plugwash
STICKY: sonic-pi 3.10 for buster available for testing.
Thu Jul 18, 2019 6:46 pm
Add
deb http://plugwash.raspbian.org/sonic-pi buster-sonicpi main
to your sources.list
apt-get update && apt-get install sonic-pi sonic-pi-server sonic-pi-samples
I have done a basic smoke test of running the application and trying out the first example in the tutorial, but i'm not a sonic-pi guy so feedback from people who actually use sonic-pi would be welcomed.
ShiftPlusOne
Re: sonic-pi 3.10 for buster available for testing.
Fri Aug 30, 2019 1:30 pm
Just tried building it for i386 and amd64:
dh_auto_configure
        cd app/gui/qt && qmake -makefile "QMAKE_CFLAGS_RELEASE=-g -O2 -fdebug-prefix-map=/<<PKGBUILDDIR>>=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2" "QMAKE_CFLAGS_DEBUG=-g -O2 -fdebug-prefix-map=/<<PKGBUILDDIR>>=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2" "QMAKE_CXXFLAGS_RELEASE=-g -O2 -fdebug-prefix-map=/<<PKGBUILDDIR>>=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2" "QMAKE_CXXFLAGS_DEBUG=-g -O2 -fdebug-prefix-map=/<<PKGBUILDDIR>>=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2" "QMAKE_LFLAGS_RELEASE=-Wl,-z,relro -Wl,-z,now" "QMAKE_LFLAGS_DEBUG=-Wl,-z,relro -Wl,-z,now" QMAKE_STRIP=: PREFIX=/usr
Info: creating stash file /<<PKGBUILDDIR>>/app/gui/qt/.qmake.stash
Project ERROR: Unknown module(s) in QT: opengl
dh_auto_configure: cd app/gui/qt && qmake -makefile "QMAKE_CFLAGS_RELEASE=-g -O2 -fdebug-prefix-map=/<<PKGBUILDDIR>>=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2" "QMAKE_CFLAGS_DEBUG=-g -O2 -fdebug-prefix-map=/<<PKGBUILDDIR>>=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2" "QMAKE_CXXFLAGS_RELEASE=-g -O2 -fdebug-prefix-map=/<<PKGBUILDDIR>>=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2" "QMAKE_CXXFLAGS_DEBUG=-g -O2 -fdebug-prefix-map=/<<PKGBUILDDIR>>=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2" "QMAKE_LFLAGS_RELEASE=-Wl,-z,relro -Wl,-z,now" "QMAKE_LFLAGS_DEBUG=-Wl,-z,relro -Wl,-z,now" QMAKE_STRIP=: PREFIX=/usr returned exit code 3
make[1]: *** [debian/rules:19: override_dh_auto_configure] Error 3
make[1]: Leaving directory '/<<PKGBUILDDIR>>'
make: *** [debian/rules:10: build-arch] Error 2
plugwash
Sat Aug 31, 2019 1:21 am
I'd guess it needs a build-dependency on libqt5opengl5-dev
jamesrobinson
Mon Sep 02, 2019 8:22 am
I have tested the install on a Pi 4 and everything I would usually use for a Picademy session is there and work's perfectly! Thanks so much
Botspot
Sat Sep 14, 2019 1:33 am
Worked last month, but today it wouldn't open. Strange.
Opened an issue on github, but error output is here also:
Sonic Pi Boot Error Report
System Information
* Sonic Pi version: 3.1.0
* OS: Raspbian GNU/Linux 10 (buster)
GUI Log
**`/home/pi/.sonic-pi/log/gui.log`**
[GUI] - Detecting port numbers...
[GUI] - GUI OSC listen port 4558
[GUI] -    port: 4558 [OK]
[GUI] - Server OSC listen port 4557
[GUI] -    port: 4557 [OK]
[GUI] - Server incoming OSC cues port 4559
[GUI] -    port: 4559 [OK]
[GUI] - Scsynth port 4556
[GUI] -    port: 4556 [OK]
[GUI] - Server OSC out port 4558
[GUI] - GUI OSC out port 4557
[GUI] - Scsynth send port 4556
[GUI] - Erlang router port 4560
[GUI] -    port: 4560 [OK]
[GUI] - OSC MIDI out port 4561
[GUI] -    port: 4561 [OK]
[GUI] - OSC MIDI in port 4562
[GUI] -    port: 4562 [OK]
[GUI] - Init script completed
[GUI] - using default editor colours
[GUI] - launching Sonic Pi Server:
[GUI] - starting UDP OSC Server on port 4558...
[GUI] - UDP OSC Server ready and listening
[GUI] - Ruby server pid registered: 20853
[GUI] - waiting for Sonic Pi Server to boot...
[GUI] - Critical error! Could not boot Sonic Pi Server.
[GUI] - stopping UDP OSC Server...
[GUI] - UDP OSC Server no longer listening
Server Errors
**`/home/pi/.sonic-pi/log/server-errors.log`**
Failed to load the fast_osc c-extension, falling back to pure Ruby version
Overriding fast_osc c-extension FastOsc::decode_single_message, falling back to pure Ruby version
control open "hw:0" (No such file or directory)
ALSA lib pcm_hw.c:1822:(_snd_pcm_hw_open) Invalid value for card
ALSA: Cannot open PCM device alsa_pcm for playback. Falling back to capture-only mode
Cannot initialize driver
JackServer::Open failed with -1
Failed to open server
ruby: No such file or directory -- /usr/app/server/ruby/bin/task-register.rb (LoadError)
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
JackTemporaryException : now quits...
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
terminate called without an active exception
Server Output
**`/home/pi/.sonic-pi/log/server-output.log`**
Sonic Pi server booting...
Using protocol: udp
Send port: 4558
Listen port: 4557
  - OK
Scsynth port: 4556
  - OK
Scsynth send port: 4556
  - OK
OSC cues port: 4559
  - OK
Erlang port: 4560
  - OK
OSC MIDI out port: 4561
  - OK
OSC MIDI in port: 4562
  - OK
Booting server...
Booting Sonic Pi
Booting on Raspberry Pi
Jackd not running on system. Starting...
jackdmp 1.9.12
Copyright 2001-2005 Paul Davis and others.
Copyright 2004-2016 Grame.
Copyright 2016-2017 Filipe Coelho.
jackdmp comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details
JACK server starting in realtime mode with priority 10
self-connect-mode is "Don't restrict self connect requests"
creating alsa driver ... hw:0|hw:0|2048|3|44100|0|2|nomon|swmeter|-|32bit
Boot - Starting the SuperCollider server...
Boot - scsynth -u 4556 -m 131072 -a 1024 -D 0 -R 0 -l 1 -i 2 -o 2 -z 128 -c 128 -U /usr/lib/SuperCollider/plugins:/usr/app/server/native/extra-ugens/ -b 4096 -B 127.0.0.1
Scsynth Output
**`/home/pi/.sonic-pi/log/scsynth.log`**
# Starting SuperCollider 2019-09-13 20:26:16
Found 0 LADSPA plugins
*** ERROR: open directory failed '/usr/app/server/native/extra-ugens/': No such file or directory
jackdmp 1.9.12
creating alsa driver ... hw:0|hw:0|1024|2|48000|0|0|nomon|swmeter|-|32bit
could not initialize audio.
Process Log
**`/home/pi/.sonic-pi/log/processes.log`**
Clearing pids: []
No pids to clear :-)
Started [19014] [-] ruby -E utf-8 /opt/sonic-pi/app/gui/qt/../../../app/server/bin/sonic-pi-server.rb -u 4557 4558 4556 4556 4559 4560 4561 4562 [-] /tmp/sonic-pi-pids/19014
Started [19086] [-] sh [-] /tmp/sonic-pi-pids/19086
Started [19143] [-] scsynth -u 4556 -a 1024 -m 131072 -D 0 -R 0 -l 1 -z 128 -c 128 -U /usr/lib/SuperCollider/plugins:/opt/sonic-pi/app/server/native/raspberry/extra-ugens/ -i 2 -o 2 -b 4096 [-] /tmp/sonic-pi-pids/19143
Started [19214] [-] sh -c erl -pz "/opt/sonic-pi/app/server/erlang" -s pi_server start 4560 [-] /tmp/sonic-pi-pids/19214
Started [19268] [-] sh -c '/opt/sonic-pi/app/server/native/raspberry/osmid/o2m' -b -i 4561 -O 4562 -m 6 [-] /tmp/sonic-pi-pids/19268
Started [19299] [-] sh -c '/opt/sonic-pi/app/server/native/raspberry/osmid/m2o' -b -o 4562 -m 6 'Sonic Pi' [-] /tmp/sonic-pi-pids/19299
Ever wished you could "open" a RaspiOS .img file? Well now you can! I've developed Pi-Power-Tools, the only RaspiOS img editor on the planet.
https://github.com/Botspot/Pi-Power-Tools
Want to try it out?
wget -O - https://raw.githubusercontent.com/Botspot/Pi-Power-Tools/master/update | bash
plugwash
Sat Sep 14, 2019 8:23 am
Seems like jack is failing to open the audio device. Are you running any other audio related stuff?
Botspot
Sat Sep 14, 2019 12:19 pm
Not that I'm aware of. How could I find out?
Want to try it out?
rbn
Tue Sep 17, 2019 11:45 am
Interested to come across this.
Personally I build SP 3.2dev from source on a Pi4 with Buster (run apt-update and apt-upgrade on it first)
Details for the build are at https://in-thread.sonic-pi.net/t/buildi ... a-pi4/2645
I have been using this both on Pi4, and on Pi2 and Pi3 with Buster.
There have been quite a lot of changes to the source code since 3.1 with several bugs sorted, and the structure of the code layout has also changed.
ShiftPlusOne
Tue Sep 24, 2019 4:25 pm
Adding the qt gl dev package did get it to build. But the older Debian version and this new version seem to have stopped working relatively recently. No idea what has changed, but now they don't get past the splash screen on x86.
rbn
Thu Sep 26, 2019 7:37 pm
Just tried the Sonic Pi 3.1 on Raspbian. Unfortunately it doesn't have the erlang support files or the osmid m2o and o2m files necessary for midi and OSC messaging to work. Consequently neither of them work See the source code on github for SP.
for what needs to be added.
You can see they are missing from the log files in ~/.sonic-pi/log/ and from looking at dpkg -L sonic-pi and dpkg -L sonic-pi-server
You need to have erlang-base installed and also the two binaries from https://github.com/llloret/osmid and the two erl files in the Sonic Pi erlang folder need to be built to .beam files
EDIT also the fast osc support doesn't seem to be built and it is falling back to a slower ruby version (from the log files)
Botspot
Wed Jan 22, 2020 1:07 pm
Same here. I can't use sonic pi at all now.
Want to try it out?
Giga_Pi
Mon Jun 15, 2020 6:36 pm
I don't want to bash the RPF, but:
Sam Aaron wrote:Hi,
Unfortunately MIDI support is broken on the RPi4 or any Pi running Buster.
It’s a long story, but essentially the Pi Foundation terminated my funding prematurely. Despite that, I still built and released version 3 of Sonic Pi for the Pi and delivered it to them for release on the Stretch version of Raspbian.
Pi Trading then released the Buster version of Raspbian and included v2.1 of Sonic Pi - effectively silently downgrading all their users to a much older version of Sonic Pi without any warning or notice on their lengthy release blog post.
When I pointed this out they initially claimed there was no downgrade?!? And then once they realised there actually was I offered to make them a new release for Buster if they could fund the development work. They declined.
Subsequently they made their own release of v3.1 and unfortunately didn’t do a good job and failed to build the MIDI / OSC support correctly. This is now shipping on their latest Raspbian and is unfortunately completely out of my control.
As the RP4 requires Buster, I can’t recommend it at all for Sonic Pi if you want to use MIDI or outgoing OSC.
The only ways forward from this that I can imagine are:
The Pi Foundation or Trading company fund me to make a proper release
They build it correctly themselves (or get someone else to)
Someone does the hard work of releasing v3.1 doe Debian proper and it then makes its way int Raspbian like any other Debian package.
Sorry for the inconvenience.
GNOME for Pi
A project to get the popular GNOME desktop to run on Raspberry Pi OS.
Guide here: https://www.raspberrypi.org/forums/viewtopic.php?f=66&t=276512
Source code here: https://github.com/TerraGitHuB/gnomeforpi
Pi4 4GB with Manjaro ARM KDE
Mon Jun 15, 2020 8:47 pm
Sam Aaron wrote:Hi,
There is an explanation 8n this recent post about why Sonic-Pi is an old version, seems to differ from what the developer stated:
viewtopic.php?f=91&t=277039
Mon Jun 15, 2020 8:48 pm
Giga_Pi
Tue Jun 16, 2020 6:21 am
Sam Aaron wrote:Hi,
Thanks! There are always two sides of the story!
GNOME for Pi
Tue Jun 16, 2020 7:27 am
Seems there is a newer version from the Developers 3.2.2
https://sonic-pi.net/#rp
Re: STICKY: sonic-pi 3.10 for buster available for testing.
Tue Jun 16, 2020 7:42 am
Yes, there are two sides to every story. We've been very quiet on our side... Lets hope it stays that way.
Return to “Raspberry Pi OS”
