joural
Raspberry pi zero display
Wed Jul 17, 2019 8:43 pm
hello, does anybody know
If there is led/oled display the size/dimensions of raspberry pi zero that can come on top of it? Connection is any, i found 2.13 inch but thats e-ink, thank you in advance
HermannSW
Re: Raspberry pi zero display
Thu Jul 18, 2019 2:13 am
Interesting question, I doubt that you will find a perfect fit.
Pi0 dimensions are 65mmx30mm, that is a 2.82" diagonal:
sqrt(65^2+30^2)/25.4 = 2.82
This is a two dimension overshoot 2.8" display (display alone is 57.6mm×47.2mm):
https://www.aliexpress.com/item/33013348233.html
This is a nearly perfect fit vertically (display alone is 88mm×28mm):
https://www.aliexpress.com/item/33012440441.html
https://www.lcd-module.com/fileadmin/en ... 4-XALG.pdf
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://gitlab.freedesktop.org/HermannSW/gst-template
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
joural
Thu Jul 18, 2019 4:17 am
HermannSW wrote: Interesting question, I doubt that you will find a perfect fit.
Thank you HermannSW
Ill go with 88x28mm
I guess thats near enough to "perfect"
Thank you again
HermannSW
Thu Jul 18, 2019 9:32 am
Ill go with 88x28mm
Be aware that 88x28 is from PDF link for display only, the module is some millimeters longer:
joural
Thu Jul 18, 2019 3:58 pm
HermannSW wrote:
Ill go with 88x28mm
Yep, will be
Somehow i couldnt find any of these ssd13XX oled displays, and i thought of myself as google master 😁
