Killertechno
Automatic refresh of map
Tue Jul 16, 2019 2:22 pm
Hi to all, I need some help about automatic map refreshing.
Here example code I downloaded (https://docs.obspy.org/tutorial/code_sn ... balls.html):
import gzip
import numpy as np
import matplotlib.pyplot as plt
from mpl_toolkits.basemap import Basemap
from obspy.imaging.beachball import beach
# read in topo data (on a regular lat/lon grid)
# (SRTM data from: http://srtm.csi.cgiar.org/)
with gzip.open("srtm_1240-1300E_4740-4750N.asc.gz") as fp:
    srtm = np.loadtxt(fp, skiprows=8)
# origin of data grid as stated in SRTM data file header
# create arrays with all lon/lat values from min to max and
lats = np.linspace(47.8333, 47.6666, srtm.shape[0])
lons = np.linspace(12.6666, 13.0000, srtm.shape[1])
# create Basemap instance with Mercator projection
# we want a slightly smaller region than covered by our SRTM data
m = Basemap(projection='merc', lon_0=13, lat_0=48, resolution="h",
            llcrnrlon=12.75, llcrnrlat=47.69, urcrnrlon=12.95, urcrnrlat=47.81)
# create grids and compute map projection coordinates for lon/lat grid
x, y = m(*np.meshgrid(lons, lats))
# Make contour plot
cs = m.contour(x, y, srtm, 40, colors="k", lw=0.5, alpha=0.3)
m.drawcountries(color="red", linewidth=1)
# Draw a lon/lat grid (20 lines for an interval of one degree)
m.drawparallels(np.linspace(47, 48, 21), labels=[1, 1, 0, 0], fmt="%.2f",
                dashes=[2, 2])
m.drawmeridians(np.linspace(12, 13, 21), labels=[0, 0, 1, 1], fmt="%.2f",
                dashes=[2, 2])
# Plot station positions and names into the map
# again we have to compute the projection of our lon/lat values
lats = [47.761659, 47.7405, 47.755100, 47.737167]
lons = [12.864466, 12.8671, 12.849660, 12.795714]
names = [" RMOA", " RNON", " RTSH", " RJOB"]
x, y = m(lons, lats)
m.scatter(x, y, 200, color="r", marker="v", edgecolor="k", zorder=3)
for i in range(len(names)):
    plt.text(x[i], y[i], names[i], va="top", family="monospace", weight="bold")
# Add beachballs for two events
lats = [47.751602, 47.75577]
lons = [12.866492, 12.893850]
# Two focal mechanisms for beachball routine, specified as [strike, dip, rake]
focmecs = [[80, 50, 80], [85, 30, 90]]
ax = plt.gca()
for i in range(len(focmecs)):
    b = beach(focmecs[i], xy=(x[i], y[i]), width=1000, linewidth=1)
    b.set_zorder(10)
    ax.add_collection(b)
plt.show()
In short I draw map and I add locations, stations and earthquake.
I would like to periodically update map (every second) but I haven't still understood how do it.
load map
# Make contour plot
                dashes=[2, 2])
                dashes=[2, 2])
# here I have my map (fixed background)
# now I periodically read data from file for "beachballs"
# draw beachballs
plt.show()	# show map
plt.savefig('books_read.png') # save image to disk for webpage
Taking a look to auto-refresh plots I can see several examples about automatically replot, but all using x-y instead maps....
Any ideas?
Thanks.
Return to “Python”
