Segue o código:
import RPi.GPIO as GPIO
import os
from subprocess import Popen
import Adafruit_CharLCD as LCD
import atexit
from time import sleep
import random
GPIO.setmode(GPIO.BCM)
# Pinos LCD x Raspberry (GPIO)
lcd_rs = 23
lcd_en = 24
lcd_d4 = 12
lcd_d5 = 16
lcd_d6 = 20
lcd_d7 = 21
lcd_backlight = 4
# Define numero de colunas e linhas do LCD
lcd_colunas = 16
lcd_linhas = 2
# Inicializa o LCD nos pinos configurados acima
lcd = LCD.Adafruit_CharLCD(lcd_rs, lcd_en, lcd_d4, lcd_d5,
lcd_d6, lcd_d7, lcd_colunas, lcd_linhas,
lcd_backlight)
# Define os botoes (BCM)
CHANNEL_UP = 3 #GPIO3
CHANNEL_DW = 2 #GPIO2
# Define as matrizes das playlists
nomeradio = []
cidade = []
radiourl = []
radioinicial = 1
nomeradio.append("Globo FM RJ")
cidade.append("Rio de Janeiro")
radiourl.append("http://stream.sgr.globo.com/hls/aRGloboRJ/aRGloboRJ.m3u8")
nomeradio.append("Globo AM")
cidade.append("Juiz de Fora")
radiourl.append("http://r13.ciclano.io:8366/stream.aac?1559573868261")
nomeradio.append("Eldorado FM")
cidade.append("Sao Paulo")
radiourl.append("https://estadaohls-lh.akamaihd.net/i/estadaohls_1@301351/index_200_a-p.m3u8?sd=10&rebase=on")
nomeradio.append("Radio Cultura")
radiourl.append("http://200.136.27.16:8001/stream/1/")
nomeradio.append("Inconfidencia AM")
cidade.append("Belo Horizonte")
radiourl.append("http://192.99.227.251:7050/;")
nomeradio.append("Radio Iatatiaia")
radiourl.append("http://8903.brasilstream.com.br:8903/stream")
nomeradio.append("Radio Record AM")
radiourl.append("http://stm2.xcast.com.br:9262/stream?1559574548787")
nomeradio.append("Radio Capital")
radiourl.append("https://audio.capitalcomvoce.com.br/capital?1559574704497")
nomeradio.append("Radio Tupi")
radiourl.append("http://189.112.0.43:8000/stream/1/")
nomeradio.append("CBN SP")
radiourl.append("https://stream.sgr.globo.com/hls/aCBNSP/aCBNSP.m3u8")
nomeradio.append("Jovem Pan News")
radiourl.append("https://19293.live.streamtheworld.com/JP_NEWSAAC.aac")
nomeradio.append("Tribuna FM")
cidade.append("Vitoria")
radiourl.append("http://cast.midiaip.com.br:6060/stream?1506557548760")
nomeradio.append("BandNews FM")
radiourl.append("http://evpp.mm.uol.com.br/band/bandnewsfm_sp/chunklist_w1028856076.m3u8")
nomeradio.append("BandNews BH")
radiourl.append("http://evpp.mm.uol.com.br/band/bandnewsfm_bh/chunklist_w1604310346.m3u8")
nomeradio.append("Bandeirantes")
cidade.append("Campinas")
radiourl.append("http://streaming.mobradio.com.br:8002/live.aac")
nomeradio.append("Radiopatos AM")
cidade.append("Patos de Minas")
radiourl.append("http://stm1.painelcast.com:7048")
nomeradio.append("Clube Patos AM")
radiourl.append("http://srv05.brasilstream.com.br:9061/mp3?type=.mp3")
nomeradio.append("Montanhesa FM")
cidade.append("Vazante")
radiourl.append("http://wz1.dnip.com.br/montanheza/montanheza.stream/chunklist_w1457849555.m3u8")
nomeradio.append("Alvorada")
radiourl.append("https://20323.live.streamtheworld.com/RADIO_ALVORADAAAC_SC")
nomeradio.append("Cultura")
cidade.append("Pocos de Caldas")
radiourl.append("http://caikron.com.br:7020/stream/1/")
nomeradio.append("Ribeirao 79 AM")
cidade.append("Ribeirao Preto")
radiourl.append("http://m3.fabricahost.com.br:8100/;")
nomeradio.append("Cidade")
cidade.append("Mogi das Cruzes")
radiourl.append("http://stm3.sateg.com.br:29234/;")
nomeradio.append("Glogo AM")
cidade.append("Sao Carlos")
radiourl.append("http://servidor39.brlogic.com:8190/live")
nomeradio.append("Bom Jesus FM")
cidade.append("Ribeirao Bonito")
radiourl.append("http://servidor20.dnip.com.br:8530/")
nomeradio.append("Vitoriosa AM")
cidade.append("Lagoa Formosa")
radiourl.append("http://stream.radiovitoriosa.com.br:8044//;stream.mp3")
nomeradio.append("Juriti AM")
cidade.append("Paracatu")
radiourl.append("http://streaming22.hstbr.net:8316/live")
nomeradio.append("Difusora AM")
cidade.append("Patrocinio")
radiourl.append("http://srv01.brasilstream.com.br:8026/mp3")
nomeradio.append("Gazeta")
radiourl.append("http://servidor1a.crossdigital.com.br:9552/1")
nomeradio.append("Dourado FM")
cidade.append("Dourado")
radiourl.append("http://euroticast5.euroti.com.br:8044/;stream/1")
nomeradio.append("Calhambeque")
cidade.append("Internet")
radiourl.append("http://198.100.146.218:7096//;stream.mp3")
# Rotina de saida
def finish():
lcd.clear()
lcd.cursor_pos = (0, 3)
lcd.message("Parando...")
exec_command("service mpd stop")
GPIO.cleanup()
print("Radio parado")
atexit.register(finish)
# Executa system command sub-routine
def exec_command(cmd):
result = ""
p = os.popen(cmd)
for line in p.readline().split('\n'):
result = result + line
return result
### Rotina principal ###
if __name__ == "__main__":
GPIO.setup(CHANNEL_UP,GPIO.IN,pull_up_down=GPIO.PUD_DOWN)
GPIO.setup(CHANNEL_DW,GPIO.IN,pull_up_down=GPIO.PUD_DOWN)
lcd.clear()
lcd.message("Conectando...")
exec_command("service mpd start")
exec_command("mpc clear")
sleep(1)
for i in range(len(nomeradio)-1): #adiciona as playlists ao mpc
exec_command("mpc add " + radiourl[i])
radioinicial = random.randint(0, len(nomeradio)-1) #sorteia, dentro da matriz contendo as playlists (comeca em 0), uma das radios
no_RadioTocando = radioinicial + 1 #A radio que esta tocando e o indice da matriz +1
max_pls_no = len(nomeradio) #variavel que contem o numero de playlists carregadas
exec_command("mpc play " + str(no_RadioTocando)) #toca a radio sorteada
exec_command("mpc volume 90") #poe o volume em 90%
current = exec_command("mpc current")
print "Tocando... " + current #mostra no terminal qual esta tocando
print nomeradio[radioinicial]
print "press CTRL + C to stop"
# Atualiza o LCD com o nome da radio que esta tocando
lcd.clear()
lcd.message(nomeradio[no_RadioTocando - 1]) #Escreve a primeira linha (nome da radio)
lcd.message('\n') #Passa pra linha de baixo
lcd.message(cidade[no_RadioTocando - 1]) #Escreve a cidade
while True: #Repete tudo isso daqui
sleep(0.1) #pra nao usar toda a CPU
MudouEstacao = False #Ainda nao mudou a estacao
if GPIO.input(CHANNEL_UP): #Se apertar o botao pra subir uma estacao:
no_RadioTocando += 1 #incrementa o indice
if no_RadioTocando > 30: #Testa se passou da ultima estacao da lista
no_RadioTocando = 1 #se sim vai pra primeira da playlist
exec_command("sudo service mpd restart")
exec_command("mpc play " + str(no_RadioTocando)) #e toca ela
MudouEstacao = True #Avisa la que mudou de estacao!
if GPIO.input(CHANNEL_DW): #Se apertar o botao para descer a estacao:
no_RadioTocando -= 1 #decrementa o indice
if no_RadioTocando < 1: #Testa se chegou abaixo da primeira da lista
no_RadioTocando = 30 #se sim passa pra ultima
MudouEstacao = True #Avisa la que mudou de estacao tambem!
if MudouEstacao: #Se a estacao mudou, atualiza o LCD e o terminal
lcd.clear()
print "Tocando... " #mostra no terminal qual esta tocando
print nomeradio[no_RadioTocando - 1]
print cidade[no_RadioTocando - 1]
sleep(0.2)
pi@raspberrypi:~ $ cd Desktop
pi@raspberrypi:~/Desktop $ sudo python Radio.py
sh: 1: stream.mp3: not found
sh: 1: stream/1: not found
Tocando... http://srv05.brasilstream.com.br:9061/mp3?type=.mp3
Clube Patos AM
Tocando...
Clube Patos AM
Patos de Minas
Tocando...
Clube Patos AM
Patos de Minas
Tocando...
Clube Patos AM
Patos de Minas
Tocando...
Clube Patos AM
Patos de Minas
O que eu fiz de errado? Que adaptação temos que fazer para migrar do Pi 3B para o Zero?
