pik33
A problem with Chromium after last update (bad rendered content)
Sat Jul 13, 2019 5:02 pm
Can you check if this page:
http://pogodynka.pl/polska/radary
displays correctly on RPi4 with lats Chromium update or it is my local problem?
On the square in the center of the screen there should be a map of Poland with rainfall data. There is a big mess there instead.
This site worked OK before and it works OK on my PC.
I don't know if it is my local program (messed up settings on my RPi) or there is the problem with the last update
neilgl
Re: A problem with Chromium after last update (bad rendered content)
Sat Jul 13, 2019 5:48 pm
It is working OK for me on my pi4 2GB with latest updates.
Andyroo
Sat Jul 13, 2019 6:55 pm
Have to agree with neilgl - headless Pi but works fine over VNC
Looks like rain headed your way :cry:
thatchunkylad198966
Sat Jul 13, 2019 7:07 pm
Happening here too on Buster desktop with all the latest updates.
I noticed this on some images don't show and whilst one's that do show, they're merge into one.
Maybe a bug?
One man's trash is another man's treasure! :) Pi's I have; Pi Zero, Pi Zero W, Pi 2 x2, Pi 3 x2, Pi 4 4GB x2.
pik33
Sat Jul 13, 2019 8:12 pm
The site works OK with old video driver. Switching to new=a mess. I tried to reset the browser to factory setting, no change. This is so far only one address which gave me such an effect... the address is important, it is main Polish weather service.
The RPi is 4 GB and this is the newest firmware by rpi-update. Also I did sudo apt-get update/upgrade
apt-get update gave me this comment:
E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'testing' to 'stable'
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
Maybe someone have a hint how to start debugging this? Browser settings change, etc...
Andyroo
Sat Jul 13, 2019 8:47 pm
To clear the status change message just run
sudo apt-get update --allow-releaseinfo-change
though I thought you should be prompted Y/N to the original question - answer Y would do the job.
This is due to Buster going live on the Pi before the formal release :)
Once that’s complete just run the update / upgrade again.
trejan
Sat Jul 13, 2019 9:18 pm
Different commands. They ran apt-get which won't prompt you. apt will.
wrn
Sat Jul 13, 2019 9:47 pm
The page you have linked appears fine in Firefox ESR to me ( lots of rain in poland right now ! ), but totally messed up in Chromium : it is all mixed like a jigsaw puzzle randomly assembled, and the rain layer isn't visible at all.
I did notice in firefox-ESR some images on some websites render like a game with a texture bug, or like some corrupt videos : lots of compression square or rectangle patterns, some shapes and contours that you can actually recognize, and globally totally messed up colors.
It really looks like something is wrong with image / video display / compression
This is with the raspberry pi4 with latest update / upgrade
wrn
Sat Jul 13, 2019 10:06 pm
Here is what http://pogodynka.pl/polska/radary looks like in firefox-ESR on the pi4 :
and in Chromium :
LTolledo
Sat Jul 13, 2019 10:08 pm
Works fine with me on a USB-SSD boot RPi3B+ Raspbian Stretch Desktop, in Chromium with 13 tabs active.
if this is some sort of map, it loads incredibly faster (no joke!) than google maps!
just checked it also on a USB-SSD boot RPi3B Raspbian Stretch Desktop, in Chromium with 15 tabs active.
loads quite good as well (peeked up to the intersection near Teodory, raining there probably).
on both RPi, just did a recent update 6 hours ago, prior to checking the liked site.
Some people be like:
LTolledo
Sat Jul 13, 2019 10:21 pm
Ok might as well post how I saw it on the 15 active tab chromium on the RPi3B (sorry cant find Teodory anymore, but peeked into some sort of airport at Konopnica)
pik33
Sun Jul 14, 2019 12:48 pm
As far as I know they get these maps from OpenStreetMap https://www.openstreetmap.org
But then OpenStreetMap works with RPi4/chromium while this radar map doesn't work.
It works OK using Firefox on the same RPi so I have a workaround which allows me to not switch on a big PC to look at these rain maps.
Chimneyfactory
Sun Jul 14, 2019 7:07 pm
On my RPi 4GB with up to date firmware and software, running Raspbian Buster :
[email protected]:~ $ uname -a
Linux pi4 4.19.57-v7l+ #1244 SMP Thu Jul 4 18:48:07 BST 2019 armv7l GNU/Linux
(Chromimum About...)
Version 74.0.3729.157 (Official Build) Built on Raspbian , running on Raspbian 10 (32-bit)
I can confirm the web page looks wrong for me too.
On a Raspberry Pi 3B+, up to date with Raspbian Stretch (up to date but not upgraded to Buster)
Linux oslo 4.19.57-v7+ #1244 SMP Thu Jul 4 18:45:25 BST 2019 armv7l GNU/Linux
(Chromium About...)
Version 72.0.3626.121 (Official Build) Built on Raspbian , running on Raspbian 9.9 (32-bit)
The web page renders ok
So I can confirm I also have the problem you are seeing.
