Catch.Rahul
Pi4 - custom dual display configuration
Fri Jul 12, 2019 4:31 pm
Hello All,
I am fairly new to the Raspberry Pi world. I wanted to achieve dual display using Pi4 and the usage is as follows:
- hdmi0 to be used to connect a 2K LCD panel via adapter board
- hdmi1 port to be connected to 7" capacity touch interface via adapter board with custom UI interface programmed in Kivy.
Can this be achieved and kindly advice on the steps that are required to achieve this.
Earlier, I was on Pi3 and config.txt (below) worked like charm for 2k display and used Nextion display for custom UI interface:
dmi_pixel_encoding=2
start_x=1
gpu_mem=128
disable_camera_led=1
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
disable_overscan= 1
#overscan_left=-16
#overscan_right=-16
#overscan_top=-16
#overscan_bottom=-16
#uncomment to force a console size. By default it will be display's size minus
# overscan.
framebuffer_width=1440
framebuffer_height=2560
max_framebuffer_width=1440
max_framebuffer_height=2560
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
config_hdmi_boost=4
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
hdmi_mode=87
hdmi_drive=2
hdmi_cvt=1440 2560 48
hdmi_pixel_freq_limit=500000000
hdmi_ignore_edid=0xa5000080
hdmi_force_hotplug=1
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
hvs_priority=0x32ff
display_rotate=0x10000
force_turbo=1
enable_uart=1
disable_overscan=1
framebuffer_depth=24
framebuffer_ignore_alpha=1
6by9
Re: Pi4 - custom dual display configuration
Sat Jul 13, 2019 9:57 am
Does your monitors have valid edids for the relevant modes? If so then it should just work.
Pi4 is using the Linux kernel standard drm/kms interface now for display mode setup, and it has far more comprehensive edid parsing than the firmware does. If the edid describes the mode correctly, then it should drive it directly.
If your display doesn't have a valid edid, then you can add a mode via xrandr if using X. There are similar low level calls to update the framebuffer size if not running X, but I can't quote them off the top of my head.
I am working on piping the settings through from tne firmware hdmi_timings into fkms, but it's not quite ready yet.
You will see some people recommending disabling the "dtoverlay=vc4-fkms-v3d" line from config.txt. You can do that, and then hdmi_timings= and hdmi_timings:1= will work to set up your two displays, however you will lose all hardware 3d support. Doing it though drm/kms is the better solution.
aBUGSworstnightmare
Sun Jul 14, 2019 8:06 am
hi 6by9,
Any schedule for these changes?
And, is there any dual display support for all other Pis (except Pi4) when using legacy driver?
6by9
Sun Jul 14, 2019 8:46 am
hi 6by9,
Adding new modes via xrandr should work now.
Plumbing from Hdmi_timings should be this week depending on interruptions.
All of the changes made to fkms for pi4 should also work on earlier Pis in fkms mode. Whether it is practical on pi0/1 I don't know.
Legacy driver has all the changes that James did to expose multiple /dev/fbN nodes. That'll also work on pi4 but you'll have no gl support. What other changes were you expecting?
aBUGSworstnightmare
Sun Jul 14, 2019 11:09 am
hi 6by9,
Well, as said, I'm not talking about Pi4 for dual-display! I have a baseboard for CM3L which worked fine with the dual-framebuffer beta by James, but no longer works with official Buster (latest release 10/07/19). But displays on their own work fine, but when I try using them together I only have HDMI.
Problem that I see is that both framebuffers were created, but only HDMI is active; DPI display has no data
[email protected]:~ $ ls /dev/fb*
/dev/fb0  /dev/fb1
and
[email protected]:~ $ tvservice -l
2 attached device(s), display ID's are :
Display Number 0, type Main LCD
Display Number 2, type HDMI 0
aBUGSworstnightmare
Sun Jul 14, 2019 11:45 am
hi 6by9,
/dev/fb0  /dev/fb1
and
EDIT:
let me add to this: both displays are identical (10in WXGA resolution); EDID data can be found here (that's the file which I'm using https://drive.google.com/open?id=1ITc_e ... 420KWPr4vq
disrupted 'framebuffer' when enabling FMKS on CM3L
Bildschirmfoto 2019-07-14 um 13.31.49_small.png (64.17 KiB) Viewed 366 times
When trying to use FKMS VNC shows me a totally disrupted 'framebuffer' https://drive.google.com/open?id=1ZsWDR ... nu0mMuY4LB
while the displays show this https://drive.google.com/open?id=1AFfkV ... URwsfV1Pii
real display
here is my config.txt
# 2019/07/14 - LVDS3CM3L
disable_overscan=1
#hdmi_force_hotplug=1
hdmi_drive=1
dtoverlay=hifiberry-dac
dtoverlay=i2c0-bcm2708,pins_44_45
dtoverlay=i2s-gpio28-31
dtoverlay=i2s-mmap
gpu_mem=208
# custom HDMI mode
hdmi_group=2
hdmi_mode=87
framebuffer_depth=32
# DPI timing definitions LQ101K1LW02
hdmi_timings=1280 0 160 48 48 800 0 23 6 8 0 0 0 60 0 71100000 5
dpi_timings=1280 0 160 48 48 800 0 23 6 8 0 0 0 60 0 71100000 5
dpi_output_format=458791
#dtoverlay=dpi24
gpio=0-27=a2,np
enable_dpi_lcd=1
dpi_group=2
dpi_mode=87
hdmi_edid_file=1
enable_uart=0
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
max_framebuffers=2
[all]
max_framebuffers=2
Note: as reported already 'dtoverlay=dpi24' is not working with FMKS driver, regardless of the platform (Rpi3 or Rpi4); I need to use GPIO command for configuring DPI interface
#dtoverlay=dpi24
gpio=0-27=a2,np
Working with the disrupted screen is impossible; screen configuration tools fans to change alignment/placement of the displays. DSI display is always primary; size shown in config tool is different for both screens (again;: both are the same)
Sun Jul 14, 2019 12:27 pm
If you do
cat /dev/urandom > /dev/fb0
cat /dev/urandom > /dev/fb1
do they both display something random?
aBUGSworstnightmare
Sun Jul 14, 2019 12:32 pm
jamesh wrote: If you do
Yes (did this test with FMKS disabled); screens are filled entirely with random data.
under FMKS 'cat /dev/urandom > /dev/fb0' fills both displays with random data (as expected)
Mon Jul 15, 2019 10:11 am
So the framebuffers are working correctly.
What is not actually working?
6by9
Mon Jul 15, 2019 10:12 am
Please keep the two threads separate
Thread title:"Pi4 - custom dual display configuration"
First post: "I wanted to achieve dual display using Pi4 "
Fifth post: "Well, as said, I'm not talking about Pi4 for dual-display"
So now I have no idea whether any of your posts are for Pi3 or Pi4, at which point I drop out of providing support.
Keep this thread to Pi4 dual displays, and start a new thread with full details of your Pi3/CM3 issues.
aBUGSworstnightmare
Mon Jul 15, 2019 10:23 am
There is no display on the second framebuffer! Yes, I can write random data to it but that's of no particular use.
To me it looks like the code from 'dual framebuffer testing' is either ported incomplete or no longer working.
6by9 wrote: Please keep the two threads separate
There is a thread for this by me already (https://www.raspberrypi.org/forums/view ... 0#p1486670) but nobody was answering so far... To me it looks like with release of RPi4 all issues related to Rpi3 get's abandoned
I do exactly what you're prposing here https://www.raspberrypi.org/forums/view ... 0#p1486790 - means using EDID.dat file - but that's doesn't solve the problem as you can see from my recent postings here
Please explain to me why VNC shows the same disruppted framebuffer as I see on my screens and how you guys can tell 'all fine'!
Mon Jul 15, 2019 10:36 am
So, the frame buffers are working, both in legacy and FKMS but you do not have the desktop on it? This is not done by default on older devices in legacy mode (unlike pi4, where using FKMS means it all works out of the box). You will need to set up X to use multiple displays. This is described in the previous dual display thread, I'll try and dig it up.
But I would expect when using FKMS that the desktop would be extended over both displays. What does the screen configuration utility do?
aBUGSworstnightmare
Mon Jul 15, 2019 10:43 am
jamesh wrote: So, the frame buffer is working, but you do not have the desktop on it? This is not done by default on older devices (unlike pi4, where using FKMS means it all works out of the box). You will need to set up X to use multiple displays. This is described in the previous dual display thread, I'll try and dig it up.
Exactly. Well ... I was under the impression that this will work now because of this statement by 6by9
If some 'adjustments' need to be made then it will not work on Pi4 with legacy driver either, right?
This would explain why legacy driver doesn't work as expected, but still doesn't explain why new FMKS/DRM driver - with custom resolution and timing from EDID file - fails to work (doesn't work 'out of the box' on old devices when new driver is enabled).
aBUGSworstnightmare
Mon Jul 15, 2019 12:11 pm
well, there is some desktop , but neither correct not extended entirely (!) over both displays.
The screen configuration utility fails (as described in the post above); the picture and screenshot were showing 'my FMKS desktop'. Using the system is impossible, either from it's own desktop nor via a VNC session.
6by9
Mon Jul 15, 2019 1:11 pm
You've followed the old thread. X has never had native support for writing to multiple /dev/fbN devices, you have to use xinerama or similar. That will never change. If you thought it would then that was a big assumption on your part.
All the work done by James to expose multiple /dev/fbN nodes is merged and should be working. (By the sounds of it it is, as you can cat /dev/urandom to the framebuffer).
aBUGSworstnightmare wrote:This would explain why legacy driver doesn't work as expected, but still doesn't explain why new FMKS/DRM driver - with custom resolution and timing from EDID file - fails to work (doesn't work 'out of the box' on old devices when new driver is enabled).
I could expend the time downloading your EDIDs to try to replicate thereby delaying implementing propagation of hdmi_timings, or you can run "xrandr" for yourself to see where X is dumping the displays.
For me on a Pi4 with a 4k and a 1080p screen attached and configured as 4k to the left of the 1080p, I get:
[email protected]:~ $ DISPLAY=:0 xrandr
Screen 0: minimum 320 x 200, current 5760 x 2160, maximum 7680 x 7680
HDMI-1 connected primary 3840x2160+0+0 (normal left inverted right x axis y axis) 609mm x 349mm
   3840x2160     30.00*   30.00    25.00    25.00    24.00    24.00    29.97    23.98
   2560x1440     59.95
   2048x1280     59.99
   2048x1080     24.00
   1920x1080     60.00    60.00    50.00    59.94    30.00    25.00    24.00    29.97    23.98
   1600x1200     60.00
   1600x900      60.00
   1280x1024     75.02    60.02
   1152x864      75.00
   1280x720      60.00    50.00    59.94
   1024x768      75.03    60.00
   800x600       75.00    60.32
   720x576       50.00    50.00
   720x480       60.00    60.00    59.94    59.94
   640x480       75.00    60.00    59.94    59.94
   720x400       70.08
HDMI-2 connected 1920x1080+3840+0 (normal left inverted right x axis y axis) 527mm x 296mm
   1920x1080     60.00*+  60.00    50.00    59.94
   1600x1200     60.00
   1152x864      75.00
   1280x720      60.00    60.00    50.00    59.94
   800x600       75.00    60.32
   720x576       50.00    50.00
   720x480       60.00    60.00    59.94    59.94    59.94
   720x400       70.08
The resolution is <width>x<height>+<xoffset>+<yoffset>
So what is your configuration?
Pi3 is not being ignored, but there are a lot of balls in the air at present to expose more functionality on all platforms. Forum threads get attention as and when time allows, and some will occasionally get missed.
aBUGSworstnightmare
Mon Jul 15, 2019 4:32 pm
6by9 wrote: All the work done by James to expose multiple /dev/fbN nodes is merged and should be working. (By the sounds of it it is, as you can cat /dev/urandom to the framebuffer).
Yes, two frame buffers are generated - I've never denied that (refer to my post above; there you can see display #0 and #2 are connected.
I can also use 'framebuffer_priority' command for switching them, but I never get a desktop on both of them!
6by9 wrote: I could expend the time downloading your EDIDs to try to replicate thereby delaying implementing propagation of hdmi_timings, or you can run "xrandr" for yourself to see where X is dumping the displays.
Which EDID did you use? The problem is with 2x 10.1in WXGA resolution displays, one is connected to HDMI, the other one to DPI. Both displays are the same, EDID data of the display is this one https://drive.google.com/open?id=1ITc_e ... 420KWPr4vq
6by9 wrote: Pi3 is not being ignored, but there are a lot of balls in the air at present to expose more functionality on all platforms. Forum threads get attention as and when time allows, and some will occasionally get missed.
You may know that I did a lot of testing of the dual-framebuffer beta, posting my findings and helping others to get it running.
I've pointed out this issue several times already but all that has been suggested isn't working (i.e. using EDID.dat file to get FMKS running with custom timing). There is an issue with the dpi24 overlay doing nothing (also reported).
What I will do tomorrow is a test to see if EDID.dat file on a Rpi4 (with one WXGA display connected to DPI) is working.
Nevertheless, before adding 'more functionality' it might be a good idea to get the existing one working correctly. By the time when I started to ask for dual display support I was given the answer by some foundations members 'might be a pretty edge use case' and now a RPI offers exactly that possibility.
As you still 'claim all is running' what about showing it to us? You guys at RPi foundation have a Adafruit kippah and ton's of monitors. So why not test - lets say with a Full-HD monitor on HDMI and the DPI display connected - to a RPI3 with legacy driver as well as with FMKS and post the evidence (and the config file used) here. Then I can replicate and report back, rather then hearing 'it should be working'! You either no it works or know it doesn't, but saying 'it should' is equal to 'I don't know'.
aBUGSworstnightmare
Mon Jul 15, 2019 4:55 pm
So, I would say the pottation of dual framebuffer support with legacy driver is incomplete!
when I look at
nano /usr/share/X11/xorg.conf.d/99-fbturbo.conf
I only see below, but not what we've used in the testing (https://www.raspberrypi.org/forums/view ... 5#p1416171)
# This is a minimal sample config file, which can be copied to
# /etc/X11/xorg.conf in order to make the Xorg server pick up
# and load xf86-video-fbturbo driver installed in the system.
# When troubleshooting, check /var/log/Xorg.0.log for the debugging
# output and error messages.
# Run "man fbturbo" to get additional information about the extra
# configuration options for tuning the driver.
Section "Device"
        Identifier      "Allwinner A10/A13 FBDEV"
        Driver          "fbturbo"
        Option          "fbdev" "/dev/fb0"
        Option          "SwapbuffersWait" "true"
EndSection
Do I still need to use 'startx -- -layout Multihead' to get dual framebuffer on RP3? Will it work on Zero an other devices as well? What is the new assignment of the screens (I think 7 is now HDMI1 on Rpi4, right) for accessing the frame buffers (also valid for OMXplayer i.e.) as there is no documentation of 'framebuffer_priority' command.
#  desktop display will default to the LCD (fb0)
# This will force the specified display to be the first in the list, i.e. /dev/fb0
# Actually this is the full set:
# MAIN_LCD 0
# AUX_LCD 1
# HDMI 2
# SDTV 3
framebuffer_priority=2
And - why do you have
[all]
#dtoverlay=vc4-fkms-v3d
max_framebuffers=2
In a standard config file if it doesn't work with only specifying number of framebuffers to be created?
6by9
Mon Jul 15, 2019 5:09 pm
I've just noticed that the OP is not aBUGSworstnightmare, therefore he's hijacked the original request and that has lead to a load of my confusion.
The ones provided by the monitors.
I have also had an VGA666 hooked up and happily driving HDMI0 and DPI. VGA666 needed dpi_group=1, dpi_mode=16, and gpio=2-21=a2. Tested on both Pi3 and Pi4.
For which we are very grateful.
aBUGSworstnightmare wrote:I've pointed out this issue several times already but all that has been suggested isn't working (i.e. using EDID.dat file to get FMKS running with custom timing).
We haven't the resource to debug each and every EDID issue.
aBUGSworstnightmare wrote:I've pointed out this issue several times already but all that has been suggested isn't working (i.e. using EDID.dat file to get FMKS running with custom timing). There is an issue with the dpi24 overlay doing nothing (also reported).
Reported on a forum post in Troubleshooting, and no apparent further action from you when recommended that the Device Tree subforum was the better bet, or raise it on Github.
aBUGSworstnightmare wrote:What I will do tomorrow is a test to see if EDID.dat file on a Rpi4 (with one WXGA display connected to DPI) is working.
So do you want to be able to provide custom timings via config.txt, or don't you?
On a Pi3 it was (and still is) an edge case. On Pi4 the majority are using dual HDMI which is working happily except with dodgy EDIDs.
aBUGSworstnightmare wrote:As you still 'claim all is running' what about showing it to us? You guys at RPi foundation have a Adafruit kippah and ton's of monitors. So why not test - lets say with a Full-HD monitor on HDMI and the DPI display connected - to a RPI3 with legacy driver as well as with FMKS and post the evidence (and the config file used) here. Then I can replicate and report back, rather then hearing 'it should be working'! You either no it works or know it doesn't, but saying 'it should' is equal to 'I don't know'.
I tested on the Pi3 before the Buster release.
I haven't necessarily tested on the absolute latest firmware/kernel, regressions happen therefore I will not 100% guarantee it will still work, therefore "should" is a very appropriate word.
aBUGSworstnightmare
Mon Jul 15, 2019 6:56 pm
I know how to deal with custom timings and how to create EDID data, so I'm fine with both. I also have a EDID EEPROM on my board, but why should I bother myself with programming it if uisng the file fails to configure the driver correctly.
Custom hdmi timings is what is documented here, there is nothing on EDID. As there are lots of examples on the forum for hdmi_timings as well I surely want to keep it.
O.k. I will stop hijacking this post and take the time for some testing tomorrow. I will be using an HDMI monitor which requires custom timing, a Adafruit 5in Kippah (settings posted at bottom of this page https://www.raspberrypi.org/documentati ... /README.md) and test with Rpi3 and Rpi4 and then open a new thread. Let me know which sub-forum suits best.
I will start with a freshly downloaded image because that's all what 'the average Joe' has.
Will also take a camera with me for recording some footage.
