mignev
Communication with Arduino problem with pyserial
Mon Dec 03, 2012 1:36 pm
Hi Guys,
I have the following stupid problem:
I'm trying to communicate with one (or more but now only with one) Arduino over USB via pySerial lib, but when i type this:
 $ python
 >>> import serial
 >>> arduino = serial.Serial('/dev/ttyACM0', 9600)
It takes a few seconds at least 5-6 to connect and after that when i type:
>>> arduino.write('something')
it takes also at least 5-6 seconds and also the load of the raspberry grows to 4-5 and also sometimes raspberry crashes and must be restarted.
Did you have any idea what's happend?
Thanks in advance :))
trouch
Re: Communication with Arduino problem with pyserial
Mon Dec 03, 2012 4:24 pm
did you remove the getty on ttyAMA0 ?
see http://www.irrational.net/2012/04/19/us ... rial-port/
WebIOPi - Raspberry Pi REST Framework to control your Pi from the web
http://store.raspberrypi.com/projects/webiopi
http://code.google.com/p/webiopi/
http://trouch.com
mignev
Tue Dec 04, 2012 9:48 am
thank you very much about the advice, i wasn't, but now there is another problem:
  File "<stdin>", line 1, in <module>
  File "relay.py", line 5, in send_cmd
  File "/usr/lib/python2.6/dist-packages/serial/serialutil.py", line 166, in __init__
    self.open()
  File "/usr/lib/python2.6/dist-packages/serial/serialposix.py", line 175, in open
    raise SerialException("could not open port %s: %s" % (self._port, msg))
serial.serialutil.SerialException: could not open port /dev/ttyACM0: [Errno 5] Input/output error: '/dev/ttyACM0'
I can't connect to the arduino. I tried to restart the ardino several times but nothing different happens
Any ideas?
trouch
Tue Dec 04, 2012 9:57 am
I'm sorry, I didn't noticed you are trying to communicate with the USB port of the Arduino.
Try make a search on "FTDI" : http://raspberrypi.org/phpBB3/search.php?keywords=ftdi
http://trouch.com
trouch
Tue Dec 04, 2012 9:59 am
http://trouch.com
croston
Tue Dec 04, 2012 10:01 am
One way of seeing what your Arduino is appearing as is:
ls /dev/tty*
Plug in you Arduino
ls /dev/tty*
Look at the difference.
It is possible your Arduino is appearing as /dev/ttyUSB0 or /dev/ttyACM1 instead.
mignev
Tue Dec 04, 2012 10:22 am
Hi :),
thank you very much for fast answer. In this link are some many different cases, problems with USB hubs, problem with drivers and so on. Tonight after i get home i will try all of them and i will write what is happened :)
mignev
Tue Dec 04, 2012 10:25 am
croston wrote:One way of seeing what your Arduino is appearing as is:
ls /dev/tty*
Plug in you Arduino
ls /dev/tty*
Hi Croston,
my Arduino is on ACM0 :)
make sure yourself:
@pi on #raspberrypi in ~
# ls /dev/tty*
/dev/tty    /dev/tty12  /dev/tty17  /dev/tty21  /dev/tty26  /dev/tty30  /dev/tty35  /dev/tty4   /dev/tty44  /dev/tty49  /dev/tty53  /dev/tty58  /dev/tty62  /dev/ttyACM0
/dev/tty0   /dev/tty13  /dev/tty18  /dev/tty22  /dev/tty27  /dev/tty31  /dev/tty36  /dev/tty40  /dev/tty45  /dev/tty5   /dev/tty54  /dev/tty59  /dev/tty63  /dev/ttyAMA0
/dev/tty1   /dev/tty14  /dev/tty19  /dev/tty23  /dev/tty28  /dev/tty32  /dev/tty37  /dev/tty41  /dev/tty46  /dev/tty50  /dev/tty55  /dev/tty6   /dev/tty7   /dev/ttyS7@
/dev/tty10  /dev/tty15  /dev/tty2   /dev/tty24  /dev/tty29  /dev/tty33  /dev/tty38  /dev/tty42  /dev/tty47  /dev/tty51  /dev/tty56  /dev/tty60  /dev/tty8
/dev/tty11  /dev/tty16  /dev/tty20  /dev/tty25  /dev/tty3   /dev/tty34  /dev/tty39  /dev/tty43  /dev/tty48  /dev/tty52  /dev/tty57  /dev/tty61  /dev/tty9
techpaul
Tue Dec 04, 2012 11:44 am
Something that I find useful when dealing with ttys, is looking in /dev/tty is full of virtual terminals which most folks never use (anyone used /dev/tty60 to /dev/tty64).
One thing you can do which makes it easier to look at this directory for debugging is create a file called
/etc/udev/rules.d/99-my-tty-rules.rules
Put this one line in
KERNEL=="tty[1-9][0-9]", RUN="/bin/rm /dev/%k" OPTIONS+="ignore_devices"
then at start up you have only /dev/tty0 to /dev/tty9 the list is so much easier to look through.
This is a variation of this page
Next to no performance enhancement just a nicety when searching through lists. No extra hassle done at every boot, if you dont like delete the file and reboot.
Simples :-P
Just another techie on the net - For GPIO boards see http:///www.facebook.com/pcservicesreading
or http://www.pcserviceselectronics.co.uk/pi/
mignev
Tue Dec 04, 2012 11:53 am
Nice idea Paul :)) Thanks :)
trouch
Tue Dec 04, 2012 1:31 pm
better way here to find serial devices :
http://stackoverflow.com/questions/2530 ... ening-them
1.7 TTY info in /proc/tty
Information about  the  available  and actually used tty's can be found in the
directory /proc/tty.You'll  find  entries  for drivers and line disciplines in
this directory, as shown in Table 1-11.
Table 1-11: Files in /proc/tty
 File          Content
 drivers       list of drivers and their usage
 ldiscs        registered line disciplines
 driver/serial usage statistic and status of single tty lines
To see  which  tty's  are  currently in use, you can simply look into the file
/proc/tty/drivers:
  > cat /proc/tty/drivers
  pty_slave            /dev/pts      136   0-255 pty:slave
  pty_master           /dev/ptm      128   0-255 pty:master
  pty_slave            /dev/ttyp       3   0-255 pty:slave
  pty_master           /dev/pty        2   0-255 pty:master
  serial               /dev/cua        5   64-67 serial:callout
  serial               /dev/ttyS       4   64-67 serial
  /dev/tty0            /dev/tty0       4       0 system:vtmaster
  /dev/ptmx            /dev/ptmx       5       2 system
  /dev/console         /dev/console    5       1 system:console
  /dev/tty             /dev/tty        5       0 system:/dev/tty
  unknown              /dev/tty        4    1-63 console
the previous link I give suggest to add the pi user to the dialout group, but you can also try to run as root ;)
sudo usermod -a -G dialout pi
what is your arduino ? Uno or previous one ?
http://trouch.com
mignev
Tue Dec 04, 2012 2:37 pm
interesting discussion is formed here :)
I tried to add pi user dialout group but nothing different happens, also i tried and with root user but is the same ....
About the Arduino actualy is UNO.
trouch
Tue Dec 04, 2012 3:24 pm
Ok, so /dev/ttyACM0 is okay regarding your previous ls command
Do you already used your Arduino under Linux ?
If no, when do you bought it ?
You may suffer the early 8U2 firmware bug (before december 2010)...
http://www.strangeparty.com/2010/12/13/ ... for-linux/
http://trouch.com
croston
Tue Dec 04, 2012 3:50 pm
mignev wrote:interesting discussion is formed here :)
You need to log out and back in for the group change to take effect. To check what groups you are in at the moment:
groups
mignev
Tue Dec 04, 2012 7:32 pm
Hi guys,
i am very confused ... this stinker works whenever it wants ... I just pull the cable and after few seconds i push it back ... and works, but from time to time it breaks and from time to time fix by itself ... i dont know !?! I really am very confused
chirag
Sun Jan 27, 2013 7:50 am
python code:
import serial
ser=serial.Serial("/dev/ttyACM0",9600)
x=input("")
while 1:
ser.open()
ser.write(x)
im just trying to write to that file whatever i give the input its working fine but after 2 seconds il get
serial.serialutil.SerialException: could not open port /dev/ttyACM0: [Errno 24] Too many open files: '/dev/ttyACM0'
infinate loop because i want to write to that file whatever i enter you have any idea why this is happening..??
shuckle
Sun Jan 27, 2013 2:00 pm
You need to close ser after the write. Without that you open it every time and run out of file handlers.
Or move taht open before while.
gordon77
Sun Jan 27, 2013 8:16 pm
I found I had to put a delay between sending strings from my Pi to Arduino
Gordon77
import serial
            ser = serial.Serial('/dev/ttyACM0',9600)
            ser.write(bytes(Vcorrt.encode('ascii')))
            t1 = time.time()
            while time.time() < t1 + 0.2:
               t2 = time.time()
            ser.write(bytes(Hcorrt.encode('ascii')))
Return to “Python”
