Mettauk
Pi4b J2 Run Global_En as power
Wed Jul 10, 2019 3:40 pm
Wondering what these are for and is it OK to run a very small fan from here (25x25x7mm 5v 0.2a) on either the 3.3v or the 4.75v side as tested? I want to keep the 40pin GPIO header clear for other stuff and don't really want to solder underneath
As humans we have been the same for a very very long time, technology changes how we do... not who we are as people.
dp11
Re: Pi4b J2 Run Global_En as power
Wed Jul 10, 2019 4:28 pm
These pins aren't suitable for running a fan.
trejan
Wed Jul 10, 2019 5:02 pm
RUN is for resetting the SoC. GLOBAL_EN is for signalling the PMIC to leave the low power shutdown state. Neither should be used for powering a fan.
IrishBrewer
Wed Jul 10, 2019 5:18 pm
I was kind of hoping they would put a fan header on the board for the same reasons stated by the OP. Seems like a simple thing to do that would keep the 40-pin header "clean". With the performance increases making it viable to use the current incarnation as a lite desktop device, active cooling (combined with passive) becomes more important.
Imperf3kt
Wed Jul 10, 2019 7:49 pm
In case it needs to be noted, the third hole in the center is ground.
55:55:44:44:4C
52:4C:52:42:41
chipace
Wed Jul 10, 2019 8:14 pm
The GLOBAL_EN pin has 100k Ohms to 5V, you are not going to get any current from that connection (and if you did you would reset the part). RUN is an input to the SOC (you could damage the SOC). The GND connection between those pins would probably be fine.
You probably don't need a fan, unless you are mining bitcoin.
SeyfertR
Sat Aug 03, 2019 2:23 pm
Thank you all so much for the information. :D I have a case from a bundler that has a fan and plugging it into the GPIO where they instruct to sort of defeats the purpose of GPIO bridging. I might have burned the thing out one day into ownership.
I guess I will solder V+ to the bottom of the board and recommend that they fire their case engineer. :lol:
Now I need to find the thread for partitioning a 64GB microSD card into 2 ea 32GB partitions, so that I can have a OS and Data drive, as only *nix can do.
Take care, God bless and be safe.
Rich
