LLDesign
Missing Python 3 Idle in the Programming Menu
Tue Jul 09, 2019 12:49 am
I installed the latest Rasbian released last month on my RPi 3 B+. Everything works fine but I can't find IDLE in the programming menu. The python version on my pi is currently 3.7.3. I can run the code through Thonny Python IDE or Terminal. Does anyone know how to add IDLE into the programming menu? I attached a picture of my programming menu.
Thank you!
Screen shot of the programming menu on my RPi.
Programming Menu.png (69.68 KiB) Viewed 8710 times
trejan
Re: Missing Python 3 Idle in the Programming Menu
Tue Jul 09, 2019 1:00 am
It was removed from the default Raspbian image but it is still in the repo. Try running "sudo apt install idle".
Andyroo
Tue Jul 09, 2019 1:40 am
Or you can use Geany that is set up for Python 3 and is the one going forward the Foundation will be promoting and supporting.
scruss
Tue Jul 09, 2019 1:44 am
I thought it was Thonny they were promoting?
Pronouns: he/him
PeterO
Tue Jul 09, 2019 5:49 am
This is a problem in a school I visit where they still have some older Pis which work perfectly well with IDLE3, but are unusable with Thonny. I thought the aim was to maintain backwards comparability ?
PeterO
B.Goode
Tue Jul 09, 2019 6:12 am
This removal (IDLE3) is not listed in the Raspbian Release Notes, unlike the Python2 IDLE which is noted as removed.
Perhaps it is a Raspbian Buster packaging error/oversight/bug that should be added to the mega Buster Bugs list?
PeterO
Tue Jul 09, 2019 6:18 am
I'm sure I've read it is a deliberate (re)move(al).
PeterO
Tue Jul 09, 2019 7:11 am
Yes it has been removed, but easily reinstalled if you need it. Thonny is indeed the replacement.
PeterO
Tue Jul 09, 2019 8:12 am
You see the inconsistency though ? You use "we need to maintain one kernel for all models" as justification for not going 64bit, then you ignore the needs of users with the older models by obscuring software they need.
PeterO
B.Goode
Tue Jul 09, 2019 8:34 am
PeterO
... and further obscure the issue by not documenting it.
[There are explicit mentions of IDLE (ie the Python2 version) being removed, but not IDLE3. An unfortunate oversight.]
Berniedu24
Sun Aug 04, 2019 7:07 am
I instal Buster 2019-07-10 version.
Yes the python idle3 is not on desktop on first startup but:
sudo apt-get install idle3
restore it
And you can see and start it from desktop menu programming.
From Terminal use:
idle-python3.7
to start it
Work for me on Pi3B+
ChrisEdH
Fri Jan 10, 2020 8:21 pm
@trejan worked perfectly for me, I had the exact same problem. Thank you very much
NeonCoder
Mon May 18, 2020 4:19 pm
Though You can run python perfectly on Thonny or Mu, But You can't Install a library.
hafifi
Fri Sep 11, 2020 9:23 am
@Berniedu24 Work for me by isntalling it and it was shown inside the menu already.. thanks
