0018
RPi4 Buster no Sound on HDMI
Sun Jul 07, 2019 7:00 pm
i have a problem with the sound over HDMI on my Rpi4 4GB with Buster. It is not possible to get sound over HDMI, 3,5mm² is fine.
I tried the advanced settings in the raspi -config to force the audio over HDMI, but nothing happend, also after a reboot.
Is there other options which i have to activate?
Thanks.
trejan
Re: RPi4 Buster no Sound on HDMI
Sun Jul 07, 2019 8:17 pm
What does "sudo tvservice -a" say?
6by9
Mon Jul 08, 2019 5:06 pm
Only one HDMI port is currently supported for audio at a time, and it is independent of the video.
Default is HDMI0, therefore if your monitor is connected to HDMI1 you will get no audio.
"hdmi_preferred=1" in /boot/config.txt to shift audio (and CEC) to HDMI1.
Thom101
Fri Jul 12, 2019 9:38 pm
I have a new Pi 4 B 4gb I go the Raspian NOOBS 3.2.0 and the sound and HDMI0 stopped working for me (I will attempt to reinstall 3.1.1 unless my card was corrupted) but the issues seems similar to 0018's issue. But I didn't look in the configuration to see what was going on. My Pi 3 B+ is still working fine and the 4 seems like it was getting hot also. You have any of the other issues 0018?
zabadaba
Sun Jul 14, 2019 10:25 am
THANK YOU! I tried everything I could find on this issue and this explanation fixed it.
snowballEarth
Fri Aug 23, 2019 7:14 pm
Raspbian buster and libreelec 9.1.002 didn't play well with my 8-year-old Logik branded tv.
The sound didn't come on through hdmi, but picture did (albeit at only 720p, when tv supports 1080p)
I looked at other threads and the following line brought back sound over hdmi:
add "hdmi_drive=2" to /boot/config.txt in raspbian.
the file is located in /flash/config.txt in libreelec.
bunklung
Tue Aug 27, 2019 10:56 am
This isn't documented and it didn't work for me :(
https://www.raspberrypi.org/forums/view ... 8#p1526219
https://www.raspberrypi.org/documentati ... t/video.md
