bpm009
Official 7" touchscreen backlight control
Sat Jul 06, 2019 8:17 pm
I am at a loss, I had a python script using this function running before but corrupt SD card and not backing up my files leads me to relearning :( .
I am trying to turn on and off the backlight for the 7" official touchscreen using the "echo 1 / 0" commands. When I run the script I get a syntax on the line with the backlight command but I can't see what the issue is. I run the on and off line command in the command prompt and the screen reacts as it should. Below is the code I'm using.
import RPi.GPIO as GPIO
import time
import os
GPIO.setmode(GPIO.BCM)
GPIO.setup(25, GPIO.IN, pull_up_down=GPIO.PUD_UP)
shutdownStarted = False
while True:
    if (GPIO.input(25) == False and not shutdownStarted):
        os.system("sudo shutdown -h -57")
        echo 1 > /sys/class/backlight/rpi_backlight/bl_power
        # This stops the code inside this if from being executed again even if the pin stays False
        shutdownStarted = True
    secs = 57 * 60
    # Run this loop once per second for 57 mins as long as shutdown is still supposed to happen
    while (secs > 0 and shutdownStarted):
        if (GPIO.input(25) == True):
            # This now allows the shutdown -h code to be run again
            # assuming you want this to execute forever based on the while True you got goin on there
            os.system("sudo shutdown -c")
            echo 0 > /sys/class/backlight/rpi_backlight/bl_power
        time.sleep(1)
        secs -= 1
    time.sleep(1)
ghp
Re: Official 7" touchscreen backlight control
Sat Jul 06, 2019 8:20 pm
there are multiple places like
think you should wrap the echo command into a os.system("echo ...")-command.
bpm009
Tue Jul 09, 2019 3:37 pm
Thanks GHP, that was exactly the solution. I must have had it inside the os.system command last time.
Return to “Python”
