alexzace
Pi 4 Raspbian Buster PEAP connection failed
Fri Jul 05, 2019 7:39 am
Hi, currently i have a Pi 4 with Buster OS.
Please help to solve this issue. Thanks
This is my wpa_supplicant.conf which work in any model of Raspberry Pi(Jessie/Stretch) except Raspberry Pi 4 model B (Buster).
update_config=1
network={
ssid="MYSSID"
key_mgmt=WPA-EAP
eap=PEAP1
identity="ID"
password="PASSWORD"
swahren
Re: Pi 4 Raspbian Buster PEAP connection failed
Fri Jul 05, 2019 3:04 pm
Do you have this kernel warning?
What version of wpa_supplicant do you have?
Andyroo
Fri Jul 05, 2019 7:02 pm
Welcome to the forum.
Try adding a country code in the file - the release notes for Buster state:
* On-board 5GHz WiFi blocked by rfkill by default
The block is removed when taking one of the following actions:
- Selecting a locale in the first run wizard
- Setting the WiFi country in the Raspberry Pi Configuration tool or the Network Settings applet
- Setting the WiFi country in raspi-config
- Providing a wpa_supplicant.conf file through the boot partition
- Running 'rfkill unblock wifi'
I guess you dropped the file into /boot before the first boot - I've found that the country code needs to be in the file even if you are not using 5Ghz
alexzace
Tue Jul 09, 2019 2:44 am
Thanks for your reply.
To make sure, the wifi is work. I'm able to connect my personal hotspot(WPA-PSK).
The Pi successfully connect the network via the external Wifi adapter.
But when connect via the build-in wifi , it keep failed and retry. (WPA2-Enterprise)
@swahren my wpa_supplicant version is v2.8-devel.
@Andyroo rfkill show bluetooth and wlan unblocked. After added country code in wpa_supplicant, it still failed to connect.
alexzace
Wed Jul 10, 2019 7:09 am
I found that have the bug in Raspbian Buster.
wpa_supplicant (v2.8-devel) in Raspbian Buster can't connect to WPA2-Enterprise.
Its works, while install the wpa_supplicant(v2.4) from Stretch repository.
Tavan
Fri Jul 12, 2019 8:26 pm
I have been trying to solve this exact problem with "eduroam" since getting my Rasperry Pi 4 and flashing Raspbian Buster for it. This has so far been the only solution I have gotten to work so I'm going to post instructions here and link to this topic from a few other places.
My /etc/wpa_supplicant/wpa_supplicant.conf file contains the following settings:
update_config=1
country=US
network={
        ssid="eduroam"
        scan_ssid=1
        key_mgmt=WPA-EAP
        eap=PEAP
        identity="*****@*****.edu"
        password=hash:**************************************
        phase1="peaplabel=auto peapver=auto"
        phase2="auth=MSCHAPV2"
Take the following steps to install the Stretch version of wpa_supplicant (2:2.4-1+deb9u4):
Create the following apt preference files:
/etc/apt/preferences.d/stretch.pref:
Package: *
Pin release n=stretch
Pin-Priority: 750
/etc/apt/preferences.d/buster.pref:
Package: *
Pin release n=buster
Pin-Priority: 900
Create the following apt list file:
/etc/apt/sources.list.d/stretch.list:
deb http://mirrordirector.raspbian.org/raspbian/ stretch main contrib non-free rpi
Update the apt lists, double check that the stretch version is available, then install the stretch version over the buster version. I don't know if the version number might change for the Stretch release... if so, just copy it from the output of the apt-cache command and paste it over the version number in the apt-get install command
sudo apt-get update
apt-cache policy wpasupplicant
sudo apt-get install wpasupplicant=2:2.4-1+deb9u4 -t stretch
*EDIT*
After installing the Stretch version of wpa_supplicant, you'll also want to put a version hold on it so that it doesn't get updated automatically when you perform other update/upgrade operations. You can do this using the following command:
sudo apt-mark hold wpasupplicant
If you need or want to remove the hold later do so with the similar command:
sudo apt-mark unhold wpasupplicant
*/EDIT*
The fix involving adding the following entries into the wpa_supplicant.conf file DID NOT WORK for me.
tls_disable_tlsv1_0=1
tls_disable_tlsv1_1=1
openssl_ciphers=DEFAULT@SECLEVEL=2
bschermerhorn
Tue Jul 16, 2019 8:13 pm
Thank you so much for posting this. I understood that I needed to downgrade 'wpasupplicant', but I'm too much of a linux newbie to know how to do that. This was very helpful.
alexzace
Wed Jul 17, 2019 2:31 am
Hi ,@bschermerhorn
1)
sudo apt-get remove wpasupplicant
( to remove current wpasupplicant)
2) u could edit the /etc/apt/sources.list
from
deb http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
to
deb http://raspbian.raspberrypi.org/raspbian/ stretch main contrib non-free rpi
3)
sudo apt-get update
( get the sources list from stretch)
and
Now you should have the wpa_supplicant with (v2.4).
you could check the version by issue 'wpa_supplicant -v'
4) After successful installed, please edit '/etc/apt/sources.list' back to
and
sudo apt-get update
(to change back buster sources list, as you only want downgrade wpasupplicant).
RobinGreig
Thu Sep 05, 2019 5:45 pm
Thanks @alexzace and everyone for your help with this!
Worked like a charm!
Robin
www.robingreig.ca
Arduino + Raspi + Amateur Radio enthusiast since 2012
VE6RBN Canadian Amateur Radio Callsign
GreatLeader_Technus
Fri Sep 06, 2019 5:58 am
Does SSH work on your Pi @Tavan? Your suggestion worked and my Pi connected to Eduroam, but I can't SSH into it.
GreatLeader_Technus
Wed Sep 11, 2019 10:02 pm
I think I need to get Stretch's SSH, how would I do that?
AgentRev
Sat Sep 28, 2019 9:47 pm
Had the same problem on my 3B+, I combined Tavan's and alexzace's answers into this script:
#!/bin/sh
# temporary fix for WPA Enterprise on Raspbian Buster, connect Ethernet before running
sudo apt-get remove wpasupplicant -y
sudo mv -f /etc/apt/sources.list /etc/apt/sources.list.bak
sudo bash -c "echo 'deb http://raspbian.raspberrypi.org/raspbian/ stretch main contrib non-free rpi' > /etc/apt/sources.list"
sudo apt-get update
sudo apt-get install wpasupplicant -y
sudo cp -f /etc/apt/sources.list.bak /etc/apt/sources.list
sudo apt-get update
benolayinka
Wed Nov 13, 2019 2:36 pm
I can confirm that using the Raspbian Stretch wpasupplicant fixed the issue for me as well. I was tearing my hair out trying to connect to eduroam. My symptoms were:
wpa_cli -i wlan status reported AUTHENTICATED
ping reported temporary dns lookup failure
and my wpa_supplicant, which was authenticating but not giving network access until I downgraded wpa_supplicant, looks like:
network = {
ssid = "eduroam"
scan_ssid=1
key_mgmt=WPA-EAP
eap=PEAP
identity="xxx@kth.se"
anonymous_identity="xxx@kth.se"
password="xxx"
ca_cert="/home/pi/cert/cert.pem" #this I had to copy from a python script at https://cat.eduroam.org/
gcans
Wed Nov 13, 2019 4:00 pm
This did the trick for me too!
Gcans
jfalzon
Fri Mar 20, 2020 11:57 am
Hi!
I am having very similar issues. My problem is that I know that an external interface with my wpa_supplicant file works and it manages to connect to my EAP 8021x wlan network.
However I am trying to connect using the internal wifi chip of my Raspberry PI 4 that is running Buster (4.19.97-v7l+).
One oddity is that the raspberry pi can connect (with the adapter) directly after a reboot but never using the wpa_supplicant command even when run in the background.
Have tried rolling back the version of wpa_supplicant from 2.7 to 2.4 and made modifications for wpa_supplicant to use wext by default, but nothing has worked.
siddhartha91
Wed Jul 01, 2020 7:12 pm
Same here as for jfalzon.
I'm running:
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l GNU/Linux
and is not working. It seems to connect to the network but no internet is available. Cannot ping anywhere. Actually, I already managed to connect without having to downgrade wpa_supplicant...
This is being now a nightmare. Hope someone came up with a solution for this.
Best guys!
erikosterholm
Sun Aug 16, 2020 3:33 pm
I'm running:
Best guys!
I got mine working by doing the following:
Created /etc/system/systemd/wpa_supplicant@.service:
[Service]
ExecStart=
ExecStart=/sbin/wpa_supplicant -c/etc/wpa_supplicant/wpa_supplicant-%I.conf -i%I -Dwext
Created /etc/wpa_supplicant/wpa_supplicant-wlan0.conf with my SSID settings, etc.
Ran the following:
 systemctl daemon-reload
systemctl disable --now wpa_supplicant
systemctl enable --now wpa_supplicant@wlan0
May version of raspbian-lite.
Tranks27
Sat Oct 03, 2020 11:33 am
Hi ,@bschermerhorn
1)
from
to
3)
sudo apt-get update
and
and
sudo apt-get update
You guys saved the day! Thanks a lot
Return to “Raspberry Pi OS”
