TRyan
Rapberry Pi4 custom Display Problem
Thu Jul 04, 2019 9:19 am
in the past (Raspberry Pi 2B, 3B, 3B+) I used a custom Display with a resolution of 480x640.
To use the display I used this config in the config.txt.
hdmi_ignore_edid=0xa5000080
hdmi_group=2
hdmi_mode=87
hdmi_cvt=464 618 65 1 1 0 0
hdmi_drive=1
dtoverlay=vc4-fkms-v3d
I tried this configuration with the Raspberry pi 4, but the display shows nothing.
When I use: hdmi_safe=1 the Display is showing something but the resolution is wrong.
Did the configuration from the display change by the Rasoberry Pi4?
Greetings
Tobias
Re: Rapberry Pi4 custom Display Problem
Thu Jul 04, 2019 9:30 am
I think you need to remove this line from config.txt
The VC4 fkms is replaced by v3d-fkms-v3d on the Pi4. Which should be there already in the [pi4] section.
TRyan
Thu Jul 04, 2019 9:41 am
Hi Jamesh,
thanks for your quick replay.
I removed the line from the config.txt.
But still the same. When I use the same SD-Card in a Raspberry 3B+ the Display works.
Thanks for your help
Greetings
Thu Jul 04, 2019 9:59 am
Ensure you are using HDMI 0, or make the same config.txt entries available on HDMI1
e.g.
hdmi_group:0=2
hdmi_group:1=2
TRyan
Thu Jul 04, 2019 10:31 am
Hi Jamesh,
thanks for your replay.
I change the config to:
hdmi_ignore_edid:0=0xa5000080
hdmi_group:0=2
hdmi_mode:0=87
hdmi_cvt:0=464 618 65 1 1 0 0
hdmi_drive:0=1
But no difference.
When I at hdmi_safe:0=1, the Display show the console, but die resolution is wrong and the display ist not fillied
Greetings Tobias
TRyan
Thu Jul 04, 2019 11:16 am
it seems that the command hdmi_cvt maks the problem.
I use now:
hdmi_timings
and it works.
Now I must find out the right timmings for my display.
Thanks for your help.
Greetings Tobias
