Brooklyn
Raspberry PI with arduino = TCP/IP
Tue Jul 02, 2019 1:14 pm
Can I create a chat server on the Rpi and create a chat client on the Arduino and let it communicate with each other over my local network?
Can I create a chat server on the Rpi and create a chat client on the Arduino and let it communicate with each other over my local network. Can this work with a chatserver -> chatclient?
Over tcp/ip?
Or is udp better?
HermannSW
Re: Raspberry PI with arduino = TCP/IP
Tue Jul 02, 2019 3:25 pm
> on the Rpi
You don't state which Rpi, in case of Pi0 you need to add network connectivity either by USB OTG or enc28j60 network module:
https://www.raspberrypi.org/forums/view ... 0#p1015300
You don't state which arduino, you can add network connectivity to AVR based Arduinos with enc28cj60 module as well:
https://github.com/njh/EtherCard
https://twitter.com/HermannSW/status/711237172523720704
> Or is udp better?
while it does not make a big difference to loose some packets when streaming video, I doub't that you would want unnoticed lost packets (messages) for a chat client. So for chat definitely TCP is needed.
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://github.com/Hermann-SW/fork-raspiraw
Brooklyn
Wed Jul 03, 2019 2:27 pm
It's a Raspberry Pi Model 3B +
and
I have now a arduino mega with a esp module inbuilt but maybe i will buy a arduino uno wifi.
ankith26
Thu Jul 04, 2019 2:31 pm
If you plan to interface arduino and raspi, use serial protocol with usb cable connecting them... This is the easiest way to have any sort of chat or communication
I had many troubles using esp8266 module(I fried 3 modules as i did not know how to handle the thing)
My website is at https://pratt.ml
Hope it runs (which it wont)
Brooklyn
Thu Jul 04, 2019 5:53 pm
Is it easier to communicatie two rpi in a network?
because my raspberry pi is a server that stands in my garage and the arduino or maybe a other rpi that stand in my bedroom.
ankith26
Fri Jul 05, 2019 2:56 pm
A Pi to Pi connection would be easier according to me..
On arduino-raspi connection through lan, idk much
Brooklyn
Fri Jul 05, 2019 4:36 pm
Is that also tcp/ip protocol
ankith26
Sat Jul 06, 2019 8:43 am
Yup.. Through sockets that is...
I found this youtube video that shall suite your purpose
https://www.youtube.com/watch?v=l0p-NvmoeUA
