gordon77
RPI.GPIO and Pi4 issue ?
Tue Jul 02, 2019 8:19 am
I can't pull-up all the inputs, and it errors above pin 26...what's wrong ?
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BOARD)
GPIO.setwarnings(False)
pins = (3,5,7,8,10,11,12,13,15,16,18,19,21,22,23,24,26,29,31,32,33,35,36,37,38,40)
for pin in range (0,26):
    GPIO.setup(pins[pin], GPIO.IN, pull_up_down=GPIO.PUD_UP)
    print ('pin: '+ str(pins[pin]), GPIO.input(pins[pin]))
gives..
pin: 3 1
pin: 5 1
pin: 7 1
pin: 8 1
pin: 10 1
pin: 11 0
pin: 12 0
pin: 13 0
pin: 15 0
pin: 16 0
pin: 18 0
pin: 19 0
pin: 21 0
pin: 22 0
pin: 23 0
pin: 24 1
pin: 26 1
  File "/home/pi/pins1.py", line 8, in <module>
ValueError: The channel sent is invalid on a Raspberry Pi
works on a Pi3B
pin: 3 1
pin: 5 1
pin: 7 1
pin: 8 1
pin: 10 1
pin: 11 1
pin: 12 1
pin: 13 1
pin: 15 1
pin: 16 1
pin: 18 1
pin: 19 1
pin: 21 1
pin: 22 1
pin: 23 1
pin: 24 1
pin: 26 1
pin: 29 1
pin: 31 1
pin: 32 1
pin: 33 1
pin: 35 1
pin: 36 1
pin: 37 1
pin: 38 1
pin: 40 1
croston
Re: RPI.GPIO and Pi4 issue ?
Tue Jul 02, 2019 8:25 am
I am the maintainer and am working on this.
gordon77
Tue Jul 02, 2019 9:19 am
gordon77
Thu Jul 04, 2019 8:44 am
Any news on the fix ?
croston
Thu Jul 04, 2019 6:56 pm
I'm looking at a fix being available on Sunday.
gordon77
Thu Jul 04, 2019 7:03 pm
Thanks for the info.
croston
Mon Jul 08, 2019 5:13 pm
You can now install the alpha release (for testing purposes):
$ pip3 install --upgrade --pre rpi.gpio
Let me know if it works or not.
gordon77
Mon Jul 08, 2019 6:44 pm
Thanks, That seems to work fine.
jinksto
Sat Jul 13, 2019 12:21 am
This resolved my problem with RPi.GPIO as well.
https://www.raspberrypi.org/forums/view ... 7#p1498777
InnoHub
Mon Aug 26, 2019 5:48 am
Facing problems with GPIO on Pi 4.
Tried the update provided by @croston. But the pip3 install --upgrade --pre rpi.gpio command said that the rpi.gpio is already the latest version and did not upgrade anything.
Are there any further updates or steps to be followed? Have been struggling with this issue for the past couple of days.
Any help would be appreciated.
mattmiller
Mon Aug 26, 2019 10:33 am
Hi and welcome to the forum :)
Unless your problem's identical to this one - best idea is to start your own thread and explain what problem your having
croston
Mon Aug 26, 2019 11:25 pm
This fix is now in Raspbian Buster if you run an update:
sudo apt update && sudo apt full-upgrade
InnoHub
Tue Aug 27, 2019 8:09 am
Thank you!!
I thought the issues I am facing are related to this thread.
As suggested I will start a new thread anyway!
InnoHub
Tue Aug 27, 2019 8:13 am
Thanks for the suggestion.
It did not solve the issue though.
My program works perfectly on Pi 3B+ but not on Pi4 :(
pcmanbob
Tue Aug 27, 2019 8:30 am
Seeing as you have not actually told us what the problem is I don't see what more help we can offer,
we can only provide help based on the information you provide.
