Cr4z33
Raspberry Pi 4 stuck at max. 1024x768
Tue Jul 02, 2019 7:21 am
I was able to run my brand new Pi succesfully at 4K the first time that I ran Buster.
From that moment on no matter if I reflashed (twice) the SD, if I change HDMI port or if I change HDMI cable the Pi does not go any higher than 1024x768... :?
I am using a OKdo 5,1V 3A power supply by the way.
Do I have to start thinking I got a faulty unit? :x
topguy
Re: Raspberry Pi 4 stuck at max. 1024x768
Tue Jul 02, 2019 9:00 am
You should tell us what kind of screen you are using... Its the screen and Pi who usually agrees what is the best resolution.
Cr4z33
Tue Jul 02, 2019 9:19 am
It's a Samsung Q7F (year 2017) 55" LED TV.
Cr4z33
Tue Jul 02, 2019 11:22 am
I suspect it's because I am using a cheap HDMI adapter.
Ordered a micro HDMI to HDMI cable so let's see what comes up with it...
Tue Jul 02, 2019 12:08 pm
Ensure you are using HDMI0 (nearest the USB power connector)
Cr4z33
Tue Jul 02, 2019 1:34 pm
Thanks I tried with both ports, but I suspect it might depend on the micro HDMI to HDMI adapter. 😅
I will post again as soon as I try the just ordered micro HDMI to HDMI cable.
Cr4z33
Wed Jul 03, 2019 10:16 am
Tip of the day :
DO NOT BUY MICRO HDMI TO HDMI ADAPTERS . IT'S CRAP !!
A straight cable (bought on Amazon for the same price btw) connection sorted the issue ! :oops:
Wed Jul 03, 2019 10:48 am
Tip of the day :
https://www.raspberrypi.org/products/mi ... i-a-cable/
Retired disgracefully.....
