shaywood
How to enable eth0 and wlan0
Sun Dec 02, 2012 2:53 am
Hello. I'm a newbie! I initially setup Rpi using a network cable. I then added a wireless N usb adapter, which works fine. I would like to be able to go back-and-forth between the cable and usb adapter as needed. I noticed when I switch between cable and adapter the cable no longer works. How can I choose which one to use?
Shawn
pigeta
Re: How to enable eth0 and wlan0
Sun Dec 02, 2012 9:15 am
try to intall wicd
redhawk
Sun Dec 02, 2012 10:46 am
try:
ifdown wlan0
ifup eth0
Richard S.
shaywood
Sun Dec 02, 2012 3:35 pm
Richard, where do i enter those commands?
cl330b
Sun Dec 02, 2012 10:48 pm
Hi Shaywood,
The commands are entered at the command prompt (LXTerminal most likely).
cl330b@raspberrypi ~ $ sudo ifdown wlan0
cl330b@raspberrypi ~ $ sudo ifup eth0
shaywood
Thu Dec 06, 2012 5:58 pm
Thanks for the reply. Is there a way to set things up to check for lan vs wan automatically when booting. It looks like the commands you provided must be entered manually.
