Montala
How to play sounds from web sites on Raspberry Pi 4 ? (Solved)
Fri Jun 28, 2019 9:08 pm
I have purchased a 2GB Raspberry Pi 4, which I am basically using as a small PC, with an HDMI monitor and keyboard connected and with a small speaker connected to the headphone jack.
This plays a simple WAV file OK (using omxplayer) but what I would like to do is to be able to hear the sounds from webpages, such as 'YouTube' for example when using Chromium, which I assume is possible.
I am running the latst version of Debian 'Buster' but there is presumably something else which has to be done before I can hear any sounds.
My Raspberry and Linux 'skills' are more than a little rusty, I'm afraid, so please keep any replies simple!
Thanks! :)
topguy
Re: How tp play sounds from web sites on Raspberry Pi 4 ?
Fri Jun 28, 2019 10:06 pm
Using "raspi-config" I think you can set the jack connector to be the preferred output. Maybe that fixes it, I dont know if there are changes in Raspbian Buster regarding this.
Montala
Re: How to play sounds from web sites on Raspberry Pi 4 ? (Solved)
Sat Jun 29, 2019 9:15 pm
Thanks for your reply and for the tip.
That of course is one way to do it, and apparently there are others also... as I found out at: https://www.raspberrypi.org/documentati ... -config.md
Anyway, all is well now thanks, so I have marked the problem as "Solved".
LTolledo
Re: How tp play sounds from web sites on Raspberry Pi 4 ? (Solved)
Sat Jun 29, 2019 9:33 pm
Please mark your first post (not the last post) as Solved....
this way its properly reflected on the board...
Some people be like:
Montala
Sat Jun 29, 2019 10:36 pm
Sorry... hope it's OK now!
