Dygear
Raspberry Pi 4 USB Power Issues? RTL-SDRs
Fri Jun 28, 2019 5:55 pm
When trying to use an RTL SDR I'm getting the following error rtlsdr_write_reg failed with -7. -7 according to it’s value within libusb_error enum is LIBUSB_ERROR_TIMEOUT. I’ve been told that -6 (LIBUSB_ERROR_BUSY) is due to a lack of power on the USB Bus, perhaps that’s the same problem here? But that seems very unlikely given that this Pi is meant to have a lot more power delivery capability towards the USB ports. I’ve had it plugged into the USB 3.0 ports and the USB 2.0 ports both resulting in the same error. I’m also using the official Raspberry Pi 4 USB-C power adaptor, so it should be able to fully power the unit, regardless of load CPU load state of USB peripheral count. But to be sure, I removed everything but the RTL and then SSH’d into the Pi4B. Still no luck.
As a sanity check, I plugged the dongles that didn’t work on the rPi4B into a rPi3B+, both are running up to date versions of Raspbian Buster as of about 1 hour prior to this post. I went though the install test from Raspberry Pi Stretch Install process that I wrote for the trunk_recorder wiki. Installed all dependencies and compiled all of the software from the last master versions on their official public git repositories. And … It works completely fine on the rPi3B+, but not the rPi4B. I’m at a loss as to what to do next? A powered USB Hub, I guess. At least I can rule that out …
Anyone have have other ideas that I haven't presented?
jdb
Re: Raspberry Pi 4 USB Power Issues? RTL-SDRs
Fri Jun 28, 2019 7:22 pm
We've seen this during testing. The set of commands sent to the device to put it into raw streaming mode sometimes stalls and for some reason the host controller doesn't respond with the correct endpoint state to the host driver; or there's a race between the command submission and completions returned by the driver.
Oddly, you can get it to work about 25% of the time - which implies a software race rather than hardware bugginess.
Rockets are loud.
https://astro-pi.org
Dygear
Fri Jun 28, 2019 7:36 pm
That rules out the rPi4B as a software defined radio then, at least until the software is fixed. I'm using it to capture emergency traffic for most of the ambulance corps in the county that I live and giving them access to the audio feed to better respond to emergency assignments. Good thing the rPi3B+ is going to be around for at least another 4 years.
wren
Fri Jun 28, 2019 7:40 pm
I noticed this too while trying to get GQRX up and running. I was gonna try my Elonics 4000 and no USB extension today, but I guess you've ruled that out.
I have a Pi 4 with 4GB RAM and the R820T2 tuner plugged into USB3 port. Keyboard and mouse were the only other things plugged in.
Dygear
Fri Jun 28, 2019 7:46 pm
I'm using the NESDR Nano 3 plugged directly into the USB3 port on the rPi4B-2GB. Works perfect on the rPi3B+ with the same software stack (rPi3B+ Buster vs rPi4B Buster). So if there is a software problem, it's specific to the rPi4B's implementation of that code path.
wren
Fri Jun 28, 2019 7:50 pm
I will try my USRP at some point to see if it works, but I'm not very hopeful. Hopefully this can be fixed soon.
jbeale
Fri Jun 28, 2019 8:22 pm
If there's a software race condition, consider the fact that 1) the Pi4 ARM cores are faster and 2) the USB hardware itself is different and I presume, more efficient and faster due to not having the relatively large interrupt overhead that the USB2 subsystem in the Pi3 and all earlier models did. Could it be that the Pi4 is able to send and respond to USB setup data *too fast* and the RTL-SDR gets locked up when a command comes before it's ready to act on it?
Just my uninformed speculation- if the same RTL-SDR unit works fine with other, faster machines than the Pi4, then this probably isn't it.
Dygear
Fri Jun 28, 2019 10:19 pm
Good point. I have a HackRF laying around. So I used that and it works just fine. AND IT'S FREAKING FAST! Well ... The first time it was. Haven't been able to get it to work a next time.
Feek
Sun Jun 30, 2019 7:03 am
I'm pretty sure it's not a power issue. I've had a USB power meter in line with the RTL-SDR while trying to make this work with little success and the voltage has never dropped below a fraction under 5.1 volts. This is using an official RPi PSU.
I've used four different RTL-SDR dongles and out of at least fifty different attempts, have had a partial success (ie it was recognised by rtl_test) just once so it's not quite a 25% success rate. When I ran the test a second time, it failed.
Same symptoms as originally posted in this thread.
It works perfectly well on a Pi3B with Buster, it's just the Pi4 that doesn't work.
wren
Sun Jun 30, 2019 9:22 pm
I have no idea why, at this point, but the Terratec T Stick PLUS Elonics E4000 tuner seems to work every time I've tested it. Rafael Micro R820T2 has issues, which must still be Pi4 related because it works fine on my Pi3 and PC.
Dygear
Sun Jun 30, 2019 10:30 pm
It's super odd that the E4000 would work fine every time. What about your USRP, how did that work on the 4? Given that I'm still having trouble with the HackRF working (Although, it did work for me ... once.) given that it happens more often on the Pi4 side than Pi3 side, I still think we need a software patch from the Foundation.
wren
Mon Jul 01, 2019 12:31 am
It works on my B100, but I have to back it off to 500ksps input to keep the audio smooth. It chokes on GQRX at 8Msps. I'll have to try 16Msps in GNURadio Companion as GQRX doesn't support 8bit samples.
jdb
Wed Jul 10, 2019 3:47 pm
https://github.com/raspberrypi/linux/is ... -510107304
The bug has been identified - the VLI chip is doing a bad thing. Dunno how to go about fixing it yet - I need to better understand the mechanisms used in the driver before I can make an informed change to cope with the hardware brokenness.
Rockets are loud.
leshniak
Thu Jul 11, 2019 6:47 pm
I've just compiled a new kernel from this pull request https://github.com/raspberrypi/linux/pull/3066 . No issues on tvheadend so far. I hope this fix will be merged into the next kernel release.
Dygear
Tue Jul 23, 2019 3:14 am
I just did a firmware upgrade on my rPi4/4GB and now rtl_test works flawlessly. Excellent job!
Wow, I can even capture at 3.2Msps with GQRX and the 8192 @ 30fps waterfall. Doesn't get too hot while doing that too in an open case with an ambient temperature of 17C. CPU load is up at 70% but the system with the full GUI interface is still VERY useable.
MACH1SCJ
Sun Jul 28, 2019 7:25 am
The firmware seemed to help but I am still getting some USB error codes with RTL-SDR.
I thought it was related to https://github.com/raspberrypi/linux/issues/3060 .. -510107304 with a fix here https://github.com/raspberrypi/linux/pull/3066
dmesg
reports the following errors
3.442204]usb 1-1.2.4: device descriptor read/64, error -32]   (this error is reported 4 times)
 .......... brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio f or chip BCM4345/6  (this error is reported twice)
........... brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
 5.431771] usb 1-1.2.4: device not accepting address 11, error -71
5.971798] usb 1-1.2.4: device not accepting address 12, error -71
 5.974424] usb 1-1.2-port4: unable to enumerate USB device
Pi Model 4B V1.1
Raspberry Pi reference 2019-07-10
buster V. 10
Linux version 4.19.59-v7l+ ([email protected]) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1246 SMP Tue Jul 23 19:25:04 BST 2019
update 7-28-19
rtl_test
will run once with a few lost bytes.
Ctrlz
to exit.
Allocating 15 zero-copy buffers
lost at least 108 bytes
^Z
[3]+ Stopped rtl_test
 $ ps
PID TTY TIME CMD
3944 pts/0 00:00:00 bash
4367 pts/0 00:00:00 rtl_test
5037 pts/0 00:00:00 ps
looks like it is still running rtl_test ??????
from task manager "kill"
$ ps
PID TTY TIME CMD
5060 pts/0 00:00:00 ps
[1]- Killed rtl_test
$ rtl_test
Found 1 device(s):
0: Realtek, RTL2838UHIDIR, SN: 00000001
Using device 0: Generic RTL2832U OEM
Found Rafael Micro R820T tuner
Supported gain values (29): 0.0 0.9 1.4 2.7 3.7 7.7 8.7 12.5 14.4 15.7 16.6 19.7 20.7 22.9 25.4 28.0 29.7 32.8 33.8 36.4 37.2 38.6 40.2 42.1 43.4 43.9 44.5 48.0 49.6
[R82XX] PLL not locked!
Sampling at 2048000 S/s.
Info: This tool will continuously read from the device, and report if
samples get lost. If you observe no further output, everything is fine.
Reading samples in async mode...
lost at least 160 bytes
lost at least 294 bytes
lost at least 166 bytes
Ctrlc
User cancel, exiting...
Samples per million lost (minimum): 3
SNICKERDOODLES!! I guess thats it. Its nice to get lucky sometimes.
Ctrlz
only stops the run and does not unload where
Ctrlc
exits correctly.
perhaps this will help someone else?
I still might have error messages -----maybe its normal for what I have plugged in. Will test more & update
can't get device qualifier: Resource temporarily unavailable
can't get debug descriptor: Resource temporarily unavailable
lsusb -v https://pastebin.com/rDQggkze
Loose nut behind the wheel. Watch out!
