HypedKey
Re: How to setup Minecraft 1.12.2 on Pi3 or Pi4
Thu Feb 27, 2020 11:57 am
Hey mike, a minecraft fan here, I was wondering if there is a way to run minecraft 1.8.9 with forge and optifine installed? I am attempting to see if my FPS mod can help the Pi4 4GB model run with 50-60 FPS in average, but to do that I would need forge 1.8.9 to run, thanks a lot.
A RaspberryPi 4GB user that runs minecraft Java edition on it, with needs of money to buy an actual PC to let the raspberry pi host a mi extant server so I can get $$$$
HypedKey
Fri Feb 28, 2020 3:57 pm
By the way, is there any way to optimise all the CPU power on the raspberry pi to squeeze every FPS possible out of it? I’m just curious
timof121
Wed Mar 11, 2020 8:05 pm
Hello. Now that i'm on a RPi 4 with 4GB RAM everything works very good. Thanks!
Do you have any idea about running minecraft custom clients (that are placed in versions, not mods) like Wolfram
CactiChameleon9
Sun Mar 22, 2020 1:09 pm
Hello, I'm having issues with frame-rate and Fake KMS. I'm running a rpi4 4GB and I have followed all of your instructions, Minecraft crashes, but it does work if I have "G1 Legacy" on. The only issue with this is the massive lag, and when comparing to your video I noticed that your Minecraft runs a lot better. Near the beginning of your video, you state that rpi4s have Fake KMS on by default, so I assume that me having to turn it off is the big difference, yet if reactivate it it crashes. I am using the latest version of desktop Raspbian (32bit).
Could you please help me debug/fix this... :D
Many thanks,
CactiChameleon9
With G1 Legacy i'm getting getting 4/3 fps at best :shock: on a normal world with everything down and fast maths on etc.
With Fake KMS I get the error:
./runMC1_12_2_OptifineF4.sh
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   738  100   553  100   185   1855    620 --:--:-- --:--:-- --:--:--  2484
todays access token = eyJhbGciOiJIUzI1NiJ9.eyJzdWIiOiIwY2IxMmI2MDRlOTBkNGFkNTI3ZGFlNjM2Mjc0YzU1NiIsInlnZ3QiOiJkZWZlOWFlMTE1ZWY0N2M2YTA3MTcwNzQzMzYyNmRiMCIsInNwciI6Ijg3NTk2NjZjMjgwMjQxMTFiOTZlMmEzNDAwZmQ0NzU3IiwiaXNzIjoiWWdnZHJhc2lsLUF1dGgiLCJleHAiOjE1ODUwNzgxOTgsImlhdCI6MTU4NDkwNTM5OH0.oKvRRemfVircwwSyPmI_KHq-o8huzljbNT9ARLcMaYQ
100    85  100    68  100    17    338     84 --:--:-- --:--:-- --:--:--   422
MINECRAFT_UUID=8759666c28024111b96e2a3400fd4757
Java HotSpot(TM) Server VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
[19:30:04] [main/INFO]: Loading tweak class name optifine.OptiFineTweaker
[19:30:04] [main/INFO]: Using primary tweak class name optifine.OptiFineTweaker
[19:30:04] [main/INFO]: Calling tweak class optifine.OptiFineTweaker
OptiFineTweaker: acceptOptions
OptiFineTweaker: injectIntoClassLoader
OptiFine ClassTransformer
OptiFine ZIP file: /home/pi/.minecraft/libraries/optifine/OptiFine/1.12.2_HD_U_F4/OptiFine-1.12.2_HD_U_F4.jar
OptiFineTweaker: getLaunchArguments
OptiFineTweaker: getLaunchTarget
[19:30:05] [main/INFO]: Launching wrapped minecraft {net.minecraft.client.main.Main}
[19:30:07] [main/INFO]: Setting user: CactiChameleon9
[19:30:17] [main/INFO]: [OptiFine] *** Reflector Forge ***
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: mods.betterfoliage.client.BetterFoliageClient
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.event.world.ChunkWatchEvent$UnWatch
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.relauncher.CoreModManager
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.common.DimensionManager
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.GuiScreenEvent$DrawScreenEvent$Pre
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.GuiScreenEvent$DrawScreenEvent$Post
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.EntityViewRenderEvent$CameraSetup
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.EntityViewRenderEvent$FogColors
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.EntityViewRenderEvent$RenderFogEvent
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.common.eventhandler.Event
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.common.eventhandler.EventBus
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.common.eventhandler.Event$Result
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.common.property.ExtendedBlockState
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.client.FMLClientHandler
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.common.FMLCommonHandler
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: bhv.getCameraPosition
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: bhv.updateRenderInfo
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: anh.getWaterColorMultiplier
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: anh$c.newInstance
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.addDestroyEffects
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.addHitEffects
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.canCreatureSpawn
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.canRenderInLayer
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.doesSideBlockRendering
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.doesSideBlockChestOpening
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.getBedDirection
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.getExtendedState
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.getFogColor
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.getLightOpacity
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.getLightValue
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.getSoundType
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.hasTileEntity
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.isAir
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.isBed
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.isBedFoot
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.isSideSolid
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: cfy.isAmbientOcclusion
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: aws.getLightValue
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: and.isSideSolid
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: vg.canRiderInteract
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Field not present: vg.captureDrops
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Field not present: vg.capturedDrops
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: vg.shouldRenderInPass
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: vg.shouldRiderSit
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.event.ForgeEventFactory
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.common.ForgeHooks
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.ForgeHooksClient
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Field not present: ain.delegate
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: ain.getDurabilityForDisplay
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: ain.getEquipmentSlot
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: ain.getTileEntityItemStackRenderer
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: ain.getRGBDurabilityForDisplay
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: ain.isShield
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: ain.onEntitySwing
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: ain.shouldCauseReequipAnimation
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: ain.showDurabilityBar
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: agv.hasOverlay
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: bhy.setKeyConflictContext
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: bhy.setKeyModifierAndCode
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: bhy.getKeyModifier
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.common.ForgeModContainer
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: bvv.parseFromReader
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: uz.shouldRenderHUD
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: uz.renderHUDEffect
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: va.isCurativeItem
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: avj.canRenderBreaking
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: avj.getRenderBoundingBox
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: avj.hasFastRenderer
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: avj.shouldRenderInPass
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: ceb$b.preDraw
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: ceb$b.postDraw
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: amu.countEntities
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: amu.getPerWorldStorage
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: amu.initCapabilities
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: aym.getCloudRenderer
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: aym.getSkyRenderer
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: aym.getWeatherRenderer
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: aym.getLightmapColors
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Method not present: aym.getSaveFolder
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.client.GuiModList
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.common.property.IExtendedBlockState
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.registries.IForgeRegistryEntry$Impl
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.model.IModel
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.IRenderHandler
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.ItemModelMesherForge
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.settings.KeyConflictContext
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.settings.KeyModifier
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.model.pipeline.LightUtil
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.common.Loader
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.common.MinecraftForge
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.MinecraftForgeClient
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.common.ModContainer
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.model.ModelLoader
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.gui.NotificationModUpdateScreen
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.RenderBlockOverlayEvent$OverlayType
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.client.registry.RenderingRegistry
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.RenderItemInFrameEvent
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.RenderLivingEvent$Pre
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.RenderLivingEvent$Post
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.RenderLivingEvent$Specials$Pre
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.RenderLivingEvent$Specials$Post
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.ScreenshotEvent
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.client.SplashProgress
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.resource.VanillaResourceType
[19:30:17] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.event.world.WorldEvent$Load
[19:30:17] [main/INFO]: [OptiFine] *** Reflector Vanilla ***
---- Minecraft Crash Report ----
// There are four lights!
Time: 3/22/20 7:30 PM
Description: Initializing game
java.lang.ExceptionInInitializerError
	at Config.getDisplayModes(Config.java:1859)
	at bid$a.<clinit>(GameSettings.java:3596)
	at bid.<init>(GameSettings.java:332)
	at bib.aq(SourceFile:443)
	at bib.a(SourceFile:404)
	at net.minecraft.client.main.Main.main(SourceFile:123)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:498)
	at net.minecraft.launchwrapper.Launch.launch(Launch.java:159)
	at net.minecraft.launchwrapper.Launch.main(Launch.java:30)
Caused by: java.lang.RuntimeException: org.lwjgl.LWJGLException: No modes available
	at org.lwjgl.opengl.Display.<clinit>(Display.java:141)
	... 12 more
Caused by: org.lwjgl.LWJGLException: No modes available
	at org.lwjgl.opengl.LinuxDisplay.init(LinuxDisplay.java:740)
	at org.lwjgl.opengl.Display.<clinit>(Display.java:138)
	... 12 more
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Thread: Client thread
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
	Minecraft Version: 1.12.2
	Operating System: Linux (arm) version 4.19.97-v7l+
	Java Version: 1.8.0_211, Oracle Corporation
	Java VM Version: Java HotSpot(TM) Server VM (mixed mode), Oracle Corporation
	Memory: 556505240 bytes (530 MB) / 970588160 bytes (925 MB) up to 2040135680 bytes (1945 MB)
	JVM Flags: 5 total; -Xmn1G -Xmx2G -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy
	IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
	Launched Version: 1.12
	LWJGL: 2.9.4
	OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
	GL Caps:
	Using VBOs: ~~ERROR~~ NullPointerException: null
	Is Modded: Very likely; Jar signature invalidated
	Type: Client (map_client.txt)
	Resource Packs: ~~ERROR~~ NullPointerException: null
	Current Language: ~~ERROR~~ NullPointerException: null
	Profiler Position: N/A (disabled)
	CPU: <unknown>
	OptiFine Version: OptiFine_1.12.2_HD_U_F4
	OptiFine Build: 20191023-234904
	Shaders: null
	OpenGlVersion: null
	OpenGlRenderer: null
	OpenGlVendor: null
	CpuCount: 0
#@[email protected]# Game crashed! Crash report saved to: #@[email protected]# /home/pi/.minecraft/crash-reports/crash-2020-03-22_19.30.19-client.txt
The file contains:
// Oops.
	... 12 more
	... 12 more
-- Head --
Stacktrace:
Details:
Stacktrace:
Details:
	LWJGL: 2.9.4
	GL Caps:
	CPU: <unknown>
	Shaders: null
	OpenGlVersion: null
	OpenGlVendor: null
	CpuCount: 0
SagarPrakash
Sun Mar 22, 2020 3:02 pm
Thankyou for the setup guide which I was looking for so long, really appreciate it.
rpiMike
Sun Mar 22, 2020 9:40 pm
Thanks, you're welcome.
rpiMike
Sun Mar 22, 2020 9:42 pm
Many thanks,
CactiChameleon9
	... 12 more
	... 12 more
-- Head --
Stacktrace:
Details:
Stacktrace:
Details:
	LWJGL: 2.9.4
	GL Caps:
	CPU: <unknown>
	Shaders: null
	OpenGlVersion: null
	OpenGlVendor: null
	CpuCount: 0
The file contains:
// Oops.
	... 12 more
	... 12 more
-- Head --
Stacktrace:
Details:
Stacktrace:
Details:
	LWJGL: 2.9.4
	GL Caps:
	CPU: <unknown>
	Shaders: null
	OpenGlVersion: null
	OpenGlVendor: null
	CpuCount: 0
I can see 'No modes available'. Are you connected to a screen? If so what resolution?
CactiChameleon9
Mon Mar 23, 2020 7:29 am
I am using a 7 inch HDMI touch screen (but just as a screen).
In my config.txt may have something to do with it then:
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
# Additional overlays and parameters are documented /boot/overlays/README
dtparam=audio=on
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
[all]
#addedmanually
max_usb_current=1
hdmi_group=2
hdmi_mode=87
hdmi_cvt 1024 600 60 6 0 0 0
display_rotate=2
Therefore I can tell that my screen is at the resolution of 1024x600...
rpiMike
Mon Mar 23, 2020 7:40 am
Have you got a normal monitor or tv you can try. It’s probably the non standard screen size causing problems.
CactiChameleon9
Mon Mar 23, 2020 9:13 am
I'll try with a TV in a bit and get back too you.
I may also try playing around with the extra stuff I added on to the config.txt if the TV works.
Thanks :D
Edit: It works with a TV!!!! (after commenting out all the touch screen stuff)
Now i just have to find what is breaking it for the touch screen
Edit 2:
Now working fine with the touch screen...
I commented out
hdmi_group=2
hdmi_mode=87
So they became:
#hdmi_group=2
#hdmi_mode=87
#hdmi_cvt 1024 600 60 6 0 0 0
It means that everything is small though, yet this is a small price to pay for minecraft.
Thanks again,
CactiChameleon9
Salawat
Mon Mar 30, 2020 1:07 am
CactiChameleon9 , I noticed this:
LWJGL: 2.9.4
In your system dump. The latest LWJGL libraries are 3.2.3
You may be working, but I think you may have missed a step somewhere.
icyfiremario
Wed Apr 01, 2020 7:22 pm
thx I don't like the pi version of Minecraft very much. Question, is there a way to set your skin through the terminal?
Honzualdo
Fri Apr 10, 2020 7:19 am
Can I connect to a server running outside my network from RPI 3b ??
rpiMike
Fri Apr 10, 2020 9:43 am
Yes
Honzualdo
Fri Apr 10, 2020 9:54 am
If i want to connect to the server it will write me:
failed to login access token cannot be null or empty
rpiMike
Fri Apr 10, 2020 10:03 am
Does a local game start ok on your Pi?
Is it a public MC server you are trying to connect to if so what is the address?
Honzualdo
Fri Apr 10, 2020 10:06 am
it is a local server, ip address is mc.survival-games.cz
rpiMike
Fri Apr 10, 2020 10:11 am
Does a singleplayer game work on your Pi?
Honzualdo
Fri Apr 10, 2020 10:14 am
sorry, it's a server from the internet and singleplayer works great.
Is the way to get the server up and running from the internet ??
rpiMike
Fri Apr 10, 2020 10:32 am
My Pi4 running MC1.12.2 connected to that server fine, as far as as asking to register on the server.
Honzualdo
Fri Apr 10, 2020 11:03 am
How to turn on minecraft from launcher or script??
rpiMike
Fri Apr 10, 2020 11:19 am
Step 10 shows you how to run Minecraft with the script?
Honzualdo
Fri Apr 10, 2020 12:32 pm
yes, but I don't know if I can connect to the server mc.survival-games.cz via Raspberry
writes to me: Failed to login : Access Token can not be null or empty. Do you think it could be repaired ??
Honzualdo
Sat Apr 11, 2020 11:42 am
You can connect to the server ??
rpiMike
Sat Apr 11, 2020 12:17 pm
Yes, sorry don’t know why you can’t.
Return to “Gaming”
