utamav
Re: No Docker for Raspbian Buster
Mon Sep 30, 2019 7:55 pm
I was able to successfully install docker on a Raspberry Pi 4 running Rasbian Buster but I am unable to install docker-compose.
Command to install Docker:
curl -sSL https://get.docker.com | sh
I have tried the pip install method but that does not work.
sudo pip install docker-compose
Error:
Collecting docker-compose
  Using cached https://files.pythonhosted.org/packages/dd/e6/1521d1dfd9c0da1d1863b18e592d91c3df222e55f258b9876fa1e59bc4b5/docker_compose-1.24.1-py2.py3-none-any.whl
Collecting PyYAML<4.3,>=3.10 (from docker-compose)
  Using cached https://files.pythonhosted.org/packages/9e/a3/1d13970c3f36777c583f136c136f804d70f500168edc1edea6daa7200769/PyYAML-3.13.tar.gz
Requirement already satisfied: six<2,>=1.3.0 in /usr/lib/python2.7/dist-packages (from docker-compose) (1.12.0)
Collecting backports.ssl-match-hostname>=3.5; python_version < "3.5" (from docker-compose)
  Using cached https://www.piwheels.org/simple/backports-ssl-match-hostname/backports.ssl_match_hostname-3.7.0.1-py2.py3-none-any.whl
Requirement already satisfied: ipaddress>=1.0.16; python_version < "3.3" in /usr/lib/python2.7/dist-packages (from docker-compose) (1.0.17)
Collecting requests!=2.11.0,!=2.12.2,!=2.18.0,<2.21,>=2.6.1 (from docker-compose)
  Using cached https://files.pythonhosted.org/packages/ff/17/5cbb026005115301a8fb2f9b0e3e8d32313142fe8b617070e7baad20554f/requests-2.20.1-py2.py3-none-any.whl
Collecting docker[ssh]<4.0,>=3.7.0 (from docker-compose)
  Using cached https://files.pythonhosted.org/packages/09/da/7cc7ecdcd01145e9924a8ccbe9c1baf3a362fc75d4cb150676eb5231ea60/docker-3.7.3-py2.py3-none-any.whl
Collecting jsonschema<3,>=2.5.1 (from docker-compose)
  Using cached https://files.pythonhosted.org/packages/77/de/47e35a97b2b05c2fadbec67d44cfcdcd09b8086951b331d82de90d2912da/jsonschema-2.6.0-py2.py3-none-any.whl
Collecting docopt<0.7,>=0.6.1 (from docker-compose)
  Using cached https://www.piwheels.org/simple/docopt/docopt-0.6.2-py2.py3-none-any.whl
Collecting cached-property<2,>=1.2.0 (from docker-compose)
  Using cached https://files.pythonhosted.org/packages/3b/86/85c1be2e8db9e13ef9a350aecd6dea292bd612fa288c2f40d035bb750ded/cached_property-1.5.1-py2.py3-none-any.whl
Collecting websocket-client<1.0,>=0.32.0 (from docker-compose)
  Using cached https://files.pythonhosted.org/packages/29/19/44753eab1fdb50770ac69605527e8859468f3c0fd7dc5a76dd9c4dbd7906/websocket_client-0.56.0-py2.py3-none-any.whl
Requirement already satisfied: enum34<2,>=1.0.4; python_version < "3.4" in /usr/lib/python2.7/dist-packages (from docker-compose) (1.1.6)
Collecting dockerpty<0.5,>=0.4.1 (from docker-compose)
  Using cached https://files.pythonhosted.org/packages/8d/ee/e9ecce4c32204a6738e0a5d5883d3413794d7498fe8b06f44becc028d3ba/dockerpty-0.4.1.tar.gz
Collecting texttable<0.10,>=0.9.0 (from docker-compose)
  Using cached https://files.pythonhosted.org/packages/02/e1/2565e6b842de7945af0555167d33acfc8a615584ef7abd30d1eae00a4d80/texttable-0.9.1.tar.gz
Collecting chardet<3.1.0,>=3.0.2 (from requests!=2.11.0,!=2.12.2,!=2.18.0,<2.21,>=2.6.1->docker-compose)
  Using cached https://files.pythonhosted.org/packages/bc/a9/01ffebfb562e4274b6487b4bb1ddec7ca55ec7510b22e4c51f14098443b8/chardet-3.0.4-py2.py3-none-any.whl
Collecting certifi>=2017.4.17 (from requests!=2.11.0,!=2.12.2,!=2.18.0,<2.21,>=2.6.1->docker-compose)
  Using cached https://files.pythonhosted.org/packages/18/b0/8146a4f8dd402f60744fa380bc73ca47303cccf8b9190fd16a827281eac2/certifi-2019.9.11-py2.py3-none-any.whl
Collecting urllib3<1.25,>=1.21.1 (from requests!=2.11.0,!=2.12.2,!=2.18.0,<2.21,>=2.6.1->docker-compose)
  Using cached https://files.pythonhosted.org/packages/01/11/525b02e4acc0c747de8b6ccdab376331597c569c42ea66ab0a1dbd36eca2/urllib3-1.24.3-py2.py3-none-any.whl
Collecting idna<2.8,>=2.5 (from requests!=2.11.0,!=2.12.2,!=2.18.0,<2.21,>=2.6.1->docker-compose)
  Using cached https://files.pythonhosted.org/packages/4b/2a/0276479a4b3caeb8a8c1af2f8e4355746a97fab05a372e4a2c6a6b876165/idna-2.7-py2.py3-none-any.whl
Collecting docker-pycreds>=0.4.0 (from docker[ssh]<4.0,>=3.7.0->docker-compose)
  Using cached https://files.pythonhosted.org/packages/f5/e8/f6bd1eee09314e7e6dee49cbe2c5e22314ccdb38db16c9fc72d2fa80d054/docker_pycreds-0.4.0-py2.py3-none-any.whl
Collecting paramiko>=2.4.2; extra == "ssh" (from docker[ssh]<4.0,>=3.7.0->docker-compose)
  Using cached https://files.pythonhosted.org/packages/4b/80/74dace9e48b0ef923633dfb5e48798f58a168e4734bca8ecfaf839ba051a/paramiko-2.6.0-py2.py3-none-any.whl
Collecting functools32; python_version == "2.7" (from jsonschema<3,>=2.5.1->docker-compose)
  Using cached https://files.pythonhosted.org/packages/c5/60/6ac26ad05857c601308d8fb9e87fa36d0ebf889423f47c3502ef034365db/functools32-3.2.3-2.tar.gz
Collecting bcrypt>=3.1.3 (from paramiko>=2.4.2; extra == "ssh"->docker[ssh]<4.0,>=3.7.0->docker-compose)
  Using cached https://files.pythonhosted.org/packages/fa/aa/025a3ab62469b5167bc397837c9ffc486c42a97ef12ceaa6699d8f5a5416/bcrypt-3.1.7.tar.gz
  Installing build dependencies ... error
  Complete output from command /usr/bin/python -m pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-AERBYd --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple --extra-index-url https://www.piwheels.org/simple -- setuptools>=40.8.0 wheel "cffi>=1.1; python_implementation != 'PyPy'":
  Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple, https://www.piwheels.org/simple
  Collecting setuptools>=40.8.0
    Using cached https://files.pythonhosted.org/packages/b2/86/095d2f7829badc207c893dd4ac767e871f6cd547145df797ea26baea4e2e/setuptools-41.2.0-py2.py3-none-any.whl
  Collecting wheel
    Using cached https://files.pythonhosted.org/packages/00/83/b4a77d044e78ad1a45610eb88f745be2fd2c6d658f9798a15e384b7d57c9/wheel-0.33.6-py2.py3-none-any.whl
  Collecting cffi>=1.1
    Using cached https://files.pythonhosted.org/packages/93/1a/ab8c62b5838722f29f3daffcc8d4bd61844aa9b5f437341cc890ceee483b/cffi-1.12.3.tar.gz
  Collecting pycparser (from cffi>=1.1)
    Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.19-py2.py3-none-any.whl
  Building wheels for collected packages: cffi
    Running setup.py bdist_wheel for cffi: started
    Running setup.py bdist_wheel for cffi: finished with status 'error'
    Complete output from command /usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-Ycp_BJ/cffi/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-mxnH4a --python-tag cp27:
    Package libffi was not found in the pkg-config search path.
    Perhaps you should add the directory containing `libffi.pc'
    to the PKG_CONFIG_PATH environment variable
    No package 'libffi' found
    running bdist_wheel
    running build
    running build_py
    creating build
    creating build/lib.linux-armv7l-2.7
    creating build/lib.linux-armv7l-2.7/cffi
    copying cffi/__init__.py -> build/lib.linux-armv7l-2.7/cffi
    copying cffi/cffi_opcode.py -> build/lib.linux-armv7l-2.7/cffi
    copying cffi/verifier.py -> build/lib.linux-armv7l-2.7/cffi
    copying cffi/vengine_cpy.py -> build/lib.linux-armv7l-2.7/cffi
    copying cffi/commontypes.py -> build/lib.linux-armv7l-2.7/cffi
    copying cffi/pkgconfig.py -> build/lib.linux-armv7l-2.7/cffi
    copying cffi/setuptools_ext.py -> build/lib.linux-armv7l-2.7/cffi
    copying cffi/recompiler.py -> build/lib.linux-armv7l-2.7/cffi
    copying cffi/lock.py -> build/lib.linux-armv7l-2.7/cffi
    copying cffi/cparser.py -> build/lib.linux-armv7l-2.7/cffi
    copying cffi/backend_ctypes.py -> build/lib.linux-armv7l-2.7/cffi
    copying cffi/vengine_gen.py -> build/lib.linux-armv7l-2.7/cffi
    copying cffi/model.py -> build/lib.linux-armv7l-2.7/cffi
    copying cffi/ffiplatform.py -> build/lib.linux-armv7l-2.7/cffi
    copying cffi/api.py -> build/lib.linux-armv7l-2.7/cffi
    copying cffi/error.py -> build/lib.linux-armv7l-2.7/cffi
    copying cffi/_cffi_include.h -> build/lib.linux-armv7l-2.7/cffi
    copying cffi/parse_c_type.h -> build/lib.linux-armv7l-2.7/cffi
    copying cffi/_embedding.h -> build/lib.linux-armv7l-2.7/cffi
    copying cffi/_cffi_errors.h -> build/lib.linux-armv7l-2.7/cffi
    running build_ext
    building '_cffi_backend' extension
    creating build/temp.linux-armv7l-2.7
    creating build/temp.linux-armv7l-2.7/c
    arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-9NJ3qw/python2.7-2.7.16=. -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/ffi -I/usr/include/libffi -I/usr/include/python2.7 -c c/_cffi_backend.c -o build/temp.linux-armv7l-2.7/c/_cffi_backend.o
    c/_cffi_backend.c:15:10: fatal error: ffi.h: No such file or directory
     #include <ffi.h>
    compilation terminated.
    error: command 'arm-linux-gnueabihf-gcc' failed with exit status 1
    Failed building wheel for cffi
    Running setup.py clean for cffi
  Failed to build cffi
  Installing collected packages: setuptools, wheel, pycparser, cffi
    Running setup.py install for cffi: started
      Running setup.py install for cffi: finished with status 'error'
      Complete output from command /usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-Ycp_BJ/cffi/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-_PaCnm/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-AERBYd --compile:
      running install
      running build
      running build_py
      creating build
      running build_ext
       #include <ffi.h>
  Command "/usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-Ycp_BJ/cffi/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-_PaCnm/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-AERBYd --compile" failed with error code 1 in /tmp/pip-install-Ycp_BJ/cffi/
Command "/usr/bin/python -m pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-AERBYd --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple --extra-index-url https://www.piwheels.org/simple -- setuptools>=40.8.0 wheel "cffi>=1.1; python_implementation != 'PyPy'"" failed with error code 1 in None
Has anyone successfully installed docker-compose on Raspberry Pi 4 running Buster?
DirkS
Mon Sep 30, 2019 8:25 pm
Yes, using pip3:
sudo pip3 install docker-compose
utamav
Mon Sep 30, 2019 9:49 pm
Yes, using pip3:
Thanks, that solved it for me.
mspohr
Fri Oct 11, 2019 5:18 pm
Does not work for me:
[email protected]:~ $ sudo pip3 install docker-compose
sudo: pip3: command not found
[email protected]:~ $ sudo apt-get install pip3
Reading package lists... Done
Building dependency tree
E: Unable to locate package pip3
How do I install docker-compose?
DirkS
Fri Oct 11, 2019 5:22 pm
Download pip3 first
sudo apt update
sudo apt install python3-pip
topguy
Sat Oct 12, 2019 10:24 am
     #include <ffi.h>
A more general tip, if you have errors like these, it usually means your are missing some "xxx-dev" package.
To quickly find out which one you go to https://packages.debian.org and enter the filename in the bottom search field.
In this case it leads to the package "libffi-dev".
mspohr
Sat Oct 12, 2019 8:17 pm
install python3-pip is the magic phrase.
Thank you.
Return to “Raspbian”
