stevemarsbar
Raspbian Buster and LIRC
Tue Jun 25, 2019 4:20 pm
Hi All,
I'm struggling to get LIRC to work on Raspbian Buster. It's a completely new install of Raspbian Buster downloaded today.
I have added the following line to /boot/config.txt and rebooted:
dtoverlay=gpio-ir,gpio_pin=24
dtoverlay=gpio-ir-tx,gpio_pin=25
and then installed Lirc via command:
sudo apt install lirc
however when trying to use lircd, I get a segmentation fault.
Any pointers or ideas? I've also tried building lirc from source.
Steve
stevemarsbar
Re: Raspbian Buster and LIRC
Wed Jun 26, 2019 1:48 pm
Thanks!
The final steps to config LIRC on Buster to send IR commands were:
Add the following line to /boot/config.txt and reboot:
dtoverlay=gpio-ir-tx,gpio_pin=17
Attempt install of lirc (It wiill fail but will create directory structure etc):
Rename the LIRC config file:
sudo cp /etc/lirc/lirc_options.conf.dist /etc/lirc/lirc_options.conf
Update the following lines in /etc/lirc/lirc_options.conf:
driver = default
device = /dev/lirc0
Finish installation of LIRC:
Install your desired remote and use :)
MallocArray
Thu Jun 27, 2019 6:16 pm
Does anyone know if copying the .conf.dist to .conf is an permanent step or just a bug that will be resolved? The "apt install lirc" fails halfway through but copying two files like this and then trying to install it again does allow it to complete as mentioned in this thread. It was not required in earlier versions
sudo cp /etc/lirc/lircd.conf.dist /etc/lirc/lircd.conf
portafreak
Mon Aug 05, 2019 11:54 pm
It seems to be working for transmitting but cannot get it to record new remote with this command:
irrecord -d /dev/lirc0 out.conf
Warning: Running as root.
Using driver default on device /dev/lirc0
Mode not supported
It was working great with Jessie and Raspberrypi3.
My settings in /boot/config.txt:
dtoverlay=gpio-ir,gpio_pin=23
dtoverlay=gpio-ir-tx,gpio_pin=22
portafreak
Sun Aug 11, 2019 6:43 pm
I have found a way to make it work by following this post on github: https://github.com/raspberrypi/linux/issues/2993
jerihaly
Thu Aug 29, 2019 3:05 am
I have noticed that switching "lirc0" with "lirc1" gets mode2 and irrecord to work. I am a total noob and the only reason I tried this is because I noticed both lirc0 and lirc1 files in /dev folder while messing around trying to learn more about the lirc files. Why is this? And why was this changed? It worked using Jesse before and now Buster requires gpio-ir instead of lirc_rpi (I do not have a good understanding of either.) and need to change file names to finish installing? I do not understand why this was changed on such a fundamental level. Also currently having trouble with irsend after irrecord successfully created a file. irrecord created file in /home/pi and I copied to /etc/lirc.
Returns as:
bash: verizon: No such file or directory.
