According to the FanShim inhouse tests they run cooler without the heatsink than with.itsmedoofer wrote: ↑Fri Jun 28, 2019 12:26 pmI saw a 20C drop, just with the FanShim fitted, no heatsink. The USB ports were noticeably cooler as well after 10 mins of the fan running.
That will not work any better, you'll be trying to suck air out of what is essentially a poorly sealed vacuum. Try it yourself, take a plastic straw and block one end with your finger, blow into the straw. Then try to suck air through the straw.furious360 wrote: ↑Tue Jul 09, 2019 5:24 amThe only difference is that I can not blow in the case because there are no removable sides so I will reverse the fan and extract the hot air from the case.
Have you got a link for that case - looks good.gkreidl wrote: ↑Tue Jul 09, 2019 8:47 amThe acryl case shown below has open sides. If you add the additional spacers (as shown in the image), it can easily be mounted sideways (on the GPIO side). This gives some kind of protection and provides a good airflow for the whole board. Adding a small heat sink to the SOC (and perhaps also to the USB controller) might help a bit more.
You're right, there is a lot of changes to make on the official case.Imperf3kt wrote: ↑Tue Jul 09, 2019 9:23 amThat will not work any better, you'll be trying to suck air out of what is essentially a poorly sealed vacuum. Try it yourself, take a plastic straw and block one end with your finger, blow into the straw. Then try to suck air through the straw.
You'll notice in both situations, it is impossible to make any air move.
I'd get out a drill and put a few holes in the plastic for ventilation.
Inside that tiny enclosed space with no ventilation holes, I cant see that big heat sink doing anything at all. You have to get the 10 watts of heat out of the case. The large mass of the heat sink may delay the rise in temperature in the short term, but that's all.
Well, the PoE HAT could do this, but it'd need a cut down version without the PoE bit and just the fan and fan control circuitry.laurent wrote: ↑Wed Jul 10, 2019 8:34 amI think a solution for keeping the CPU cold, while having a HAT attached, is to design a "cooling HAT" between the Pi and the "useful" HAT stacked on to ! A thin blowing fan (like on laptop ones) on the "cooling HAT" could extract the hot air above the CPU and send it to one side, allowing a lower space between those stacked boards.
I believe thats called the Pimoroni Fan SHIMrpdom wrote: ↑Wed Jul 10, 2019 9:43 amWell, the PoE HAT could do this, but it'd need a cut down version without the PoE bit and just the fan and fan control circuitry.laurent wrote: ↑Wed Jul 10, 2019 8:34 amI think a solution for keeping the CPU cold, while having a HAT attached, is to design a "cooling HAT" between the Pi and the "useful" HAT stacked on to ! A thin blowing fan (like on laptop ones) on the "cooling HAT" could extract the hot air above the CPU and send it to one side, allowing a lower space between those stacked boards.
It's almost that. But the problem with the POE HAT design is the regular fan it uses. It takes the air from above to blow it down to the CPU. The design I think uses a radial blowing fan to take the air flow from the CPU to a side of the "cooling HAT" (and not above or bottom), letting the attached HAT stacked totaly insulated from the CPU's temperature and hot air flow (and keeping this flow optimally extracted).rpdom wrote: ↑Wed Jul 10, 2019 9:43 amWell, the PoE HAT could do this, but it'd need a cut down version without the PoE bit and just the fan and fan control circuitry.laurent wrote: ↑Wed Jul 10, 2019 8:34 amI think a solution for keeping the CPU cold, while having a HAT attached, is to design a "cooling HAT" between the Pi and the "useful" HAT stacked on to ! A thin blowing fan (like on laptop ones) on the "cooling HAT" could extract the hot air above the CPU and send it to one side, allowing a lower space between those stacked boards.
The Pimoroni Fan SHIM is not compatible with I2S HAT (seems due to a shared GPIO), and I'm guessing how efficient could be that shim with a HAT just above.Imperf3kt wrote: ↑Wed Jul 10, 2019 12:06 pmI believe thats called the Pimoroni Fan SHIMrpdom wrote: ↑Wed Jul 10, 2019 9:43 amWell, the PoE HAT could do this, but it'd need a cut down version without the PoE bit and just the fan and fan control circuitry.laurent wrote: ↑Wed Jul 10, 2019 8:34 amI think a solution for keeping the CPU cold, while having a HAT attached, is to design a "cooling HAT" between the Pi and the "useful" HAT stacked on to ! A thin blowing fan (like on laptop ones) on the "cooling HAT" could extract the hot air above the CPU and send it to one side, allowing a lower space between those stacked boards.
https://shop.pimoroni.com/products/fan-shim
But you'll require a header extension
https://shop.pimoroni.com/products/booster-header
https://www.tomshardware.com/reviews/pi ... ,6219.html
Installed, no issues, minor improvement. Heatsink on order
That looks like a great case! Did you notice though that it only shows a single, full sized HDMI port on the side? If it's for a Pi4 it would be great if they converted it to full sized ports, via their internal "extensions" it should also have two of them.Montala wrote: ↑Tue Jul 02, 2019 7:21 amA Pi 4 specific case is also available for pre-order from Argon ONE at the higher price of $25.00 on https://www.argon40.com/argon-one-pi4.html
