lerner
Help with crashing RPZ(W)
Mon Jun 24, 2019 10:51 am
I have a RPZ(W) running 24/7.
It is early days but now and then it is locking up or something.
I am not sure as it is headless.
I have the log file and message file.
Is this the right place to ask for help understanding them?
I copied the /var/log/syslog and /var/log/messages file.
The event happened at a known time and that is in the logs.
Could someone read them and tell me if there is anything "wrong" with the machine, or find out why it stopped at the given time if I post the logs?
pcmanbob
Re: Help with crashing RPZ(W)
Mon Jun 24, 2019 1:05 pm
I would suggest you should have posted the logs with your question.
use code tags to post the logs .
lerner
Mon Jun 24, 2019 9:16 pm
Here they are.
The time of interest is June 24 time 20:17
Jun 23 06:25:09 TelePi liblogging-stdlog:  [origin software="rsyslogd" swVersion="8.24.0" x-pid="236" x-info="http://www.rsyslog.com"] rsyslogd was HUPed
Jun 24 06:25:08 TelePi liblogging-stdlog:  [origin software="rsyslogd" swVersion="8.24.0" x-pid="236" x-info="http://www.rsyslog.com"] rsyslogd was HUPed
Jun 24 07:17:12 TelePi kernel: [    0.000000] Booting Linux on physical CPU 0x0
Jun 24 07:17:12 TelePi kernel: [    0.000000] Linux version 4.14.71+ ([email protected]) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1145 Fri Sep 21 15:06:38 BST 2018
Jun 24 07:17:12 TelePi kernel: [    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
Jun 24 07:17:12 TelePi kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Jun 24 07:17:12 TelePi kernel: [    0.000000] OF: fdt: Machine model: Raspberry Pi Zero W Rev 1.1
Jun 24 07:17:12 TelePi kernel: [    0.000000] Memory policy: Data cache writeback
Jun 24 07:17:12 TelePi kernel: [    0.000000] cma: Reserved 8 MiB at 0x17400000
Jun 24 07:17:12 TelePi kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 97440
Jun 24 07:17:12 TelePi kernel: [    0.000000] Kernel command line: 8250.nr_uarts=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:7A:DA:02 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=dd3bf6a2-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles net.ifnames=0
Jun 24 07:17:12 TelePi kernel: [    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
Jun 24 07:17:12 TelePi kernel: [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Jun 24 07:17:12 TelePi kernel: [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Jun 24 07:17:12 TelePi kernel: [    0.000000] Memory: 370280K/393216K available (6431K kernel code, 587K rwdata, 1988K rodata, 436K init, 673K bss, 14744K reserved, 8192K cma-reserved)
Jun 24 07:17:12 TelePi kernel: [    0.000000] Virtual kernel memory layout:
Jun 24 07:17:12 TelePi kernel: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Jun 24 07:17:12 TelePi kernel: [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
Jun 24 07:17:12 TelePi kernel: [    0.000000]     vmalloc : 0xd8800000 - 0xff800000   ( 624 MB)
Jun 24 07:17:12 TelePi kernel: [    0.000000]     lowmem  : 0xc0000000 - 0xd8000000   ( 384 MB)
Jun 24 07:17:12 TelePi kernel: [    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
Jun 24 07:17:12 TelePi kernel: [    0.000000]       .text : 0xc0008000 - 0xc064fed0   (6432 kB)
Jun 24 07:17:12 TelePi kernel: [    0.000000]       .init : 0xc08cd000 - 0xc093a000   ( 436 kB)
Jun 24 07:17:12 TelePi kernel: [    0.000000]       .data : 0xc093a000 - 0xc09ccfe0   ( 588 kB)
Jun 24 07:17:12 TelePi kernel: [    0.000000]        .bss : 0xc09d28f0 - 0xc0a7ae6c   ( 674 kB)
Jun 24 07:17:12 TelePi kernel: [    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Jun 24 07:17:12 TelePi kernel: [    0.000000] ftrace: allocating 24110 entries in 71 pages
Jun 24 07:17:12 TelePi kernel: [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Jun 24 07:17:12 TelePi kernel: [    0.000030] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
Jun 24 07:17:12 TelePi kernel: [    0.000062] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
Jun 24 07:17:12 TelePi kernel: [    0.000146] bcm2835: system timer (irq = 27)
Jun 24 07:17:12 TelePi kernel: [    0.000708] Console: colour dummy device 80x30
Jun 24 07:17:12 TelePi kernel: [    0.000734] console [tty1] enabled
Jun 24 07:17:12 TelePi kernel: [    0.000778] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
Jun 24 07:17:12 TelePi kernel: [    0.060295] pid_max: default: 32768 minimum: 301
Jun 24 07:17:12 TelePi kernel: [    0.060801] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Jun 24 07:17:12 TelePi kernel: [    0.060820] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Jun 24 07:17:12 TelePi kernel: [    0.062104] Disabling memory control group subsystem
Jun 24 07:17:12 TelePi kernel: [    0.062266] CPU: Testing write buffer coherency: ok
Jun 24 07:17:12 TelePi kernel: [    0.063391] Setting up static identity map for 0x8200 - 0x8238
Jun 24 07:17:12 TelePi kernel: [    0.064611] devtmpfs: initialized
Jun 24 07:17:12 TelePi kernel: [    0.073776] random: get_random_u32 called from bucket_table_alloc+0x88/0x1c4 with crng_init=0
Jun 24 07:17:12 TelePi kernel: [    0.074801] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
Jun 24 07:17:12 TelePi kernel: [    0.075170] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Jun 24 07:17:12 TelePi kernel: [    0.075198] futex hash table entries: 256 (order: -1, 3072 bytes)
Jun 24 07:17:12 TelePi kernel: [    0.076521] pinctrl core: initialized pinctrl subsystem
Jun 24 07:17:12 TelePi kernel: [    0.077844] NET: Registered protocol family 16
Jun 24 07:17:12 TelePi kernel: [    0.080955] DMA: preallocated 1024 KiB pool for atomic coherent allocations
Jun 24 07:17:12 TelePi kernel: [    0.087294] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
Jun 24 07:17:12 TelePi kernel: [    0.087311] hw-breakpoint: maximum watchpoint size is 4 bytes.
Jun 24 07:17:12 TelePi kernel: [    0.087433] Serial: AMBA PL011 UART driver
Jun 24 07:17:12 TelePi kernel: [    0.090252] bcm2835-mbox 2000b880.mailbox: mailbox enabled
Jun 24 07:17:12 TelePi kernel: [    0.091101] uart-pl011 20201000.serial: could not find pctldev for node /soc/[email protected]/uart0_pins, deferring probe
Jun 24 07:17:12 TelePi kernel: [    0.131616] bcm2835-dma 20007000.dma: DMA legacy API manager at d880d000, dmachans=0x1
Jun 24 07:17:12 TelePi kernel: [    0.133793] SCSI subsystem initialized
Jun 24 07:17:12 TelePi kernel: [    0.134005] usbcore: registered new interface driver usbfs
Jun 24 07:17:12 TelePi kernel: [    0.134097] usbcore: registered new interface driver hub
Jun 24 07:17:12 TelePi kernel: [    0.134299] usbcore: registered new device driver usb
Jun 24 07:17:12 TelePi kernel: [    0.140806] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-09-21 15:48
Jun 24 07:17:12 TelePi kernel: [    0.142950] clocksource: Switched to clocksource timer
Jun 24 07:17:12 TelePi kernel: [    0.229011] VFS: Disk quotas dquot_6.6.0
Jun 24 07:17:12 TelePi kernel: [    0.229135] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Jun 24 07:17:12 TelePi kernel: [    0.229417] FS-Cache: Loaded
Jun 24 07:17:12 TelePi kernel: [    0.229734] CacheFiles: Loaded
Jun 24 07:17:12 TelePi kernel: [    0.246634] NET: Registered protocol family 2
Jun 24 07:17:12 TelePi kernel: [    0.247820] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
Jun 24 07:17:12 TelePi kernel: [    0.247907] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
Jun 24 07:17:12 TelePi kernel: [    0.248002] TCP: Hash tables configured (established 4096 bind 4096)
Jun 24 07:17:12 TelePi kernel: [    0.248153] UDP hash table entries: 256 (order: 0, 4096 bytes)
Jun 24 07:17:12 TelePi kernel: [    0.248182] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Jun 24 07:17:12 TelePi kernel: [    0.248533] NET: Registered protocol family 1
Jun 24 07:17:12 TelePi kernel: [    0.249252] RPC: Registered named UNIX socket transport module.
Jun 24 07:17:12 TelePi kernel: [    0.249264] RPC: Registered udp transport module.
Jun 24 07:17:12 TelePi kernel: [    0.249269] RPC: Registered tcp transport module.
Jun 24 07:17:12 TelePi kernel: [    0.249274] RPC: Registered tcp NFSv4.1 backchannel transport module.
Jun 24 07:17:12 TelePi kernel: [    0.251328] hw perfevents: no irqs for PMU, sampling events not supported
Jun 24 07:17:12 TelePi kernel: [    0.251400] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
Jun 24 07:17:12 TelePi kernel: [    0.255180] workingset: timestamp_bits=14 max_order=17 bucket_order=3
Jun 24 07:17:12 TelePi kernel: [    0.267074] FS-Cache: Netfs 'nfs' registered for caching
Jun 24 07:17:12 TelePi kernel: [    0.268393] NFS: Registering the id_resolver key type
Jun 24 07:17:12 TelePi kernel: [    0.268449] Key type id_resolver registered
Jun 24 07:17:12 TelePi kernel: [    0.268457] Key type id_legacy registered
Jun 24 07:17:12 TelePi kernel: [    0.268483] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Jun 24 07:17:12 TelePi kernel: [    0.273269] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
Jun 24 07:17:12 TelePi kernel: [    0.273693] io scheduler noop registered
Jun 24 07:17:12 TelePi kernel: [    0.273706] io scheduler deadline registered (default)
Jun 24 07:17:12 TelePi kernel: [    0.274239] io scheduler cfq registered
Jun 24 07:17:12 TelePi kernel: [    0.274255] io scheduler mq-deadline registered
Jun 24 07:17:12 TelePi kernel: [    0.274262] io scheduler kyber registered
Jun 24 07:17:12 TelePi kernel: [    0.276538] BCM2708FB: allocated DMA memory 57500000
Jun 24 07:17:12 TelePi kernel: [    0.276601] BCM2708FB: allocated DMA channel 0 @ d880d000
Jun 24 07:17:12 TelePi kernel: [    0.284662] Console: switching to colour frame buffer device 82x26
Jun 24 07:17:12 TelePi kernel: [    0.290771] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
Jun 24 07:17:12 TelePi kernel: [    0.293506] bcm2835-rng 20104000.rng: hwrng registered
Jun 24 07:17:12 TelePi kernel: [    0.293742] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
Jun 24 07:17:12 TelePi kernel: [    0.294751] vc-sm: Videocore shared memory driver
Jun 24 07:17:12 TelePi kernel: [    0.295328] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
Jun 24 07:17:12 TelePi kernel: [    0.313809] brd: module loaded
Jun 24 07:17:12 TelePi kernel: [    0.325713] loop: module loaded
Jun 24 07:17:12 TelePi kernel: [    0.325735] Loading iSCSI transport class v2.0-870.
Jun 24 07:17:12 TelePi kernel: [    0.326580] usbcore: registered new interface driver smsc95xx
Jun 24 07:17:12 TelePi kernel: [    0.326610] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Jun 24 07:17:12 TelePi kernel: [    0.354685] dwc_otg 20980000.usb: base=0xf0980000
Jun 24 07:17:12 TelePi kernel: [    0.555094] Core Release: 2.80a
Jun 24 07:17:12 TelePi kernel: [    0.555111] Setting default values for core params
Jun 24 07:17:12 TelePi kernel: [    0.555151] Finished setting default values for core params
Jun 24 07:17:12 TelePi kernel: [    0.755482] Using Buffer DMA mode
Jun 24 07:17:12 TelePi kernel: [    0.755495] Periodic Transfer Interrupt Enhancement - disabled
Jun 24 07:17:12 TelePi kernel: [    0.755501] Multiprocessor Interrupt Enhancement - disabled
Jun 24 07:17:12 TelePi kernel: [    0.755513] OTG VER PARAM: 0, OTG VER FLAG: 0
Jun 24 07:17:12 TelePi kernel: [    0.755614] Dedicated Tx FIFOs mode
Jun 24 07:17:12 TelePi kernel: [    0.756475] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xd7514000 dma = 0x57514000 len=9024
Jun 24 07:17:12 TelePi kernel: [    0.756504] FIQ FSM acceleration enabled for :
Jun 24 07:17:12 TelePi kernel: [    0.756504] Non-periodic Split Transactions
Jun 24 07:17:12 TelePi kernel: [    0.756504] Periodic Split Transactions
Jun 24 07:17:12 TelePi kernel: [    0.756504] High-Speed Isochronous Endpoints
Jun 24 07:17:12 TelePi kernel: [    0.756504] Interrupt/Control Split Transaction hack enabled
Jun 24 07:17:12 TelePi kernel: [    0.756685] WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc049c060
Jun 24 07:17:12 TelePi kernel: [    0.756699] WARN::hcd_init_fiq:460: FIQ ASM at 0xc049c33c length 36
Jun 24 07:17:12 TelePi kernel: [    0.756728] WARN::hcd_init_fiq:486: MPHI regs_base at 0xf0006000
Jun 24 07:17:12 TelePi kernel: [    0.756811] dwc_otg 20980000.usb: DWC OTG Controller
Jun 24 07:17:12 TelePi kernel: [    0.756878] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
Jun 24 07:17:12 TelePi kernel: [    0.756952] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
Jun 24 07:17:12 TelePi kernel: [    0.757008] Init: Port Power? op_state=1
Jun 24 07:17:12 TelePi kernel: [    0.757015] Init: Power Port (0)
Jun 24 07:17:12 TelePi kernel: [    0.757420] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Jun 24 07:17:12 TelePi kernel: [    0.757438] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun 24 07:17:12 TelePi kernel: [    0.757450] usb usb1: Product: DWC OTG Controller
Jun 24 07:17:12 TelePi kernel: [    0.757461] usb usb1: Manufacturer: Linux 4.14.71+ dwc_otg_hcd
Jun 24 07:17:12 TelePi kernel: [    0.757471] usb usb1: SerialNumber: 20980000.usb
Jun 24 07:17:12 TelePi kernel: [    0.758572] hub 1-0:1.0: USB hub found
Jun 24 07:17:12 TelePi kernel: [    0.758679] hub 1-0:1.0: 1 port detected
Jun 24 07:17:12 TelePi kernel: [    0.760163] usbcore: registered new interface driver usb-storage
Jun 24 07:17:12 TelePi kernel: [    0.760564] mousedev: PS/2 mouse device common for all mice
Jun 24 07:17:12 TelePi kernel: [    0.760625] IR NEC protocol handler initialized
Jun 24 07:17:12 TelePi kernel: [    0.760633] IR RC5(x/sz) protocol handler initialized
Jun 24 07:17:12 TelePi kernel: [    0.760638] IR RC6 protocol handler initialized
Jun 24 07:17:12 TelePi kernel: [    0.760643] IR JVC protocol handler initialized
Jun 24 07:17:12 TelePi kernel: [    0.760648] IR Sony protocol handler initialized
Jun 24 07:17:12 TelePi kernel: [    0.760653] IR SANYO protocol handler initialized
Jun 24 07:17:12 TelePi kernel: [    0.760659] IR Sharp protocol handler initialized
Jun 24 07:17:12 TelePi kernel: [    0.760664] IR MCE Keyboard/mouse protocol handler initialized
Jun 24 07:17:12 TelePi kernel: [    0.760669] IR XMP protocol handler initialized
Jun 24 07:17:12 TelePi kernel: [    0.761934] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
Jun 24 07:17:12 TelePi kernel: [    0.762468] bcm2835-cpufreq: min=700000 max=1000000
Jun 24 07:17:12 TelePi kernel: [    0.763182] sdhci: Secure Digital Host Controller Interface driver
Jun 24 07:17:12 TelePi kernel: [    0.763193] sdhci: Copyright(c) Pierre Ossman
Jun 24 07:17:12 TelePi kernel: [    0.763790] mmc-bcm2835 20300000.mmc: could not get clk, deferring probe
Jun 24 07:17:12 TelePi kernel: [    0.764386] sdhost-bcm2835 20202000.mmc: could not get clk, deferring probe
Jun 24 07:17:12 TelePi kernel: [    0.764574] sdhci-pltfm: SDHCI platform and OF driver helper
Jun 24 07:17:12 TelePi kernel: [    0.765109] ledtrig-cpu: registered to indicate activity on CPUs
Jun 24 07:17:12 TelePi kernel: [    0.765238] hidraw: raw HID events driver (C) Jiri Kosina
Jun 24 07:17:12 TelePi kernel: [    0.765485] usbcore: registered new interface driver usbhid
Jun 24 07:17:12 TelePi kernel: [    0.765495] usbhid: USB HID core driver
Jun 24 07:17:12 TelePi kernel: [    0.766418] vchiq: vchiq_init_state: slot_zero = d7580000, is_master = 0
Jun 24 07:17:12 TelePi kernel: [    0.768333] [vc_sm_connected_init]: start
Jun 24 07:17:12 TelePi kernel: [    0.777879] [vc_sm_connected_init]: end - returning 0
Jun 24 07:17:12 TelePi kernel: [    0.778821] Initializing XFRM netlink socket
Jun 24 07:17:12 TelePi kernel: [    0.778883] NET: Registered protocol family 17
Jun 24 07:17:12 TelePi kernel: [    0.779034] Key type dns_resolver registered
Jun 24 07:17:12 TelePi kernel: [    0.780840] registered taskstats version 1
Jun 24 07:17:12 TelePi kernel: [    0.789170] uart-pl011 20201000.serial: cts_event_workaround enabled
Jun 24 07:17:12 TelePi kernel: [    0.789324] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
Jun 24 07:17:12 TelePi kernel: [    0.791905] console [ttyS0] disabled
Jun 24 07:17:12 TelePi kernel: [    0.791963] 20215040.serial: ttyS0 at MMIO 0x0 (irq = 160, base_baud = 31250000) is a 16550
Jun 24 07:17:12 TelePi kernel: [    0.792051] console [ttyS0] enabled
Jun 24 07:17:12 TelePi kernel: [    0.793792] mmc-bcm2835 20300000.mmc: mmc_debug:0 mmc_debug2:0
Jun 24 07:17:12 TelePi kernel: [    0.793810] mmc-bcm2835 20300000.mmc: DMA channel allocated
Jun 24 07:17:12 TelePi kernel: [    0.856467] sdhost: log_buf @ d7513000 (57513000)
Jun 24 07:17:12 TelePi kernel: [    0.890946] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Jun 24 07:17:12 TelePi kernel: [    0.892666] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Jun 24 07:17:12 TelePi kernel: [    0.894347] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Jun 24 07:17:12 TelePi kernel: [    0.897277] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Jun 24 07:17:12 TelePi kernel: [    0.925493] random: fast init done
Jun 24 07:17:12 TelePi kernel: [    0.932987] NOHZ: local_softirq_pending 02
Jun 24 07:17:12 TelePi kernel: [    0.933076] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Jun 24 07:17:12 TelePi kernel: [    0.934307] of_cfs_init
Jun 24 07:17:12 TelePi kernel: [    0.934441] of_cfs_init: OK
Jun 24 07:17:12 TelePi kernel: [    0.935456] Waiting for root device PARTUUID=dd3bf6a2-02...
Jun 24 07:17:12 TelePi kernel: [    1.021780] mmc1: new high speed SDIO card at address 0001
Jun 24 07:17:12 TelePi kernel: [    1.074395] mmc0: host does not support reading read-only switch, assuming write-enable
Jun 24 07:17:12 TelePi kernel: [    1.077703] mmc0: new high speed SDHC card at address aaaa
Jun 24 07:17:12 TelePi kernel: [    1.078486] mmcblk0: mmc0:aaaa SL32G 29.7 GiB
Jun 24 07:17:12 TelePi liblogging-stdlog:  [origin software="rsyslogd" swVersion="8.24.0" x-pid="236" x-info="http://www.rsyslog.com"] start
Jun 24 07:17:12 TelePi kernel: [    1.081551]  mmcblk0: p1 p2
Jun 24 07:17:12 TelePi kernel: [    1.086129] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
Jun 24 07:17:12 TelePi kernel: [    1.086146] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
Jun 24 07:17:12 TelePi kernel: [    1.529037] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
Jun 24 07:17:12 TelePi kernel: [    1.539118] EXT4-fs (mmcblk0p2): 2 orphan inodes deleted
Jun 24 07:17:12 TelePi kernel: [    1.539134] EXT4-fs (mmcblk0p2): recovery complete
Jun 24 07:17:12 TelePi kernel: [    1.553013] NOHZ: local_softirq_pending 40
Jun 24 07:17:12 TelePi kernel: [    1.554158] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Jun 24 07:17:12 TelePi kernel: [    1.554251] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
Jun 24 07:17:12 TelePi kernel: [    1.555384] devtmpfs: mounted
Jun 24 07:17:12 TelePi kernel: [    1.557812] Freeing unused kernel memory: 436K
Jun 24 07:17:12 TelePi kernel: [    1.557821] This architecture does not have kernel memory protection.
Jun 24 07:17:12 TelePi kernel: [    2.188546] ip_tables: (C) 2000-2006 Netfilter Core Team
Jun 24 07:17:12 TelePi kernel: [    2.221985] random: systemd: uninitialized urandom read (16 bytes read)
Jun 24 07:17:12 TelePi kernel: [    2.290305] random: systemd: uninitialized urandom read (16 bytes read)
Jun 24 07:17:12 TelePi kernel: [    2.510707] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read)
Jun 24 07:17:12 TelePi kernel: [    3.123014] NOHZ: local_softirq_pending 02
Jun 24 07:17:12 TelePi kernel: [    3.634301] i2c /dev entries driver
Jun 24 07:17:12 TelePi kernel: [    4.127520] Installing knfsd (copyright (C) 1996 [email protected]).
Jun 24 07:17:12 TelePi kernel: [    6.165264] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Jun 24 07:17:12 TelePi kernel: [    9.737415] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
Jun 24 07:17:12 TelePi kernel: [    9.768539] bcm2835_alsa bcm2835_alsa: card created with 8 channels
Jun 24 07:17:12 TelePi kernel: [   10.239904] usbcore: registered new interface driver brcmfmac
Jun 24 07:17:13 TelePi kernel: [   16.686290] uart-pl011 20201000.serial: no DMA platform data
Jun 24 07:17:17 TelePi kernel: [   20.170692] random: crng init done
Jun 24 07:17:17 TelePi kernel: [   20.170720] random: 7 urandom warning(s) missed due to ratelimiting
Jun 24 07:17:18 TelePi kernel: [   21.495871] Bluetooth: Core ver 2.22
Jun 24 07:17:18 TelePi kernel: [   21.496008] NET: Registered protocol family 31
Jun 24 07:17:18 TelePi kernel: [   21.496018] Bluetooth: HCI device and connection manager initialized
Jun 24 07:17:18 TelePi kernel: [   21.496052] Bluetooth: HCI socket layer initialized
Jun 24 07:17:18 TelePi kernel: [   21.496069] Bluetooth: L2CAP socket layer initialized
Jun 24 07:17:18 TelePi kernel: [   21.496129] Bluetooth: SCO socket layer initialized
Jun 24 07:17:18 TelePi kernel: [   21.545958] Bluetooth: HCI UART driver ver 2.3
Jun 24 07:17:18 TelePi kernel: [   21.545979] Bluetooth: HCI UART protocol H4 registered
Jun 24 07:17:18 TelePi kernel: [   21.545986] Bluetooth: HCI UART protocol Three-wire (H5) registered
Jun 24 07:17:18 TelePi kernel: [   21.563253] Bluetooth: HCI UART protocol Broadcom registered
Jun 24 07:17:20 TelePi kernel: [   22.903127] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Jun 24 07:17:20 TelePi kernel: [   22.903144] Bluetooth: BNEP filters: protocol multicast
Jun 24 07:17:20 TelePi kernel: [   22.903179] Bluetooth: BNEP socket layer initialized
Jun 24 07:17:20 TelePi kernel: [   23.643399] Bluetooth: RFCOMM TTY layer initialized
Jun 24 07:17:20 TelePi kernel: [   23.643443] Bluetooth: RFCOMM socket layer initialized
Jun 24 07:17:20 TelePi kernel: [   23.643496] Bluetooth: RFCOMM ver 1.11
Jun 24 07:17:22 TelePi kernel: [   25.072053] brcmfmac: power management disabled
Jun 24 07:17:23 TelePi kernel: [   26.507418] NFSD: starting 90-second grace period (net c09b8588)
Jun 24 07:17:27 TelePi kernel: [   30.128512] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
Jun 24 07:17:27 TelePi lightdm[441]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
Jun 24 07:17:37 TelePi lightdm[643]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
Jun 24 07:17:38 TelePi kernel: [   41.337182] NET: Registered protocol family 3
Jun 24 07:17:38 TelePi kernel: [   41.440537] NET: Registered protocol family 5
Jun 24 07:41:16 TelePi kernel: [   45.785733] fuse init (API version 7.26)
Jun 24 07:42:48 TelePi kernel: [  137.715460] warning: `/bin/ping' has both setuid-root and effective capabilities. Therefore not raising all capabilities.
Jun 24 07:42:55 TelePi kernel: [  144.100019] NOHZ: local_softirq_pending 40
Jun 24 07:44:15 TelePi kernel: [  224.092262] NOHZ: local_softirq_pending 40
Jun 24 07:46:35 TelePi kernel: [  364.108251] NOHZ: local_softirq_pending 40
Jun 24 07:46:55 TelePi kernel: [  384.102342] NOHZ: local_softirq_pending 40
Jun 24 07:47:25 TelePi kernel: [  414.675936] NOHZ: local_softirq_pending 42
Jun 24 07:48:17 TelePi kernel: [  466.866576] NOHZ: local_softirq_pending 40
Jun 24 07:48:17 TelePi kernel: [  466.866607] NOHZ: local_softirq_pending 40
Jun 24 20:16:33 TelePi kernel: [45363.077868] brcmfmac: power management disabled
Jun 24 20:16:35 TelePi kernel: [45364.497477] brcmfmac: power management disabled
Jun 24 20:17:10 TelePi kernel: [    0.000000] Booting Linux on physical CPU 0x0
Jun 24 20:17:10 TelePi kernel: [    0.000000] Linux version 4.14.71+ ([email protected]) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1145 Fri Sep 21 15:06:38 BST 2018
Jun 24 20:17:10 TelePi kernel: [    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
Jun 24 20:17:10 TelePi kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Jun 24 20:17:10 TelePi kernel: [    0.000000] OF: fdt: Machine model: Raspberry Pi Zero W Rev 1.1
Jun 24 20:17:10 TelePi kernel: [    0.000000] Memory policy: Data cache writeback
Jun 24 20:17:10 TelePi kernel: [    0.000000] cma: Reserved 8 MiB at 0x17400000
Jun 24 20:17:10 TelePi kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 97440
Jun 24 20:17:10 TelePi kernel: [    0.000000] Kernel command line: 8250.nr_uarts=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:7A:DA:02 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=dd3bf6a2-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles net.ifnames=0
Jun 24 20:17:10 TelePi kernel: [    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
Jun 24 20:17:10 TelePi kernel: [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Jun 24 20:17:10 TelePi kernel: [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Jun 24 20:17:10 TelePi kernel: [    0.000000] Memory: 370280K/393216K available (6431K kernel code, 587K rwdata, 1988K rodata, 436K init, 673K bss, 14744K reserved, 8192K cma-reserved)
Jun 24 20:17:10 TelePi kernel: [    0.000000] Virtual kernel memory layout:
Jun 24 20:17:10 TelePi kernel: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Jun 24 20:17:10 TelePi kernel: [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
Jun 24 20:17:10 TelePi kernel: [    0.000000]     vmalloc : 0xd8800000 - 0xff800000   ( 624 MB)
Jun 24 20:17:10 TelePi kernel: [    0.000000]     lowmem  : 0xc0000000 - 0xd8000000   ( 384 MB)
Jun 24 20:17:10 TelePi kernel: [    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
Jun 24 20:17:10 TelePi kernel: [    0.000000]       .text : 0xc0008000 - 0xc064fed0   (6432 kB)
Jun 24 20:17:10 TelePi kernel: [    0.000000]       .init : 0xc08cd000 - 0xc093a000   ( 436 kB)
Jun 24 20:17:10 TelePi kernel: [    0.000000]       .data : 0xc093a000 - 0xc09ccfe0   ( 588 kB)
Jun 24 20:17:10 TelePi kernel: [    0.000000]        .bss : 0xc09d28f0 - 0xc0a7ae6c   ( 674 kB)
Jun 24 20:17:10 TelePi kernel: [    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Jun 24 20:17:10 TelePi kernel: [    0.000000] ftrace: allocating 24110 entries in 71 pages
Jun 24 20:17:10 TelePi kernel: [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Jun 24 20:17:10 TelePi kernel: [    0.000029] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
Jun 24 20:17:10 TelePi kernel: [    0.000062] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
Jun 24 20:17:10 TelePi kernel: [    0.000144] bcm2835: system timer (irq = 27)
Jun 24 20:17:10 TelePi kernel: [    0.000708] Console: colour dummy device 80x30
Jun 24 20:17:10 TelePi kernel: [    0.000734] console [tty1] enabled
Jun 24 20:17:10 TelePi kernel: [    0.000777] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
Jun 24 20:17:10 TelePi kernel: [    0.060293] pid_max: default: 32768 minimum: 301
Jun 24 20:17:10 TelePi kernel: [    0.060798] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Jun 24 20:17:10 TelePi kernel: [    0.060819] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Jun 24 20:17:10 TelePi kernel: [    0.062093] Disabling memory control group subsystem
Jun 24 20:17:10 TelePi kernel: [    0.062256] CPU: Testing write buffer coherency: ok
Jun 24 20:17:10 TelePi kernel: [    0.063380] Setting up static identity map for 0x8200 - 0x8238
Jun 24 20:17:10 TelePi kernel: [    0.064596] devtmpfs: initialized
Jun 24 20:17:10 TelePi kernel: [    0.073757] random: get_random_u32 called from bucket_table_alloc+0x88/0x1c4 with crng_init=0
Jun 24 20:17:10 TelePi kernel: [    0.074779] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
Jun 24 20:17:10 TelePi kernel: [    0.075148] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Jun 24 20:17:10 TelePi kernel: [    0.075176] futex hash table entries: 256 (order: -1, 3072 bytes)
Jun 24 20:17:10 TelePi kernel: [    0.076502] pinctrl core: initialized pinctrl subsystem
Jun 24 20:17:10 TelePi kernel: [    0.077831] NET: Registered protocol family 16
Jun 24 20:17:10 TelePi kernel: [    0.080946] DMA: preallocated 1024 KiB pool for atomic coherent allocations
Jun 24 20:17:10 TelePi kernel: [    0.087281] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
Jun 24 20:17:10 TelePi kernel: [    0.087298] hw-breakpoint: maximum watchpoint size is 4 bytes.
Jun 24 20:17:10 TelePi kernel: [    0.087421] Serial: AMBA PL011 UART driver
Jun 24 20:17:10 TelePi kernel: [    0.090234] bcm2835-mbox 2000b880.mailbox: mailbox enabled
Jun 24 20:17:10 TelePi kernel: [    0.091084] uart-pl011 20201000.serial: could not find pctldev for node /soc/[email protected]/uart0_pins, deferring probe
Jun 24 20:17:10 TelePi kernel: [    0.131630] bcm2835-dma 20007000.dma: DMA legacy API manager at d880d000, dmachans=0x1
Jun 24 20:17:10 TelePi kernel: [    0.133806] SCSI subsystem initialized
Jun 24 20:17:10 TelePi kernel: [    0.134015] usbcore: registered new interface driver usbfs
Jun 24 20:17:10 TelePi kernel: [    0.134106] usbcore: registered new interface driver hub
Jun 24 20:17:10 TelePi kernel: [    0.134307] usbcore: registered new device driver usb
Jun 24 20:17:10 TelePi kernel: [    0.140801] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-09-21 15:48
Jun 24 20:17:10 TelePi kernel: [    0.142952] clocksource: Switched to clocksource timer
Jun 24 20:17:10 TelePi kernel: [    0.229038] VFS: Disk quotas dquot_6.6.0
Jun 24 20:17:10 TelePi kernel: [    0.229161] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Jun 24 20:17:10 TelePi kernel: [    0.229442] FS-Cache: Loaded
Jun 24 20:17:10 TelePi kernel: [    0.229762] CacheFiles: Loaded
Jun 24 20:17:10 TelePi kernel: [    0.246701] NET: Registered protocol family 2
Jun 24 20:17:10 TelePi kernel: [    0.247879] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
Jun 24 20:17:10 TelePi kernel: [    0.247966] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
Jun 24 20:17:10 TelePi kernel: [    0.248061] TCP: Hash tables configured (established 4096 bind 4096)
Jun 24 20:17:10 TelePi kernel: [    0.248212] UDP hash table entries: 256 (order: 0, 4096 bytes)
Jun 24 20:17:10 TelePi kernel: [    0.248242] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Jun 24 20:17:10 TelePi kernel: [    0.248589] NET: Registered protocol family 1
Jun 24 20:17:10 TelePi kernel: [    0.249308] RPC: Registered named UNIX socket transport module.
Jun 24 20:17:10 TelePi kernel: [    0.249320] RPC: Registered udp transport module.
Jun 24 20:17:10 TelePi kernel: [    0.249325] RPC: Registered tcp transport module.
Jun 24 20:17:10 TelePi kernel: [    0.249330] RPC: Registered tcp NFSv4.1 backchannel transport module.
Jun 24 20:17:10 TelePi kernel: [    0.251393] hw perfevents: no irqs for PMU, sampling events not supported
Jun 24 20:17:10 TelePi kernel: [    0.251466] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
Jun 24 20:17:10 TelePi kernel: [    0.255251] workingset: timestamp_bits=14 max_order=17 bucket_order=3
Jun 24 20:17:10 TelePi kernel: [    0.267132] FS-Cache: Netfs 'nfs' registered for caching
Jun 24 20:17:10 TelePi kernel: [    0.268455] NFS: Registering the id_resolver key type
Jun 24 20:17:10 TelePi kernel: [    0.268512] Key type id_resolver registered
Jun 24 20:17:10 TelePi kernel: [    0.268520] Key type id_legacy registered
Jun 24 20:17:10 TelePi kernel: [    0.268545] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Jun 24 20:17:10 TelePi kernel: [    0.273342] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
Jun 24 20:17:10 TelePi kernel: [    0.273762] io scheduler noop registered
Jun 24 20:17:10 TelePi kernel: [    0.273775] io scheduler deadline registered (default)
Jun 24 20:17:10 TelePi kernel: [    0.274307] io scheduler cfq registered
Jun 24 20:17:10 TelePi kernel: [    0.274323] io scheduler mq-deadline registered
Jun 24 20:17:10 TelePi kernel: [    0.274330] io scheduler kyber registered
Jun 24 20:17:10 TelePi kernel: [    0.276595] BCM2708FB: allocated DMA memory 57500000
Jun 24 20:17:10 TelePi kernel: [    0.276657] BCM2708FB: allocated DMA channel 0 @ d880d000
Jun 24 20:17:10 TelePi kernel: [    0.284708] Console: switching to colour frame buffer device 82x26
Jun 24 20:17:10 TelePi kernel: [    0.290825] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
Jun 24 20:17:10 TelePi kernel: [    0.293620] bcm2835-rng 20104000.rng: hwrng registered
Jun 24 20:17:10 TelePi kernel: [    0.293862] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
Jun 24 20:17:10 TelePi kernel: [    0.294883] vc-sm: Videocore shared memory driver
Jun 24 20:17:10 TelePi kernel: [    0.295470] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
Jun 24 20:17:10 TelePi kernel: [    0.313981] brd: module loaded
Jun 24 20:17:10 TelePi kernel: [    0.325806] loop: module loaded
Jun 24 20:17:10 TelePi kernel: [    0.325828] Loading iSCSI transport class v2.0-870.
Jun 24 20:17:10 TelePi kernel: [    0.326663] usbcore: registered new interface driver smsc95xx
Jun 24 20:17:10 TelePi kernel: [    0.326694] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Jun 24 20:17:10 TelePi kernel: [    0.354776] dwc_otg 20980000.usb: base=0xf0980000
Jun 24 20:17:10 TelePi kernel: [    0.555174] Core Release: 2.80a
Jun 24 20:17:10 TelePi kernel: [    0.555191] Setting default values for core params
Jun 24 20:17:10 TelePi kernel: [    0.555230] Finished setting default values for core params
Jun 24 20:17:10 TelePi kernel: [    0.755551] Using Buffer DMA mode
Jun 24 20:17:10 TelePi kernel: [    0.755565] Periodic Transfer Interrupt Enhancement - disabled
Jun 24 20:17:10 TelePi kernel: [    0.755571] Multiprocessor Interrupt Enhancement - disabled
Jun 24 20:17:10 TelePi kernel: [    0.755582] OTG VER PARAM: 0, OTG VER FLAG: 0
Jun 24 20:17:10 TelePi kernel: [    0.755680] Dedicated Tx FIFOs mode
Jun 24 20:17:10 TelePi kernel: [    0.756517] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xd7514000 dma = 0x57514000 len=9024
Jun 24 20:17:10 TelePi kernel: [    0.756546] FIQ FSM acceleration enabled for :
Jun 24 20:17:10 TelePi kernel: [    0.756546] Non-periodic Split Transactions
Jun 24 20:17:10 TelePi kernel: [    0.756546] Periodic Split Transactions
Jun 24 20:17:10 TelePi kernel: [    0.756546] High-Speed Isochronous Endpoints
Jun 24 20:17:10 TelePi kernel: [    0.756546] Interrupt/Control Split Transaction hack enabled
Jun 24 20:17:10 TelePi kernel: [    0.756726] WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc049c060
Jun 24 20:17:10 TelePi kernel: [    0.756741] WARN::hcd_init_fiq:460: FIQ ASM at 0xc049c33c length 36
Jun 24 20:17:10 TelePi kernel: [    0.756768] WARN::hcd_init_fiq:486: MPHI regs_base at 0xf0006000
Jun 24 20:17:10 TelePi kernel: [    0.756849] dwc_otg 20980000.usb: DWC OTG Controller
Jun 24 20:17:10 TelePi kernel: [    0.756916] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
Jun 24 20:17:10 TelePi kernel: [    0.756988] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
Jun 24 20:17:10 TelePi kernel: [    0.757043] Init: Port Power? op_state=1
Jun 24 20:17:10 TelePi kernel: [    0.757049] Init: Power Port (0)
Jun 24 20:17:10 TelePi kernel: [    0.757443] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Jun 24 20:17:10 TelePi kernel: [    0.757462] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun 24 20:17:10 TelePi kernel: [    0.757474] usb usb1: Product: DWC OTG Controller
Jun 24 20:17:10 TelePi kernel: [    0.757485] usb usb1: Manufacturer: Linux 4.14.71+ dwc_otg_hcd
Jun 24 20:17:10 TelePi kernel: [    0.757495] usb usb1: SerialNumber: 20980000.usb
Jun 24 20:17:10 TelePi kernel: [    0.758578] hub 1-0:1.0: USB hub found
Jun 24 20:17:10 TelePi kernel: [    0.758684] hub 1-0:1.0: 1 port detected
Jun 24 20:17:10 TelePi kernel: [    0.760168] usbcore: registered new interface driver usb-storage
Jun 24 20:17:10 TelePi kernel: [    0.760567] mousedev: PS/2 mouse device common for all mice
Jun 24 20:17:10 TelePi kernel: [    0.760628] IR NEC protocol handler initialized
Jun 24 20:17:10 TelePi kernel: [    0.760635] IR RC5(x/sz) protocol handler initialized
Jun 24 20:17:10 TelePi kernel: [    0.760641] IR RC6 protocol handler initialized
Jun 24 20:17:10 TelePi kernel: [    0.760648] IR JVC protocol handler initialized
Jun 24 20:17:10 TelePi kernel: [    0.760653] IR Sony protocol handler initialized
Jun 24 20:17:10 TelePi kernel: [    0.760658] IR SANYO protocol handler initialized
Jun 24 20:17:10 TelePi kernel: [    0.760663] IR Sharp protocol handler initialized
Jun 24 20:17:10 TelePi kernel: [    0.760668] IR MCE Keyboard/mouse protocol handler initialized
Jun 24 20:17:10 TelePi kernel: [    0.760673] IR XMP protocol handler initialized
Jun 24 20:17:10 TelePi kernel: [    0.761956] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
Jun 24 20:17:10 TelePi kernel: [    0.762490] bcm2835-cpufreq: min=700000 max=1000000
Jun 24 20:17:10 TelePi kernel: [    0.763223] sdhci: Secure Digital Host Controller Interface driver
Jun 24 20:17:10 TelePi kernel: [    0.763235] sdhci: Copyright(c) Pierre Ossman
Jun 24 20:17:10 TelePi kernel: [    0.763837] mmc-bcm2835 20300000.mmc: could not get clk, deferring probe
Jun 24 20:17:10 TelePi kernel: [    0.764449] sdhost-bcm2835 20202000.mmc: could not get clk, deferring probe
Jun 24 20:17:10 TelePi kernel: [    0.764640] sdhci-pltfm: SDHCI platform and OF driver helper
Jun 24 20:17:10 TelePi kernel: [    0.765183] ledtrig-cpu: registered to indicate activity on CPUs
Jun 24 20:17:10 TelePi kernel: [    0.765313] hidraw: raw HID events driver (C) Jiri Kosina
Jun 24 20:17:10 TelePi kernel: [    0.765563] usbcore: registered new interface driver usbhid
Jun 24 20:17:10 TelePi kernel: [    0.765572] usbhid: USB HID core driver
Jun 24 20:17:10 TelePi kernel: [    0.766489] vchiq: vchiq_init_state: slot_zero = d7580000, is_master = 0
Jun 24 20:17:10 TelePi kernel: [    0.768412] [vc_sm_connected_init]: start
Jun 24 20:17:10 TelePi kernel: [    0.777878] [vc_sm_connected_init]: end - returning 0
Jun 24 20:17:10 TelePi kernel: [    0.778828] Initializing XFRM netlink socket
Jun 24 20:17:10 TelePi kernel: [    0.778892] NET: Registered protocol family 17
Jun 24 20:17:10 TelePi kernel: [    0.779046] Key type dns_resolver registered
Jun 24 20:17:10 TelePi kernel: [    0.780886] registered taskstats version 1
Jun 24 20:17:10 TelePi kernel: [    0.789200] uart-pl011 20201000.serial: cts_event_workaround enabled
Jun 24 20:17:10 TelePi kernel: [    0.789351] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
Jun 24 20:17:10 TelePi kernel: [    0.791879] console [ttyS0] disabled
Jun 24 20:17:10 TelePi kernel: [    0.791938] 20215040.serial: ttyS0 at MMIO 0x0 (irq = 160, base_baud = 31250000) is a 16550
Jun 24 20:17:10 TelePi kernel: [    0.792025] console [ttyS0] enabled
Jun 24 20:17:10 TelePi kernel: [    0.793766] mmc-bcm2835 20300000.mmc: mmc_debug:0 mmc_debug2:0
Jun 24 20:17:10 TelePi kernel: [    0.793785] mmc-bcm2835 20300000.mmc: DMA channel allocated
Jun 24 20:17:10 TelePi kernel: [    0.856464] sdhost: log_buf @ d7513000 (57513000)
Jun 24 20:17:10 TelePi kernel: [    0.892916] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Jun 24 20:17:10 TelePi kernel: [    0.894629] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Jun 24 20:17:10 TelePi kernel: [    0.896277] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Jun 24 20:17:10 TelePi kernel: [    0.899214] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Jun 24 20:17:10 TelePi kernel: [    0.926560] random: fast init done
Jun 24 20:17:10 TelePi kernel: [    0.942987] NOHZ: local_softirq_pending 40
Jun 24 20:17:10 TelePi kernel: [    0.943047] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Jun 24 20:17:10 TelePi kernel: [    0.964407] of_cfs_init
Jun 24 20:17:10 TelePi kernel: [    0.964542] of_cfs_init: OK
Jun 24 20:17:10 TelePi kernel: [    0.965553] Waiting for root device PARTUUID=dd3bf6a2-02...
Jun 24 20:17:10 TelePi kernel: [    0.983002] NOHZ: local_softirq_pending 40
Jun 24 20:17:10 TelePi kernel: [    1.023569] mmc1: new high speed SDIO card at address 0001
Jun 24 20:17:10 TelePi kernel: [    1.074450] mmc0: host does not support reading read-only switch, assuming write-enable
Jun 24 20:17:10 TelePi kernel: [    1.077749] mmc0: new high speed SDHC card at address aaaa
Jun 24 20:17:10 TelePi kernel: [    1.078526] mmcblk0: mmc0:aaaa SL32G 29.7 GiB
Jun 24 20:17:10 TelePi kernel: [    1.081627]  mmcblk0: p1 p2
Jun 24 20:17:10 TelePi kernel: [    1.118813] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
Jun 24 20:17:10 TelePi kernel: [    1.118829] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
Jun 24 20:17:10 TelePi kernel: [    1.324811] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
Jun 24 20:17:10 TelePi kernel: [    1.334749] EXT4-fs (mmcblk0p2): 1 orphan inode deleted
Jun 24 20:17:10 TelePi kernel: [    1.334766] EXT4-fs (mmcblk0p2): recovery complete
Jun 24 20:17:10 TelePi kernel: [    1.345505] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Jun 24 20:17:10 TelePi kernel: [    1.345600] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
Jun 24 20:17:10 TelePi kernel: [    1.346725] devtmpfs: mounted
Jun 24 20:17:10 TelePi kernel: [    1.349153] Freeing unused kernel memory: 436K
Jun 24 20:17:10 TelePi kernel: [    1.349161] This architecture does not have kernel memory protection.
Jun 24 20:17:10 TelePi kernel: [    1.980339] ip_tables: (C) 2000-2006 Netfilter Core Team
Jun 24 20:17:10 TelePi kernel: [    2.013795] random: systemd: uninitialized urandom read (16 bytes read)
Jun 24 20:17:10 TelePi kernel: [    2.081930] random: systemd: uninitialized urandom read (16 bytes read)
Jun 24 20:17:10 TelePi kernel: [    2.310878] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read)
Jun 24 20:17:10 TelePi kernel: [    3.409539] i2c /dev entries driver
Jun 24 20:17:10 TelePi kernel: [    3.832200] Installing knfsd (copyright (C) 1996 [email protected]).
Jun 24 20:17:10 TelePi kernel: [    5.847168] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Jun 24 20:17:10 TelePi kernel: [    9.682188] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
Jun 24 20:17:10 TelePi kernel: [    9.763316] bcm2835_alsa bcm2835_alsa: card created with 8 channels
Jun 24 20:17:10 TelePi kernel: [   10.364873] usbcore: registered new interface driver brcmfmac
Jun 24 20:17:10 TelePi liblogging-stdlog:  [origin software="rsyslogd" swVersion="8.24.0" x-pid="227" x-info="http://www.rsyslog.com"] start
Jun 24 20:17:12 TelePi kernel: [   15.157894] uart-pl011 20201000.serial: no DMA platform data
Jun 24 20:17:16 TelePi kernel: [   19.339162] NFSD: starting 90-second grace period (net c09b8588)
Jun 24 20:17:17 TelePi kernel: [   20.098926] Bluetooth: Core ver 2.22
Jun 24 20:17:17 TelePi kernel: [   20.099069] NET: Registered protocol family 31
Jun 24 20:17:17 TelePi kernel: [   20.099080] Bluetooth: HCI device and connection manager initialized
Jun 24 20:17:17 TelePi kernel: [   20.099111] Bluetooth: HCI socket layer initialized
Jun 24 20:17:17 TelePi kernel: [   20.099131] Bluetooth: L2CAP socket layer initialized
Jun 24 20:17:17 TelePi kernel: [   20.099205] Bluetooth: SCO socket layer initialized
Jun 24 20:17:17 TelePi kernel: [   20.207003] Bluetooth: HCI UART driver ver 2.3
Jun 24 20:17:17 TelePi kernel: [   20.207025] Bluetooth: HCI UART protocol H4 registered
Jun 24 20:17:17 TelePi kernel: [   20.207033] Bluetooth: HCI UART protocol Three-wire (H5) registered
Jun 24 20:17:17 TelePi kernel: [   20.207405] Bluetooth: HCI UART protocol Broadcom registered
Jun 24 20:17:18 TelePi kernel: [   21.188773] random: crng init done
Jun 24 20:17:18 TelePi kernel: [   21.188799] random: 7 urandom warning(s) missed due to ratelimiting
Jun 24 20:17:19 TelePi lightdm[373]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
Jun 24 20:17:20 TelePi kernel: [   23.749296] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
Jun 24 20:17:21 TelePi kernel: [   24.410458] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Jun 24 20:17:21 TelePi kernel: [   24.410474] Bluetooth: BNEP filters: protocol multicast
Jun 24 20:17:21 TelePi kernel: [   24.410503] Bluetooth: BNEP socket layer initialized
Jun 24 20:17:22 TelePi kernel: [   25.261016] Bluetooth: RFCOMM TTY layer initialized
Jun 24 20:17:22 TelePi kernel: [   25.261055] Bluetooth: RFCOMM socket layer initialized
Jun 24 20:17:22 TelePi kernel: [   25.261100] Bluetooth: RFCOMM ver 1.11
Jun 24 20:17:24 TelePi kernel: [   27.949653] brcmfmac: power management disabled
Jun 24 20:17:31 TelePi lightdm[536]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
Jun 24 20:17:33 TelePi kernel: [   36.013201] NET: Registered protocol family 3
Jun 24 20:17:33 TelePi kernel: [   36.089703] NET: Registered protocol family 5
Jun 24 20:17:37 TelePi kernel: [   40.833182] fuse init (API version 7.26)
Jun 24 20:27:20 TelePi kernel: [   81.322903] NOHZ: local_softirq_pending 02
Jun 24 20:27:30 TelePi kernel: [   91.302781] NOHZ: local_softirq_pending 42
Jun 24 20:28:11 TelePi kernel: [  131.804274] warning: `/bin/ping' has both setuid-root and effective capabilities. Therefore not raising all capabilities.
Jun 24 20:28:53 TelePi kernel: [  173.803250] NOHZ: local_softirq_pending 40
Jun 24 20:31:43 TelePi kernel: [  343.966359] NOHZ: local_softirq_pending 40
Jun 24 20:32:19 TelePi kernel: [  380.134055] NOHZ: local_softirq_pending 40
Jun 24 20:33:04 TelePi kernel: [  425.129539] NOHZ: local_softirq_pending 40
Jun 24 20:36:19 TelePi kernel: [  620.139463] NOHZ: local_softirq_pending 40
The next is in the next post
lerner
Mon Jun 24, 2019 9:18 pm
syslog:
Jun 24 16:17:02 TelePi CRON[1595]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Jun 24 17:17:01 TelePi CRON[9185]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Jun 24 18:17:01 TelePi CRON[16817]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Jun 24 19:17:01 TelePi CRON[24395]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Jun 24 20:16:29 TelePi dhcpcd[270]: wlan0: carrier lost
Jun 24 20:16:30 TelePi dhcpcd[270]: wlan0: deleting default route via 192.168.0.254
Jun 24 20:16:30 TelePi dhcpcd[270]: wlan0: deleting route to 192.168.0.0/24
Jun 24 20:16:31 TelePi dhcpcd[270]: wlan0: carrier acquired
Jun 24 20:16:31 TelePi dhcpcd[31935]: sending commands to master dhcpcd process
Jun 24 20:16:31 TelePi dhcpcd[270]: control command: /sbin/dhcpcd -k wlan0
Jun 24 20:16:31 TelePi dhcpcd[270]: wlan0: removing interface
Jun 24 20:16:31 TelePi avahi-daemon[220]: Withdrawing address record for 192.168.0.93 on wlan0.
Jun 24 20:16:31 TelePi avahi-daemon[220]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 192.168.0.93.
Jun 24 20:16:31 TelePi avahi-daemon[220]: Interface wlan0.IPv4 no longer relevant for mDNS.
Jun 24 20:16:32 TelePi dhcpcd[270]: wlan0: deleted IP address 192.168.0.93/24
Jun 24 20:17:01 TelePi CRON[32059]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Jun 24 20:17:10 TelePi blkmapd[100]: open pipe file /run/rpc_pipefs/nfs/blocklayout failed: No such file or directory
Jun 24 20:17:10 TelePi systemd-modules-load[59]: Inserted module 'i2c_dev'
Jun 24 20:17:10 TelePi systemd-udevd[105]: Network interface NamePolicy= disabled on kernel command line, ignoring.
Jun 24 20:17:10 TelePi kernel: [    0.000000] On node 0 totalpages: 98304
Jun 24 20:17:10 TelePi kernel: [    0.000000] free_area_init_node: node 0, pgdat c09c2630, node_mem_map d7c8a000
Jun 24 20:17:10 TelePi kernel: [    0.000000]   Normal zone: 864 pages used for memmap
Jun 24 20:17:10 TelePi kernel: [    0.000000]   Normal zone: 0 pages reserved
Jun 24 20:17:10 TelePi kernel: [    0.000000]   Normal zone: 98304 pages, LIFO batch:31
Jun 24 20:17:10 TelePi kernel: [    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Jun 24 20:17:10 TelePi kernel: [    0.000000] pcpu-alloc: [0] 0
Jun 24 20:17:10 TelePi kernel: [    0.756558] dwc_otg: Microframe scheduler enabled
Jun 24 20:17:10 TelePi kernel: [    0.759639] dwc_otg: FIQ enabled
Jun 24 20:17:10 TelePi kernel: [    0.759650] dwc_otg: NAK holdoff enabled
Jun 24 20:17:10 TelePi kernel: [    0.759656] dwc_otg: FIQ split-transaction FSM enabled
Jun 24 20:17:10 TelePi kernel: [    0.759674] Module dwc_common_port init
Jun 24 20:17:10 TelePi kernel: [   10.337149] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
Jun 24 20:17:10 TelePi kernel: [   10.364489] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43430-sdio.bin for chip 0x00a9a6(43430) rev 0x000001
Jun 24 20:17:10 TelePi kernel: [   10.922017] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
Jun 24 20:17:10 TelePi kernel: [   10.924658] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.39 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-10-23 03:47:14
Jun 24 20:17:10 TelePi fake-hwclock[70]: Mon 24 Jun 10:17:01 UTC 2019
Jun 24 20:17:10 TelePi systemd-fsck[89]: e2fsck 1.43.4 (31-Jan-2017)
Jun 24 20:17:10 TelePi systemd-fsck[89]: /dev/mmcblk0p2: clean, 161776/1911616 files, 1208342/7779968 blocks
Jun 24 20:17:10 TelePi systemd[1]: Started File System Check on Root Device.
Jun 24 20:17:10 TelePi systemd[1]: Starting Remount Root and Kernel File Systems...
Jun 24 20:17:10 TelePi systemd[1]: Started Remount Root and Kernel File Systems.
Jun 24 20:17:10 TelePi systemd[1]: Starting Flush Journal to Persistent Storage...
Jun 24 20:17:10 TelePi systemd[1]: Starting udev Coldplug all Devices...
Jun 24 20:17:10 TelePi systemd[1]: Starting Load/Save Random Seed...
Jun 24 20:17:10 TelePi systemd[1]: Started udev Kernel Device Manager.
Jun 24 20:17:10 TelePi systemd[1]: Started Load/Save Random Seed.
Jun 24 20:17:10 TelePi systemd[1]: Started Flush Journal to Persistent Storage.
Jun 24 20:17:10 TelePi systemd[1]: Started Set the console keyboard layout.
Jun 24 20:17:10 TelePi systemd[1]: Reached target Local File Systems (Pre).
Jun 24 20:17:10 TelePi systemd[1]: Started udev Coldplug all Devices.
Jun 24 20:17:10 TelePi systemd[1]: Starting Show Plymouth Boot Screen...
Jun 24 20:17:10 TelePi systemd[1]: Started Show Plymouth Boot Screen.
Jun 24 20:17:10 TelePi systemd[1]: Reached target Encrypted Volumes.
Jun 24 20:17:10 TelePi systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
Jun 24 20:17:10 TelePi systemd[1]: Received SIGRTMIN+20 from PID 131 (plymouthd).
Jun 24 20:17:10 TelePi systemd[1]: Found device /dev/ttyS0.
Jun 24 20:17:10 TelePi systemd[1]: Found device /dev/serial1.
Jun 24 20:17:10 TelePi systemd[1]: Found device /dev/disk/by-partuuid/dd3bf6a2-01.
Jun 24 20:17:10 TelePi systemd[1]: Starting File System Check on /dev/disk/by-partuuid/dd3bf6a2-01...
Jun 24 20:17:10 TelePi systemd-fsck[152]: fsck.fat 4.1 (2017-01-24)
Jun 24 20:17:10 TelePi systemd-fsck[152]: 0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
Jun 24 20:17:10 TelePi systemd-fsck[152]:  Automatically removing dirty bit.
Jun 24 20:17:10 TelePi systemd-fsck[152]: Performing changes.
Jun 24 20:17:10 TelePi systemd-fsck[152]: /dev/mmcblk0p1: 175 files, 45002/84273 clusters
Jun 24 20:17:10 TelePi systemd[1]: Started File System Check on /dev/disk/by-partuuid/dd3bf6a2-01.
Jun 24 20:17:10 TelePi systemd[1]: Mounting /boot...
Jun 24 20:17:10 TelePi systemd[1]: Mounted /boot.
Jun 24 20:17:10 TelePi systemd[1]: Reached target Local File Systems.
Jun 24 20:17:10 TelePi systemd[1]: Starting Raise network interfaces...
Jun 24 20:17:10 TelePi systemd[1]: Starting Set console font and keymap...
Jun 24 20:17:10 TelePi systemd[1]: Starting Preprocess NFS configuration...
Jun 24 20:17:10 TelePi systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
Jun 24 20:17:10 TelePi systemd[1]: Starting Create Volatile Files and Directories...
Jun 24 20:17:10 TelePi systemd[1]: Started Set console font and keymap.
Jun 24 20:17:10 TelePi systemd[1]: Started Preprocess NFS configuration.
Jun 24 20:17:10 TelePi systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
Jun 24 20:17:10 TelePi systemd[1]: Started Create Volatile Files and Directories.
Jun 24 20:17:10 TelePi systemd[1]: Starting Network Time Synchronization...
Jun 24 20:17:10 TelePi systemd[1]: Starting RPC bind portmap service...
Jun 24 20:17:10 TelePi systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Jun 24 20:17:10 TelePi systemd[1]: Starting NFSv4 ID-name mapping service...
Jun 24 20:17:10 TelePi systemd[1]: Reached target NFS client services.
Jun 24 20:17:10 TelePi systemd[1]: Started NFSv4 ID-name mapping service.
Jun 24 20:17:10 TelePi rpcbind[199]: cannot create socket for udp6
Jun 24 20:17:10 TelePi rpcbind[199]: cannot create socket for tcp6
Jun 24 20:17:10 TelePi systemd[1]: Started RPC bind portmap service.
Jun 24 20:17:10 TelePi systemd[1]: Started Update UTMP about System Boot/Shutdown.
Jun 24 20:17:10 TelePi systemd[1]: Reached target RPC Port Mapper.
Jun 24 20:17:10 TelePi systemd[1]: Started Network Time Synchronization.
Jun 24 20:17:10 TelePi systemd[1]: Reached target System Initialization.
Jun 24 20:17:10 TelePi systemd[1]: Listening on CUPS Scheduler.
Jun 24 20:17:10 TelePi systemd[1]: Started Daily Cleanup of Temporary Directories.
Jun 24 20:17:10 TelePi systemd[1]: Listening on triggerhappy.socket.
Jun 24 20:17:10 TelePi systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Jun 24 20:17:10 TelePi systemd[1]: Started CUPS Scheduler.
Jun 24 20:17:10 TelePi systemd[1]: Reached target Paths.
Jun 24 20:17:10 TelePi systemd[1]: Listening on D-Bus System Message Bus Socket.
Jun 24 20:17:10 TelePi systemd[1]: Reached target Sockets.
Jun 24 20:17:10 TelePi systemd[1]: Reached target Basic System.
Jun 24 20:17:10 TelePi systemd[1]: Starting triggerhappy global hotkey daemon...
Jun 24 20:17:10 TelePi systemd[1]: Starting Disable WiFi if country not set...
Jun 24 20:17:10 TelePi systemd[1]: Starting System Logging Service...
Jun 24 20:17:10 TelePi thd[222]: Found socket passed from systemd
Jun 24 20:17:10 TelePi systemd[1]: Starting Check for v3d driver...
Jun 24 20:17:10 TelePi systemd[1]: Starting Login Service...
Jun 24 20:17:10 TelePi systemd[1]: Starting dhcpcd on all interfaces...
Jun 24 20:17:10 TelePi systemd[1]: Started Node-RED graphical event wiring tool.
Jun 24 20:17:11 TelePi systemd[1]: Starting Save/Restore Sound Card State...
Jun 24 20:17:11 TelePi systemd[1]: Starting Configure Bluetooth Modems connected by UART...
Jun 24 20:17:11 TelePi systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Jun 24 20:17:11 TelePi systemd[1]: Started D-Bus System Message Bus.
Jun 24 20:17:11 TelePi dhcpcd[240]: dev: loaded udev
Jun 24 20:17:11 TelePi dhcpcd[240]: no valid interfaces found
Jun 24 20:17:11 TelePi dhcpcd[240]: forked to background, child pid 254
Jun 24 20:17:11 TelePi avahi-daemon[248]: Found user 'avahi' (UID 108) and group 'avahi' (GID 112).
Jun 24 20:17:11 TelePi avahi-daemon[248]: Successfully dropped root privileges.
Jun 24 20:17:11 TelePi avahi-daemon[248]: avahi-daemon 0.6.32 starting up.
Jun 24 20:17:12 TelePi avahi-daemon[248]: Successfully called chroot().
Jun 24 20:17:12 TelePi avahi-daemon[248]: Successfully dropped remaining capabilities.
Jun 24 20:17:12 TelePi avahi-daemon[248]: No service file found in /etc/avahi/services.
Jun 24 20:17:12 TelePi dbus[250]: [system] Successfully activated service 'org.freedesktop.systemd1'
Jun 24 20:17:12 TelePi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Jun 24 20:17:12 TelePi avahi-daemon[248]: socket() failed: Address family not supported by protocol
Jun 24 20:17:12 TelePi avahi-daemon[248]: Failed to create IPv6 socket, proceeding in IPv4 only mode
Jun 24 20:17:12 TelePi systemd[1]: Started Make remote CUPS printers available locally.
Jun 24 20:17:12 TelePi systemd[1]: Started Regular background program processing daemon.
Jun 24 20:17:12 TelePi avahi-daemon[248]: Network interface enumeration completed.
Jun 24 20:17:12 TelePi systemd[1]: Reached target System Time Synchronized.
Jun 24 20:17:12 TelePi avahi-daemon[248]: Server startup complete. Host name is TelePi.local. Local service cookie is 2298403704.
Jun 24 20:17:12 TelePi systemd[1]: apt-daily.timer: Adding 3h 45min 42.711727s random time.
Jun 24 20:17:12 TelePi systemd[1]: Started Daily apt download activities.
Jun 24 20:17:12 TelePi cron[290]: (CRON) INFO (pidfile fd = 3)
Jun 24 20:17:12 TelePi systemd[1]: apt-daily-upgrade.timer: Adding 40min 9.821204s random time.
Jun 24 20:17:13 TelePi systemd[1]: Started Daily apt upgrade and clean activities.
Jun 24 20:17:13 TelePi cron[290]: (CRON) INFO (Running @reboot jobs)
Jun 24 20:17:13 TelePi systemd[1]: Reached target Timers.
Jun 24 20:17:13 TelePi systemd[1]: Started triggerhappy global hotkey daemon.
Jun 24 20:17:13 TelePi systemd[1]: Started System Logging Service.
Jun 24 20:17:13 TelePi systemd[1]: Started Disable WiFi if country not set.
Jun 24 20:17:13 TelePi systemd[1]: Started Check for v3d driver.
Jun 24 20:17:13 TelePi systemd[1]: Started dhcpcd on all interfaces.
Jun 24 20:17:13 TelePi systemd[1]: Started Save/Restore Sound Card State.
Jun 24 20:17:13 TelePi systemd[1]: Started Login Service.
Jun 24 20:17:14 TelePi systemd[1]: Started Raise network interfaces.
Jun 24 20:17:14 TelePi systemd[1]: Reached target Network.
Jun 24 20:17:14 TelePi systemd[1]: Starting OpenBSD Secure Shell server...
Jun 24 20:17:14 TelePi systemd[1]: Starting /etc/rc.local Compatibility...
Jun 24 20:17:14 TelePi systemd[1]: Starting NFS Mount Daemon...
Jun 24 20:17:14 TelePi rpc.mountd[302]: rpc.mountd: svc_tli_create: could not open connection for udp6
Jun 24 20:17:14 TelePi rpc.mountd[302]: Failed to create listener xprt (mountd, 1, udp6)
Jun 24 20:17:14 TelePi rpc.mountd[302]: rpc.mountd: svc_tli_create: could not open connection for tcp6
Jun 24 20:17:14 TelePi rpc.mountd[302]: Failed to create listener xprt (mountd, 1, tcp6)
Jun 24 20:17:15 TelePi rpc.mountd[302]: rpc.mountd: svc_tli_create: could not open connection for udp6
Jun 24 20:17:15 TelePi rpc.mountd[302]: Failed to create listener xprt (mountd, 2, udp6)
Jun 24 20:17:15 TelePi rpc.mountd[302]: rpc.mountd: svc_tli_create: could not open connection for tcp6
Jun 24 20:17:15 TelePi rpc.mountd[302]: Failed to create listener xprt (mountd, 2, tcp6)
Jun 24 20:17:15 TelePi rpc.mountd[302]: Failed to create listener xprt (mountd, 3, udp6)
Jun 24 20:17:15 TelePi rpc.mountd[302]: Failed to create listener xprt (mountd, 3, tcp6)
Jun 24 20:17:15 TelePi rpc.mountd[321]: Version 1.3.3 starting
Jun 24 20:17:15 TelePi systemd[1]: Started NFS Mount Daemon.
Jun 24 20:17:15 TelePi systemd[1]: Starting NFS server and services...
Jun 24 20:17:16 TelePi systemd[1]: Started OpenBSD Secure Shell server.
Jun 24 20:17:16 TelePi systemd[1]: Started NFS server and services.
Jun 24 20:17:16 TelePi systemd[1]: Reached target Remote File Systems (Pre).
Jun 24 20:17:16 TelePi systemd[1]: Reached target Remote File Systems.
Jun 24 20:17:16 TelePi systemd[1]: Starting Permit User Sessions...
Jun 24 20:17:16 TelePi systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
Jun 24 20:17:16 TelePi systemd[1]: Starting LSB: Starts and stops Wicd...
Jun 24 20:17:16 TelePi systemd[1]: Starting LSB: Autogenerate and use a swap file...
Jun 24 20:17:16 TelePi systemd[1]: Started Permit User Sessions.
Jun 24 20:17:16 TelePi systemd[1]: Starting Light Display Manager...
Jun 24 20:17:17 TelePi systemd[1]: Created slice User Slice of pi.
Jun 24 20:17:17 TelePi systemd[1]: Starting User Manager for UID 1000...
Jun 24 20:17:17 TelePi systemd[1]: Started Session c1 of user pi.
Jun 24 20:17:17 TelePi btuart[247]: bcm43xx_init
Jun 24 20:17:17 TelePi btuart[247]: Flash firmware /lib/firmware/brcm/BCM43430A1.hcd
Jun 24 20:17:17 TelePi btuart[247]: Set BDADDR UART: b8:27:eb:d0:70:a8
Jun 24 20:17:17 TelePi btuart[247]: Set Controller UART speed to 3000000 bit/s
Jun 24 20:17:17 TelePi btuart[247]: Device setup complete
Jun 24 20:17:17 TelePi systemd[1]: Started Configure Bluetooth Modems connected by UART.
Jun 24 20:17:18 TelePi dphys-swapfile[352]: Starting dphys-swapfile swapfile setup ...
Jun 24 20:17:19 TelePi systemd[1]: Reached target Sound Card.
Jun 24 20:17:19 TelePi systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Jun 24 20:17:19 TelePi raspi-config[349]: Checking if shift key is held down:Error opening '/dev/input/event*': No such file or directory
Jun 24 20:17:19 TelePi raspi-config[349]:  No. Switching to ondemand scaling governor.
Jun 24 20:17:19 TelePi systemd[1]: Starting Load/Save RF Kill Switch Status...
Jun 24 20:17:19 TelePi systemd[365]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Jun 24 20:17:19 TelePi systemd[365]: Starting D-Bus User Message Bus Socket.
Jun 24 20:17:19 TelePi systemd[365]: Reached target Timers.
Jun 24 20:17:19 TelePi systemd[365]: Reached target Paths.
Jun 24 20:17:19 TelePi systemd[365]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Jun 24 20:17:19 TelePi systemd[365]: Listening on GnuPG cryptographic agent and passphrase cache.
Jun 24 20:17:19 TelePi systemd[365]: Listening on GnuPG cryptographic agent (access for web browsers).
Jun 24 20:17:19 TelePi systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
Jun 24 20:17:19 TelePi systemd[365]: Listening on D-Bus User Message Bus Socket.
Jun 24 20:17:20 TelePi dphys-swapfile[352]: want /var/swap=100MByte, checking existing: keeping it
Jun 24 20:17:20 TelePi systemd[365]: Reached target Sockets.
Jun 24 20:17:20 TelePi systemd[365]: Reached target Basic System.
Jun 24 20:17:20 TelePi systemd[365]: Reached target Default.
Jun 24 20:17:20 TelePi systemd[365]: Startup finished in 2.168s.
Jun 24 20:17:20 TelePi systemd[1]: Started User Manager for UID 1000.
Jun 24 20:17:20 TelePi systemd[1]: Received SIGRTMIN+21 from PID 131 (plymouthd).
Jun 24 20:17:20 TelePi systemd[1]: Created slice system-bthelper.slice.
Jun 24 20:17:20 TelePi systemd[1]: Starting Bluetooth service...
Jun 24 20:17:20 TelePi systemd[1]: Started Light Display Manager.
Jun 24 20:17:20 TelePi dphys-swapfile[352]: done.
Jun 24 20:17:20 TelePi systemd[1]: Started LSB: Autogenerate and use a swap file.
Jun 24 20:17:21 TelePi systemd[1]: Started Load/Save RF Kill Switch Status.
Jun 24 20:17:21 TelePi bluetoothd[421]: Bluetooth daemon 5.43
Jun 24 20:17:21 TelePi systemd[1]: Started Bluetooth service.
Jun 24 20:17:21 TelePi systemd[1]: Reached target Bluetooth.
Jun 24 20:17:21 TelePi systemd[1]: Started BluezALSA proxy.
Jun 24 20:17:21 TelePi bluetoothd[421]: Starting SDP server
Jun 24 20:17:21 TelePi systemd[1]: Started Raspberry Pi bluetooth helper.
Jun 24 20:17:21 TelePi bluetoothd[421]: Bluetooth management interface 1.14 initialized
Jun 24 20:17:21 TelePi bluetoothd[421]: Failed to obtain handles for "Service Changed" characteristic
Jun 24 20:17:21 TelePi bluetoothd[421]: Sap driver initialization failed.
Jun 24 20:17:21 TelePi bluetoothd[421]: sap-server: Operation not permitted (1)
Jun 24 20:17:21 TelePi dbus[250]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
Jun 24 20:17:21 TelePi bluetoothd[421]: Failed to set mode: Blocked through rfkill (0x12)
Jun 24 20:17:21 TelePi bthelper[428]: Can't init device hci0: Operation not possible due to RF-kill (132)
Jun 24 20:17:21 TelePi systemd[1]: [email protected]: Main process exited, code=exited, status=1/FAILURE
Jun 24 20:17:21 TelePi systemd[1]: [email protected]: Unit entered failed state.
Jun 24 20:17:21 TelePi systemd[1]: [email protected]: Failed with result 'exit-code'.
Jun 24 20:17:22 TelePi systemd[1]: Starting Hostname Service...
Jun 24 20:17:22 TelePi bluetoothd[421]: Endpoint registered: sender=:1.12 path=/A2DP/SBC/Source/1
Jun 24 20:17:22 TelePi dhcpcd-run-hooks[453]: wlan0: starting wpa_supplicant
Jun 24 20:17:22 TelePi systemd-udevd[123]: Process '/sbin/crda' failed with exit code 249.
Jun 24 20:17:23 TelePi dbus[250]: [system] Successfully activated service 'org.freedesktop.hostname1'
Jun 24 20:17:23 TelePi systemd[1]: Started Hostname Service.
Jun 24 20:17:23 TelePi systemd-udevd[123]: Process '/sbin/crda' failed with exit code 249.
Jun 24 20:17:27 TelePi rc.local[301]: New 'X' desktop is TelePi:1
Jun 24 20:17:27 TelePi rc.local[301]: Starting applications specified in /home/pi/.vnc/xstartup
Jun 24 20:17:27 TelePi rc.local[301]: Log file is /home/pi/.vnc/TelePi:1.log
Jun 24 20:17:27 TelePi systemd[1]: Started /etc/rc.local Compatibility.
Jun 24 20:17:27 TelePi systemd[1]: Starting Terminate Plymouth Boot Screen...
Jun 24 20:17:27 TelePi systemd[1]: Starting Hold until boot process finishes up...
Jun 24 20:17:27 TelePi systemd[1]: Started Terminate Plymouth Boot Screen.
Jun 24 20:17:27 TelePi systemd[1]: Started Hold until boot process finishes up.
Jun 24 20:17:27 TelePi dhcpcd[254]: wlan0: waiting for carrier
Jun 24 20:17:27 TelePi dhcpcd[254]: wlan0: carrier acquired
Jun 24 20:17:28 TelePi systemd[1]: Started Getty on tty1.
Jun 24 20:17:28 TelePi dhcpcd[254]: wlan0: carrier lost
Jun 24 20:17:28 TelePi systemd[1]: Started Serial Getty on ttyS0.
Jun 24 20:17:28 TelePi systemd[1]: Reached target Login Prompts.
Jun 24 20:17:28 TelePi dhcpcd[254]: wlan0: carrier acquired
Jun 24 20:17:28 TelePi systemd[365]: Started D-Bus User Message Bus.
Jun 24 20:17:28 TelePi dhcpcd[254]: wlan0: probing address 192.168.0.93/24
Jun 24 20:17:31 TelePi wicd[350]: Starting Network connection manager: wicd.
Jun 24 20:17:31 TelePi systemd[1]: Started LSB: Starts and stops Wicd.
Jun 24 20:17:31 TelePi systemd[1]: Reached target Multi-User System.
Jun 24 20:17:31 TelePi systemd[1]: Reached target Graphical Interface.
Jun 24 20:17:31 TelePi systemd[1]: Starting Update UTMP about System Runlevel Changes...
Jun 24 20:17:31 TelePi systemd[1]: Started Update UTMP about System Runlevel Changes.
Jun 24 20:17:31 TelePi systemd[1]: Startup finished in 1.821s (kernel) + 32.900s (userspace) = 34.722s.
Jun 24 20:17:32 TelePi systemd[1]: Started Session c2 of user pi.
Jun 24 20:17:32 TelePi lightdm[373]: Error opening audit socket: Protocol not supported
Jun 24 20:17:33 TelePi dhcpcd[254]: wlan0: received approval for 192.168.0.93
Jun 24 20:17:33 TelePi avahi-daemon[248]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.0.93.
Jun 24 20:17:33 TelePi dhcpcd[254]: wlan0: adding route to 192.168.0.0/24
Jun 24 20:17:33 TelePi dhcpcd[254]: wlan0: adding default route via 192.168.0.254
Jun 24 20:17:33 TelePi avahi-daemon[248]: New relevant interface wlan0.IPv4 for mDNS.
Jun 24 20:17:33 TelePi avahi-daemon[248]: Registering new address record for 192.168.0.93 on wlan0.IPv4.
Jun 24 20:17:35 TelePi dhcpcd[254]: wlan0: received approval for 192.168.0.93
Jun 24 20:17:36 TelePi dbus-daemon[515]: Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service'
Jun 24 20:17:36 TelePi systemd[365]: Starting Virtual filesystem service...
Jun 24 20:17:37 TelePi dbus-daemon[515]: Successfully activated service 'org.gtk.vfs.Daemon'
Jun 24 20:17:37 TelePi systemd[365]: Started Virtual filesystem service.
Jun 24 20:17:38 TelePi systemd[1]: Mounting FUSE Control File System...
Jun 24 20:17:38 TelePi systemd[1]: Mounted FUSE Control File System.
Jun 24 20:26:43 TelePi systemd-timesyncd[198]: Synchronized to time server 203.122.222.157:123 (2.debian.pool.ntp.org).
Jun 24 20:26:43 TelePi systemd[365]: Time has been changed
Jun 24 20:26:43 TelePi systemd[1]: Time has been changed
Jun 24 20:26:43 TelePi systemd[1]: apt-daily.timer: Adding 8h 4min 32.658489s random time.
Jun 24 20:26:43 TelePi systemd[1]: apt-daily-upgrade.timer: Adding 16min 41.576387s random time.
Jun 24 20:26:46 TelePi dbus[250]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service'
Jun 24 20:26:46 TelePi systemd[1]: Starting Authorization Manager...
Jun 24 20:26:47 TelePi polkitd[806]: started daemon version 0.105 using authority implementation `local' version `0.105'
Jun 24 20:26:47 TelePi dbus[250]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Jun 24 20:26:47 TelePi systemd[1]: Started Authorization Manager.
Jun 24 20:26:59 TelePi dbus-daemon[515]: Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monitor.service'
Jun 24 20:26:59 TelePi systemd[365]: Starting Virtual filesystem service - disk device monitor...
Jun 24 20:27:00 TelePi dbus[250]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service'
Jun 24 20:27:00 TelePi systemd[1]: Starting Disk Manager...
Jun 24 20:27:00 TelePi udisksd[878]: udisks daemon version 2.1.8 starting
Jun 24 20:27:02 TelePi dbus[250]: [system] Successfully activated service 'org.freedesktop.UDisks2'
Jun 24 20:27:03 TelePi systemd[1]: Started Disk Manager.
Jun 24 20:27:03 TelePi udisksd[878]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Jun 24 20:27:04 TelePi dbus-daemon[515]: Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor'
Jun 24 20:27:04 TelePi systemd[365]: Started Virtual filesystem service - disk device monitor.
Jun 24 20:27:04 TelePi dbus-daemon[515]: Activating via systemd: service name='org.gtk.vfs.GoaVolumeMonitor' unit='gvfs-goa-volume-monitor.service'
Jun 24 20:27:05 TelePi systemd[365]: Starting Virtual filesystem service - GNOME Online Accounts monitor...
Jun 24 20:27:05 TelePi dbus-daemon[515]: Successfully activated service 'org.gtk.vfs.GoaVolumeMonitor'
Jun 24 20:27:05 TelePi systemd[365]: Started Virtual filesystem service - GNOME Online Accounts monitor.
Jun 24 20:27:05 TelePi dbus-daemon[515]: Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.service'
Jun 24 20:27:05 TelePi systemd[365]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
Jun 24 20:27:06 TelePi dbus-daemon[515]: Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor'
Jun 24 20:27:06 TelePi systemd[365]: Started Virtual filesystem service - Media Transfer Protocol monitor.
Jun 24 20:27:06 TelePi dbus-daemon[515]: Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monitor.service'
Jun 24 20:27:06 TelePi systemd[365]: Starting Virtual filesystem service - digital camera monitor...
Jun 24 20:27:07 TelePi dbus-daemon[515]: Successfully activated service 'org.gtk.vfs.GPhoto2VolumeMonitor'
Jun 24 20:27:07 TelePi systemd[365]: Started Virtual filesystem service - digital camera monitor.
Jun 24 20:27:07 TelePi dbus-daemon[515]: Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.service'
Jun 24 20:27:07 TelePi systemd[365]: Starting Virtual filesystem service - Apple File Conduit monitor...
Jun 24 20:27:07 TelePi gvfs-afc-volume-monitor[917]: Volume monitor alive
Jun 24 20:27:07 TelePi dbus-daemon[515]: Successfully activated service 'org.gtk.vfs.AfcVolumeMonitor'
Jun 24 20:27:07 TelePi systemd[365]: Started Virtual filesystem service - Apple File Conduit monitor.
Jun 24 20:27:12 TelePi Node-RED[243]: 24 Jun 20:27:11 - [info]
Jun 24 20:27:12 TelePi Node-RED[243]: Welcome to Node-RED
Jun 24 20:27:12 TelePi Node-RED[243]: ===================
Jun 24 20:27:12 TelePi Node-RED[243]: 24 Jun 20:27:12 - [info] Node-RED version: v0.20.5
Jun 24 20:27:12 TelePi Node-RED[243]: 24 Jun 20:27:12 - [info] Node.js  version: v8.12.0
Jun 24 20:27:12 TelePi Node-RED[243]: 24 Jun 20:27:12 - [info] Linux 4.14.71+ arm LE
Jun 24 20:27:21 TelePi Node-RED[243]: 24 Jun 20:27:21 - [info] Loading palette nodes
Jun 24 20:27:43 TelePi Node-RED[243]: Traceback (most recent call last):
Jun 24 20:27:43 TelePi Node-RED[243]:   File "<string>", line 1, in <module>
Jun 24 20:27:43 TelePi Node-RED[243]: ImportError: No module named rpi_ws281x
Jun 24 20:27:43 TelePi Node-RED[243]: 24 Jun 20:27:43 - [warn] rpi-neopixels : Raspberry Pi specific node set inactive
Jun 24 20:27:45 TelePi Node-RED[243]: 24 Jun 20:27:45 - [info] Dashboard version 2.15.4 started at /ui
Jun 24 20:27:50 TelePi Node-RED[243]: 24 Jun 20:27:50 - [info] Settings file  : /home/pi/.node-red/settings.js
Jun 24 20:27:50 TelePi Node-RED[243]: 24 Jun 20:27:50 - [info] HTTP Static    : /home/pi/.node-red/public
Jun 24 20:27:50 TelePi Node-RED[243]: 24 Jun 20:27:50 - [info] Context store  : 'default' [module=memory]
Jun 24 20:27:50 TelePi Node-RED[243]: 24 Jun 20:27:50 - [info] User directory : /home/pi/.node-red
Jun 24 20:27:50 TelePi Node-RED[243]: 24 Jun 20:27:50 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
Jun 24 20:27:50 TelePi Node-RED[243]: 24 Jun 20:27:50 - [info] Flows file     : /home/pi/.node-red/flows_TelePi.json
Jun 24 20:27:52 TelePi Node-RED[243]: 24 Jun 20:27:52 - [info] Server now running at http://127.0.0.1:1880/
Jun 24 20:27:56 TelePi Node-RED[243]: 24 Jun 20:27:56 - [info] Starting flows
Jun 24 20:28:07 TelePi Node-RED[243]: 24 Jun 20:28:07 - [info] Started flows
Jun 24 20:28:10 TelePi Node-RED[243]: 24 Jun 20:28:10 - [warn] [function:3f894e5e.00c832] Control signal received GO
Jun 24 20:28:10 TelePi Node-RED[243]: 24 Jun 20:28:10 - [warn] [function:46b61bd7.8aef54] Control signal received GO
Jun 24 20:28:12 TelePi Node-RED[243]: 24 Jun 20:28:12 - [info] [mqtt-broker:MQTT host] Connected to broker: mqtt://192.168.0.99:1883
Jun 24 20:28:55 TelePi systemd[1]: Started Session c3 of user pi.
