jtloper1
Loop Trouble(s)
Fri Jun 21, 2019 8:13 am
The primary purpose of this script is to call the sh file "print" which resides in another directory when a GPIO button is pressed. The secondary function is to display instructions and feedback on a 16x2 LCD. When the script loads the LCD displays "READY" as expected. When the button is pressed the print script runs (sometimes more that once, stupid button bounce) as expected however, the LCD displays "PRINTING" indifferently. What I need to for the LCD to display "READY" after printing has completed.
#!/usr/bin/env python
import daemon
import RPi.GPIO as GPIO
import time
import subprocess
import os
import I2C_LCD_driver
mylcd = I2C_LCD_driver.lcd()
mylcd.lcd_display_string("READY", 1)
def button_handler(pin):
    print("pin %s's value is %s" % (pin, GPIO.input(pin)))
#    mylcd.lcd_clear()
    mylcd.lcd_display_string("PRINTING", 1)
    os.chdir("/media/pi/BB2B-791B/sandwich")
   os.system("sh print")
    time.sleep(10)
    mylcd.lcd_clear()
if __name__ == '__main__':
    button_pin = 10
    GPIO.setmode(GPIO.BOARD)
    GPIO.setup(button_pin, GPIO.IN, pull_up_down = GPIO.PUD_DOWN)
    # events can be GPIO.RISING, GPIO.FALLING, or GPIO.BOTH
    GPIO.add_event_detect(button_pin, GPIO.BOTH,
                          callback=button_handler,
                          bouncetime=300)
    try:
        time.sleep(1000)
    except KeyboardInterrupt:
        GPIO.cleanup()
PeterO
Re: Loop Trouble(s)
Fri Jun 21, 2019 8:27 am
Did you mean "indefinitely" ?
PeterO
ghp
Re: Loop Trouble(s)
Fri Jun 21, 2019 9:06 am
Hello, instead of using os.system("sh print"), try to switch to subprocess.Popen:
import subprocess
p = subprocess.Popen("sh print.sh", shell=True)
p.wait()
print("ok")
My print.sh is:
echo "start "
sleep 10
echo "stop"
Paeryn
Re: Loop Trouble(s)
Fri Jun 21, 2019 10:16 am
import daemon
import time
import subprocess
import os
#    mylcd.lcd_clear()
    time.sleep(10)
    mylcd.lcd_clear()
    button_pin = 10
                          bouncetime=300)
    try:
        time.sleep(1000)
        GPIO.cleanup()
Your code, as given, doesn't print anything to the LCD after the printing is done, rather it just clears the display (if the lcd_clear() is doing what it says). What you need is to print the READY message when it is done. You really need to put some code in there so that multiple presses don't cause the function to run multiple times at once, e.g. a global variable that you set when the function starts and clears when it finishes, if it's already set when the function is called you can ignore it.
I just noticed, you have the callback set to occur on both rising and falling edges of the gpio, that will call the function when the button is pressed and again when it is released, is this intended?
printer_busy = False
    global printer_busy
    if printer_busy:
        # Already printing, do nothing
        return
    printer_busy = True
#    mylcd.lcd_clear()
    time.sleep(10)
    mylcd.lcd_clear()
jtloper1
Re: Loop Trouble(s)
Wed Jun 26, 2019 1:08 am
Thanks much it works! :)
Return to “Python”
