addison45
How do I configure GPIO of the ELB-REV4?
Thu Jun 20, 2019 11:10 am
I need to make several digital interfaces for controlling
drgeoff
Re: How do I configure GPIO of the ELB-REV4?
Thu Jun 20, 2019 12:19 pm
This forum supports RPi products and their uses. The ELB-REV4 does not appear to fit into those categories.
https://drive.google.com/file/d/10qSPFX ... k5Nea/view
LTolledo
Thu Jun 20, 2019 12:48 pm
could be spam post....
Some people be like:
Thu Jun 20, 2019 12:53 pm
Will keep an eye on it...
addison45
Thu Jun 20, 2019 1:22 pm
Sorry guys i did not mean to spam but i wanted to know how can i interface Raspberry pi with ELB-REV4. Since ELB-REV4 uses UART i am connecting RPi UART to ELB-REV4 but the communication does seem to work
Rogger-78
Thu Jun 20, 2019 1:27 pm
The reason why you do not see the UART of RPi communicating with ELB-REV4 is because UART of ELB-REV4 uses 5V data signal which is mostly used for industrial purpose. But if you want to want to communicate between the 2 then just convert 3.3V data output of the RPi to 5V data output. using some FTDI chips present online you can use this chipset https://www.reichelt.at/entwicklerboard ... D_BwE&&r=1
B.Goode
Thu Jun 20, 2019 1:40 pm
The Raspberry Pi Foundation documentation concerning the UART Interface built in to the RPi board is here: https://www.raspberrypi.org/documentati ... on/uart.md
Note the warning about potentially dangerous and incompatible signal levels.
alexandrajacobs1996
Sun Jun 30, 2019 5:01 am
On ELB-REV4 you can configure any GPIO pin to turn on/off or to generate PWM needed for your application. there are example code present in the path /builds/SCADA/filesystem/usr/scada/led you can see example code to turn on/off GPIO or to generate PWM.
Regards
Alexandra Jacobs
