rmunny
scipy.signals import issue
Thu Jun 20, 2019 7:10 am
I am having an issue importing find_peaks from scipy.
Following are the things I'm importing:
import numpy as np
import pywt
import pathlib
#import scipy.signal as signal
from scipy.signal import butter, lfilter
from scipy.signal import find_peaks
And that's the error I am getting in the attachment. Anyone can help me how to fix it?
Thanks!
saltydog
Re: scipy.signals import issue
Thu Jun 20, 2019 8:56 am
What version scipy are you using?
rmunny
Thu Jun 20, 2019 6:44 pm
I am new on this platform. Not sure if that's the right way to check the version. Attached the snapshot
I understand I have to upgrade the version to use find_peaks. But I don't know how to do it. I am using raspberry pi 3 B+. Any suggestion?
saltydog
Thu Jun 20, 2019 11:35 pm
The debian repo's are going to be a long way behind. You would need to build from source. I wasn't successful last time I tried.
Others have been. See:
https://raspberrypi.stackexchange.com/q ... spberry-pi
Chris
Return to “Python”
