Re: Lance a script automatically that logs my raspberry pi3 to my server
Tue Jun 18, 2019 12:56 pm
The boot partition contains the Linux kernel, so it needs to be updated when the OS is upgraded.
topguy
Tue Jun 18, 2019 12:57 pm
so my bootloader partition is untouchable, i want only the meta data to get replaced by the new ones
Then you should first stop using the word "image", because most of us interpret that as a disk-image used to write over all the data on an SD-card including boot partition and partition-tables.
Ernst
Tue Jun 18, 2019 1:59 pm
igyigy wrote:
Tue Jun 18, 2019 12:50 pm
I expect to have a bootloader dependant partition
and the meta data in another partition
Do you know what the meaning is of metadata ? see https://en.wikipedia.org/wiki/Metadata
Tue Jun 18, 2019 2:50 pm
igyigy wrote:
Tue Jun 18, 2019 9:43 am
Thank you all
I still have a question
i want you to imagine a software that enables an OS installation automatically, knowing that the os image is stored somewhere in my raspberry pi.
I want you to suggest an archiitecture for doing this so i can have an idea
I know there are experts among us :p
You should really have started a new thread for a new question, but will leave as is now, since its had a load of responses so people know where the thread is.
Andyroo
Tue Jun 18, 2019 4:37 pm
I would look at software such as NOOBS in Github and modify that so it looks for a new OS and updates it.
You do realise that ALL programs loaded by APT / PIP etc and any data created will be wiped as well as the OS don't you?
You could look to get very cleaver and mount the home folder on another partition and auto-reinstall the programs / data files but this is no minor task to do via a manually created program.
I would look to use something like Puppet for the configuration or possibly FAI (Fully Automatic Installation) for OS and config.
edit: Added link to NOOBs in GITHUB and removed waffle
B.Goode
Tue Jun 18, 2019 4:51 pm
I don't need to 'imagine': your requirement seems to be met by PINN which has its own persistent thread in these forums. The developer of PINN, regular forum contributor @procount, is indeed very knowledgeable on such matters.
Return to “Raspbian”
