melchett
art project with a traffic light
Mon Jun 17, 2019 6:58 am
For an art project I want to control a traffic light with a raspberry Pi (it’s on a remote site, so both powered with batteries).
I am not a noob with electronics but I am a noob with Raspberry Pi and Python.
I have three questions, which I hope at least one I can get help with.
Question 1: how to program the Pi, so the light functions like in a standard traffic situation(green-orange-red) in a continous loop.
Question 2: how to program the Pi, so the light reacts on a proximity sensor (PIR) and performs a predetermined sequence of light flashes.
Question 3: the lamps are changed with led matrixes, how to program the Pi, so the light reacts on a proximity sensor (PIR), and the traffic light show a predetermined list of words.
If I could get any guidance, I would be very grateful
pcmanbob
Re: art project with a traffic light
Mon Jun 17, 2019 9:47 am
As a starting point why not take a look at the physical computing lessons on the raspberry pi site it includes making traffic lights using LED's as one of the lessons.
https://projects.raspberrypi.org/en/pro ... mputing/11
then I suggest you do some searching on the web you will find lots of examples of traffic lights controlled by a pi.
gordon77
Mon Jun 17, 2019 11:27 am
This may get you started.
viewtopic.php?t=223659
Change the buttons to pirs, they may need inverting
try this...
from gpiozero import LED
from gpiozero import Button
from time import sleep
red1     = LED(23) # RED set 1
amber1   = LED(24) # AMBER set 1
green1   = LED(25) # GREEN set 1
red2     = LED(5)  # RED set 2
amber2   = LED(6)  # AMBER set 2
green2   = LED(13) # GREEN set 2
p_red1   = LED(8)  # pedestrian RED (DON'T WALK) light, set 1
p_green1 = LED(27) # pedestrian GREEN (WALK) light, set 1
p_red2   = LED(19) # pedestrian RED (DON'T WALK)light, set 2
p_green2 = LED(26) # pedestrian GREEN (WALK) light, set 1
p_set1   = LED(12) # Pedestrian WAIT LED 1, acknowledges pir detection
p_set2   = LED(22) # Pedestrian WAIT LED 2, acknowledges pir detection
PIR1 = Button( 7,pull_up = False,bounce_time= None)
PIR2 = Button(16,pull_up = False,bounce_time= None)
# initialise
red2.on()
amber2.off()
green2.off()
red1.on()
amber1.off()
green1.off()
p_red1.on()
p_red2.on()
p_green1.off()
p_green2.off()
p_set1.off()
p_set2.off()
def Light_Sequence(red,amber,green):
   amber.on()
   sleep(2)
   red.off()
   amber.off()
   green.on()
   sleep(10)
   green.off()
   amber.on()
   sleep(2)
   amber.off()
   red.on()
   sleep(1)
def PED_PIR(x): # pedestrian PIR detected
   global PED
   PED = 1
   p_set1.on() # WAIT LED 1
   p_set2.on() # WAIT LED 2
def PED_Crossing():
   p_set1.off()
   p_set2.off()
   p_green1.on()
   p_green2.on()
   p_red1.off()
   p_red2.off()
   sleep(3)
   for led in range (0, 10):
      p_green1.off()
      p_green2.off()
      sleep(.1)
      p_green1.on()
      p_green2.on()
      sleep(.1)
   p_green1.off()
   p_green2.off()
   p_red1.on()
   p_red2.on()
   sleep(1)
x = 0
PED = 0
PIR1.when_pressed = PED_PIR
PIR2.when_pressed = PED_PIR
while True:
   # traffic lights set 1 sequence
   Light_Sequence(red1,amber1,green1)
   # pedestrian crossing,if either button has been pressed
   if PED == 1:
      PED_Crossing()
      PED = 0
   # traffic lights set 2 sequence
   Light_Sequence(red2,amber2,green2)
   if PED == 1:
      PED_Crossing()
      PED = 0
boyoh
Mon Jun 17, 2019 5:01 pm
“I am not an electronics noob, but I am a PI noob “
First the Pi is not plug & play, A start on
Learning some basic electronics is your
First move. Script / and programming is
Only useful if it as something to do and
Control, Controlling traffic light comes
Under understanding Combinational Logic
Down load a Combination logic truth table,
Then You will have some idea what you
are doing, Copying a circuit is ok if it works
first time, If it don’t then you are in TROUBLE
Regards BoyOh
BoyOh ( Selby, North Yorkshire.UK)
Some Times Right Some Times Wrong
melchett
Mon Jun 17, 2019 6:43 pm
thanks pcmanbob and Gordon77 for the help and hints,
I had a look and I think it can take me where I wantto be in this short amount of time.
@BoyOh: I hear what you are saying, and although learning the basics of PI and Python before jumping into this bath is the preferred way, I do not have the time, I am asking this question to fulfill my art project I have no desire in becoming a skilled python programmer. But again, thanks for your advice
greetings
thomas
Return to “Staffroom, classroom and projects”
