teyk
camera not working on clean install
Fri Jun 14, 2019 1:05 pm
Good morning,
I'm having a lot of trouble with a picam noir. When I use raspistill:
mmal: Cannot read camera info, keeping the defaults for OV5647
mmal: mmal_vc_component_create: failed to create component 'vc.ril.camera' (1:ENOMEM)
mmal: mmal_component_create_core: could not create component 'vc.ril.camera' (1)
mmal: Failed to create camera component
mmal: main: Failed to create camera component
mmal: Camera is not detected. Please check carefully the camera module is installed correctly
vcgencmd get_camera returns supported=-1 detected=0
I2C and camera are activated in raspi-config
I'm on new install with updates done on a raspberry pi 3B+
gkaiseril
Re: camera not working on clean install
Fri Jun 14, 2019 2:45 pm
Can you use the Pi camera?
Make sure the contacts on the ribbon cable are matched to the contact pins in the camera socket at both ends. Also make sure the cables are properly aligned and not an an angle.
f u cn rd ths, u cn gt a gd jb n cmptr prgrmmng.
B.Goode
Fri Jun 14, 2019 2:49 pm
The Raspberry Pi Foundation documentation for the Camera Module, including Troubleshooting, is here: https://www.raspberrypi.org/documentati ... /camera.md
Return to “Camera board”
