miky94
picamera minimize power consumption
Fri Jun 14, 2019 11:21 am
hope this is the right forum
I'm developing a timelapse camera using camera module v1, I take a picture every 10 seconds and I was wondering if to use stop_preview() after each shot and then start_preview() 2 seconds before the next could make my battery last longer.
also how can I detect when there's low light? for example reading the value of each pixel to see how many are over a black threshold?
HermannSW
Re: picamera minimize power consumption
Fri Jun 14, 2019 3:09 pm
I doubt that you can increase battery lifetime much with that, since no Pi model has any sleep modes like ESPs or Arduinos.
In "1W server challenge" thread I first measured an ESP32-CAM module to use 186mA at 3.3V only:
viewtopic.php?t=238870#p1461306
I was totally surprised that Pi0W with a simple USB webcam only uses 0.253A at 3.3V, which is 0.835W and below 1W:
viewtopic.php?f=36&t=238870&start=50#p1463371
I did not measured Raspberry camera power consumption sofar.
bookmark list: https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://github.com/Hermann-SW/userland
https://twitter.com/HermannSW
miky94
Sun Jun 16, 2019 11:16 pm
of course we are talking about a few milliamps, but I think while the preview is stopped the Pi is not elaborating, right?
in fact I read here https://projects.raspberrypi.org/en/pro ... picamera/6 that it is important to sleep for at least 2 seconds before capturing, to give the sensor time to set its light levels.
probably using a 10s lapse it doesn't make much difference but at 30s interval would be more significant
I read here https://www.raspberrypi.org/documentati ... /#pi-power the Camera Module requires 250mA
do you know how to detect darkness?
Return to “Camera board”
