athanasios
Porting C++ code to the Raspberry Pi
Tue Jun 11, 2019 5:33 pm
Hello everyone.
I am trying to port a program originally compiled in Windows to the Raspberry Pi 3 model B+, running Raspbian. I understand the basics in Linux and was able to compile and run "Hello world", but have no real experience with C++ or the Raspberry Pi.
The source code I need to compile is meant to read data packets arriving at the Pi's Ethernet port from a data acquisition board. I am trying to compile this using Geany, and get lot's of errors, see compiler output appended below.
Can someone help me in any way resolve these errors?
In file included from Multiplicity.cpp:5:0:
DetectorParameters.h:43:2: error: ‘CStringA’ does not name a type
CStringA BoatDataIP;
Multiplicity.cpp:290:55: error: expected ‘,’ or ‘...’ before ‘mult_array_in’
void Multiplicity::update_prob_array(unsigned __int64 mult_array_in[], double prob_array_out[], int len)
Multiplicity.cpp:290:6: error: prototype for ‘void Multiplicity::update_prob_array(unsigned int)’ does not match any in class ‘Multiplicity’
In file included from Multiplicity.cpp:4:0:
Multiplicity.h:68:7: error: candidate is: void Multiplicity::update_prob_array(long long unsigned int*, double*, int)
void update_prob_array(unsigned long long mult_array_in[], double prob_array_out[], int len);
Multiplicity.cpp: In member function ‘void Multiplicity::display_mult(double)’:
Multiplicity.cpp:419:2: error: ‘CString’ was not declared in this scope
CString str;
Multiplicity.cpp:421:10: error: expected ‘;’ before ‘msg’
CString msg=L"Multiplicity Distributions @ Collection Time = ";
Multiplicity.cpp:424:2: error: ‘str’ was not declared in this scope
str.Format(L"%.1f sec\n\n",time);
Multiplicity.cpp:425:2: error: ‘msg’ was not declared in this scope
msg += str;
Multiplicity.cpp:436:3: error: ‘__int64’ was not declared in this scope
__int64 r_plus_a = this->mult_dist_ra;
Multiplicity.cpp:437:11: error: expected ‘;’ before ‘a’
__int64 a = this->mult_dist_a;
Multiplicity.cpp:439:31: error: ‘r_plus_a’ was not declared in this scope
str.Format(L"%d \t\t%ld",i, r_plus_a);
Multiplicity.cpp:441:27: error: ‘a’ was not declared in this scope
str.Format(L"\t\t%ld\n",a);
Multiplicity.cpp:462:23: error: ‘MB_OK’ was not declared in this scope
if(AfxMessageBox(msg,MB_OK|MB_ICONINFORMATION))
Multiplicity.cpp:462:29: error: ‘MB_ICONINFORMATION’ was not declared in this scope
Multiplicity.cpp:462:47: error: ‘AfxMessageBox’ was not declared in this scope
Multiplicity.cpp: At global scope:
Multiplicity.cpp:471:61: error: expected ‘,’ or ‘...’ before ‘arr’
int Multiplicity::get_effective_array_size(unsigned __int64 arr[], int max_len)
Multiplicity.cpp:471:5: error: prototype for ‘int Multiplicity::get_effective_array_size(unsigned int)’ does not match any in class ‘Multiplicity’
Multiplicity.h:82:6: error: candidate is: int Multiplicity::get_effective_array_size(long long unsigned int*, int)
int get_effective_array_size(unsigned long long arr[], int max_len);
markkuk
Re: Porting C++ code to the Raspberry Pi
Tue Jun 11, 2019 9:29 pm
The code you are trying to compile is written for Microsoft Windows and the Microsoft Visual C++ compiler. All the errors are from types and funtions that are specific to the Microsoft environment and not parts of the standard C++ language. You need to remove all Windows-specific code and write equivalent code that works in Linux.
athanasios
Thu Jun 13, 2019 12:41 pm
OK, thank you, this makes sense.
athanasios
Thu Jun 13, 2019 4:41 pm
Markkuk,
Would you be interested in consulting for us on this matter?
Thu Jun 13, 2019 5:01 pm
Wine is not an emulator might help: https://www.winehq.org
Wine is normally used to run Windows applications on Intel x86 PC's running Linux.
But wine comes with a library, libwine, that provides Windows API. That means you can compile your Windows program on Linux. Provided it does not use any API functions that libwine does not support it should work.
I have done this some years ago. As an experiment I wrote a simple win32 application with dialog boxes, text inputs, buttons etc. I compiled it with Wine on Linux. It worked very well.
I have no idea if this will also work on a Raspberry Pi but it might be worth a try.
athanasios
Thu Jun 13, 2019 5:05 pm
Ok, thank you Heater.
Return to “C/C++”
