TomT
Mercury32 MailServer
Thu Nov 29, 2012 6:12 pm
Hi
Would it be possible to run Mercury23 MailServer on a Raspberry Pi ?
Mercury32 normally run on Windows, but also works fine under Wine.
Anyway it would work ?
I like it's very simple setup and interface..hence I would like to use it if I can.
bgirardot
Re: Mercury32 MailServer
Thu Nov 29, 2012 8:14 pm
I do not think you will be able to run it on the raspberry pi.
WINE does not run on the Raspberry Pi except via an x86 emulator and even then it does not really run unless you can edit the source code yourself to figure out the patches you need.
You can probably find a simple email server for linux that does run on raspberry pi, but I do not know one off the top of my head that falls into the "simple" category unfortunately.
