algorithm
ENOSPC error but plenty space
Sat Jun 01, 2019 6:29 pm
I just did a fresh install of Raspbian Lite on a 8 GB card, updated, installed some stuff (ffmpeg and imagemagick from the repo, some utilities of my own) and now I have still 5.3 GB free (checked via df -h). I also tried "dd if=/dev/urandom of=test.bin bs=1M count=1000" and broke it off when I became impatient, size of the new file was 422 MB. So files can be written. Camera is set up via raspi-config and "vcgencmd get_camera" gives supported=1,detected=1. This is on a Zero W without the hardware error: "vcgencmd otp_dump | grep ^30" gives 30:009000c1. Then as a last resort because the error text suggested checking for firmware updates, I did rpi-update. But still every time I try raspistill -o test.jpg, I get
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn't be enabled
mmal: main: Failed to create camera component
mmal: Failed to run camera app. Please check for firmware updates
raspistill version info: commit 7cbfbd38d982 Tainted (error was the same with the stock raspistill after dist-upgrade but I didn't check that version number, sorry).
Any ideas?
B.Goode
Re: ENOSPC error but plenty space
Sat Jun 01, 2019 10:12 pm
The Raspberry Pi Foundation documentation for the Camera Module, including Troubleshooting, is here: https://www.raspberrypi.org/documentati ... /camera.md
The No Space error you are encountering is almost certainly NOT referring to 'disc' space.
algorithm
Mon Jun 03, 2019 8:07 am
I tried to preempt an "rtfm" answer by providing all the info but apparently I failed :) I said I used raspi-config to set up the camera, so yeah, config.txt has gpu_mem=128. The only option the troubleshooting page leaves me is: your hardware is broken.
Which is strange because, like I said, vcgencmd get_camera does say supported=1,detected=1. So why the specific ENOSPC error, which doesn't seem hardware related, for a hardware fault?
Anyway, I'm back home with several other Pis and cameras to swap with, and eliminate possible failure modes. Maybe it is a hardware fault ¯\_(ツ)_/¯
6by9
Mon Jun 03, 2019 9:32 am
When and where was the module bought?
See viewtopic.php?f=43&t=239893 as there have been a batch that are incorrectly programmed and would exhibit this failure mode.
algorithm
Mon Jun 03, 2019 1:57 pm
I bought it a fair while ago (some years), it has worked before, so I don't think it's that. I guess it could be fried by 24/7/365 use as a webcam..., but I thought the error was strange in combination with supported/detected=1, suggesting to me it wasn't the hardware. Haven't had a chance to swap with other Pi/camera yet, sorry.
Mon Jun 03, 2019 2:47 pm
I bought it a fair while ago (some years), it has worked before, so I don't think it's that. I guess it could be fried by 24/7/365 use as a webcam..., but I thought the error was strange in combination with supported/detected=1, suggesting to me it wasn't the hardware. Haven't had a change to swap with other Pi/camera yet, sorry.
Unplug both ends fo the ribbon cable and reseat, then the tiny plug connecting the sensor to the camera PCB, and reseat. Might just be a digy connection.
Return to “Camera board”
