vofdoom
Run Script at Startup
Thu May 30, 2019 8:34 pm
I've seen this problem a million times and read a lot of posts about it, but it seems like everyone else is trying to do something a lot more complicated than I. All I want to do is have VLC start in full screen and load all the files in a directory into the playlist. I thought that the easiest way to do with was making a little script that ran at start up but I can't seem to get it work. When I try to simply execute the script raspbian asks me if it's and executable script and what to do with it, and I have to click "Execute" then it runs, that's about as far as I've gotten. My script is on the desktop:
#!/bin/sh
# start VLC
vlc --fullscreen "/media/pi/Room media center"
exit 0
I tried the two methods I have seen the most adding a line to both rc.local and .bashrc with the script in the home folder, neither worked. I am an absolute beginner so I know I am missing something simple. If there is an even easier way to do this, I'm all for that as well.
pcmanbob
Re: Run Script at Startup
Fri May 31, 2019 8:24 am
Hi.
The first thing you need to do is make your bash script executable using chmod
use of chmod is explained here https://alvinalexander.com/linux-unix/l ... irectories
Now to start your script , the use of rc.local and .bashrc is are suitable because they run scripts in the background and you want to run your script in the gui ( desktop) so you need to run the script after the gui has started.
To do that you need to add you script to the “LXDE” autostart file.
This is explained here https://www.raspberrypi-spy.co.uk/2014/ ... e-desktop/
ricardoaraujo00
Thu Jul 02, 2020 8:59 am
You just have to edit this file
sudo nano .config/lxsession/LXDE-pi/autostart
Add this command to run a script (in this example is called shboot.sh)
@lxterminal -e /home/pi/shboot.sh
Inside that script(shboot.sh) put what you want and make it executable with "sudo chmod 755 filename"
I put those kind of scripts(shboot.sh) in my home folder..
Now it will run on LXDE desktop startup
klricks
Thu Jul 02, 2020 3:16 pm
By default RPi OS uses the global autostart here:
/etc/xdg/lxsession/LXDE-pi/autostart
Optionally if you prefer to create a local autostart then use this:
/home/pi/.config/lxsession/LXDE-pi/autostart
I think the user will need to manually create /lxsession/LXDE-pi/ directories as they don't exist by default in the users .config directory.
If the local autostart is used then it is very important that the contents of the global autostart be copied to the local autostart.
If not done then the desktop will not start properly. Note that the global autostart is completely ignored if a local autstart exists.
For most it is much easier to use the global autostart.
Return to “Beginners”
