MrBool
Two LAN9514, one crystal oscillator
Wed May 29, 2019 1:33 pm
I would like to use two LAN9514 with CM3. Is possible to clock them both with one crystal oscillator? For the first one I will use crystal oscillator, not signal from CM3.
I noticed that LAN9514 has 24MHz reference clock output but it is not useful for the second LAN9514 because it needs 25 MHz.
Re: Two LAN9514, one crystal oscillator
Wed May 29, 2019 1:49 pm
Recently another developer had a similar requirement:
viewtopic.php?f=98&t=239594
Retired disgracefully.....
hippy
Wed May 29, 2019 4:27 pm
It may be possible to take XO from the one with the crystal and feed that to the XI of the one without. That may require a buffer. Otherwise use an oscillator module and feed its output to both XI.
Return to “Compute Module”
