sushant_ocv
initializing multi dim array R PI
Tue May 28, 2019 10:22 am
Can someone provide an example to initialize multi dimensional array.
topguy
Re: initializing multi dim array R PI
Tue May 28, 2019 10:44 am
radapa
Sat May 30, 2020 8:22 pm
Multidimensional array initialization using dynamic memory allocation in C Programming
a = (int **)malloc(rows * sizeof(int *));
for (i = 0; i < rows; i++)
a = (int *)malloc(cols * sizeof(int));
Source: https://kodebinary.com/c-program-to-dyn ... ry-arrays/
Sun May 31, 2020 10:49 pm
The question is about Java radapa.
Besides your example is not even a 2d array as far as I am concerned. It's a 1D array of pointers to other 1D arrays. Rather than being a 2d array in contiguous memory.
If you declare you array correctly you can allocate it in one go like so:
array = int (*)[COLS] malloc(ROWS*COLS*sizeof(int))
And then initialize it with a single call to memset or whatever you like.
A proper contiguous 2d array will be much faster for large arrays.
jalih
Mon Jun 01, 2020 1:25 pm
Damn, that looks ugly... ;)
PL/I got it right over 60 years ago...
dcl p pointer;
dcl array(100, 100) fixed bin(31) based(p);
allocate array;
Sorry, for side tracking from Java...
Return to “Java”
