sweetpi
Is it possible to have Acess Point and Wifi at the same time?
Mon May 27, 2019 11:26 pm
I'm trying to use Wifi and AP to make a wireless router, so the idea is let the wifi act as internet access and boradcast with AP :D
epoch1970
Re: Is it possible to have Acess Point and Wifi at the same time?
Tue May 28, 2019 12:26 pm
I assume you mean from the built in adapter in Pi?
If you don’t want to waste your time, consider it is not possible.
It is possible using one USB adapter in addition to the built in one.
Some USB adapters will be capable of running in AP+STA mode, it depends on the hardware.
mkirk
Wed Jul 17, 2019 8:13 pm
Any recommended suppliers of USB WiFi adapters supporting AP+STA simultaneous mode? Also would want SMA or u.FL connector for external antenna.
Andyroo
Wed Jul 17, 2019 8:27 pm
Find an adapter that handles the AP functions as this will give less limits than a dual one. The driver on the Pi is limited - have a read through https://www.raspberrypi.org/forums/view ... 3&t=241223
davidcoton
Wed Jul 17, 2019 9:17 pm
That would invalidate the Pi's UK, EU and USA approvals. It can result in unfriendly visits from the men in black.
EDIT: Sorry, socketed aerial on an external adapter (if designed that way) is OK. It is modification of the Pi that causes approval issues.
Signature retired
Andyroo
Wed Jul 17, 2019 9:39 pm
If adapter is connected via USB and has an option of an external antenna then as long as the antenna is approved for that device then it (and the Pi) will remain legal.
Modification of the Pi results in an illegal device (and the thread locked normally).
You do have to be careful that the antenna are matched as that causes both interference and illegal operating conditions - no buying from eBay or Amazon - go to a retailer who can advise you. Or buy a real AP :lol:
Edit: added text in italics :oops:
davidcoton
Wed Jul 17, 2019 11:17 pm
Correct. My statement was based on NOT noticing that the post I quoted was not from the same poster as the OP. :oops: Will edit my post.
You do have to be careful that the antenna are matched as that mismatch causes both interference and illegal operating conditions - no buying from eBay or Amazon - go to a retailer who can advise you. Or buy a real AP :lol:
FTFY
Signature retired
Andyroo
Wed Jul 17, 2019 11:22 pm
Lift foot, remove gun from holster, point gun at foot, pull trigger till foot hurts :oops:
:lol:
Ta for the correction.
