ttwr
Internet on Compute Module 3 via USB Hub with ethernet
Mon May 27, 2019 4:28 pm
Hi guys,
i'm a bit familiar with Raspberry but I try for the very first time to manage a compute module 3 (with memory on it).
I've the CMIO card, my issue is to succeed to access to internet for the first steps of configuration, i've a USB Hub + Ethernet, and i've try most of the technics i've seen on internet, but i still not succeed to connect internet from my CM3.
Btw, i've installed raspbian Stretch Desktop Version (the tiny one, not with all software), with etcher from a macbook. I've try to change the files into the boot partition, dtoverlay and so on, but i'm a bit confused, i still don't know if it's the correct way to do it with compute module 3 Vs Pi Zero or pi 3 B.
My bad if the correct information already exists, i've try to reach it, without success.
Thanks to all, take care.
TTWR
Re: Internet on Compute Module 3 via USB Hub with ethernet
Mon May 27, 2019 6:26 pm
Hi guys,
TTWR
You need a Compute Model base board, see:
https://www.raspberrypi.org/documentati ... /README.md
adieu
Asus CS10 Chromebit / HP Envy 4500 Wireless Printer / Raspberry Pi Model 2B v1.1 / RealVNC Software...
Mon May 27, 2019 7:57 pm
Also known as a CMIO board as mentioned in the original post.
W. H. Heydt
Mon May 27, 2019 8:57 pm
You configure config.txt and cmdline.txt the same way you do with any other Pi. They're located in /boot. Use your preferred editor and do the editing as root.
Tue May 28, 2019 6:01 am
The OP wrote CMIO card
adieu
Tue May 28, 2019 7:03 am
Semantics. :lol:
ttwr
Wed May 29, 2019 4:25 pm
Hi everyone, i'm more advanced than two days before, thanks to all. I still got some issues.
At each reboot, my RPi 3 compute module add one route (that i can see with route -n), with a new IP Adress, i have to change my configuration network in my OSX system preferences and change the router from 192.168.7.0 to 192.168.3.0.
Then i have an internet connexion on RPi, i can ping the web from my Pi, i can connect in ssh from my mac, that's perfect.
But it not stay like this more than a minute, then i lose the connexion on both devices (RPI and macbook), i've to change the router again, it's rework fine, and again i ve the problem.
For information i've tried and succeed to delete the new route, it doesn't change anything, the Pi Compute Module recreate a new one, and i've to switch again, eternally.
Do you know if there is a solution (fix IP adress or something else) to avoid this behavior?
Return to “Compute Module”
