joseplaselva
Question about Tkinter text widged in scrolledtext
Sun May 19, 2019 1:42 pm
I would like to know if it is a way of dysplay the lines from top to botton in a scrolledtext widget. Now when I write a line appears allways in the top when the first one appears in the botton. When I write on a simple text widget appears in the other way, the last line is allways at the botton...
Thanks if some one can make me see the light :-)
Paeryn
Re: Question about Tkinter text widged in scrolledtext
Sun May 19, 2019 4:11 pm
Your description is a bit confusing,
When you say write do you mean inserting text from within your program or do you mean typing text into the widget? Either way a ScrolledText widget should handle writes exactly like a Text widget does as that is what that area is.
The ScrolledText widget is just three widgets combined: a text widget, a scrollbar widget and a frame widget enclosing the text and scrollbar. The ScrolledText widget behaves like a Text widget, the only difference is that the scrollbar can change what part of the text is visible when there is more text than it can display.
joseplaselva
Sun May 19, 2019 4:20 pm
Hi , thanks for fast reply.
The text is writing by scrip as folow :
    def write_line(self):
        global display_event
        timenu = str(time.strftime("%y-%m-%d %H:%M:%S"))
        texte = timenu + "  " + display_event + " \n"
        self.textEvents.insert("1.0", texte)
        self.textEvents.update_idletasks()
joseplaselva
Sun May 19, 2019 4:23 pm
and appears in the widget as folow :
19-05-19 18:20:45  =Check: Succeed mailed
19-05-19 18:20:39  =Check: Camera:19-May-19_(182036)
19-05-19 18:20:36  =Check: Down 1.35 Mbit | Up:0.75 Mbit
19-05-19 18:20:00  =Check: IP: 87.125.68.81
19-05-19 18:13:02  Starting survey every 5 minutes...
19-05-19 18:13:02  == Initial procedures acomplished ==
19-05-19 18:13:02  ...Succeed sending mail
19-05-19 18:12:56  Preparing to send Start-mail...
19-05-19 18:12:56  Test ok 19-May-19_(181254).jpg
19-05-19 18:12:54  Checking  camera...
19-05-19 18:12:54  Down:1.37 Mbit/s | Up:0.74 Mbit/s
19-05-19 18:12:17  Checking internet speed...
19-05-19 18:12:17  IP: 87.125.68.81
19-05-19 18:12:16  Checking internet connection...
19-05-19 18:12:16  ==Starting initial procedures==
Paeryn
Sun May 19, 2019 5:20 pm
The "1.0" in the insert function says to insert the text at line 1 column 0, i.e. before anything else. To insert at the very end use
        self.textEvents.insert(tk.END, texte)
joseplaselva
Sun May 19, 2019 5:30 pm
Thanks a lot , now run perfectly.
Have a nice sunday evening... and thanks again for your kind help
Cheers
Paeryn
Sun May 19, 2019 5:40 pm
Glad I could help, have fun.
Return to “Python”
