msmithy12
UART
Wed Nov 28, 2012 10:17 am
Ok, so i wanna start using the UART pins on the GPIO (GPIO14,15) and i just wanna start walking by looping the tx and rx and sending data to and from my PI.
In a future far far away i plan on having a C program running with an interrupt that is started from a serial command. (but i dont wanna be spoon fed) i just wanna start using UART and build up slowly.
My question is after physically looping TX and RX then what do i do? ( i haven't looped TX and RX in case i need to put something between them)
Thanks in advance
Matt
I assume I know what I`m talking about... I probably don`t
Home: 256mb Made in UK, Rasbmc, 40" Sony Bravia KDL-40v3000
Work: 2b+, Rasbian, 6" Lilliput touchscreen
msmithy12
Re: UART
Thu Nov 29, 2012 3:26 pm
OK, so i got a bit further with this:
I ran the following code in terminal:
echo - "sent from pi" > /dev/ttvAMA0
and all i got was
bash: /dev/ttyAMA0: Permission denied
so i tried
sudo echo - "sent from pi" > /dev/ttvAMA0
same error
I guessing i have a command wrong somewhere, any help?
(also noticing 50 views no replies: am i being stupid is this something that should be easier and people dont wanna offend me, please offend away I'm thick / thick skinned
Matt
stedew
Re: UART
Thu Nov 29, 2012 7:27 pm
ok to be not the 51the in your list:
the builtin serial port is imho (i 'am not a expert neither) used for the logon console.
you have that one turned of becuase the serial is "owned" by the bootloader/kernel (getty)
some ideas are in viewtopic.php?f=44&t=17360
Hope this one helps,
cheers.
tedhale
Re: UART
Thu Nov 29, 2012 8:11 pm
stedew is correct, another process already has the device open, so you get that error.
Look at my blog post
http://raspberrypihobbyist.blogspot.com ... -port.html
Look at the 2nd half of the post for instructions on how to "free up" the serial port.
- Ted B. Hale
tedhale
Re: UART
Thu Nov 29, 2012 8:15 pm
BTW,
you will see a lot of views and few posts because most people coming here are looking for answers, not giving them out.
Most likely, the first 50 viewers had no clue how to solve your problem.
I read this forum for two reasons
1. I need to find answers myself sometimes, but mostly
2. I enjoy helping people, so I look for new posts that I can add info to.
- Ted B. Hale
msmithy12
Re: UART
Fri Nov 30, 2012 9:07 am
thanks guys!
Modified those 2 files and everything works great
http://raspberrypihobbyist.blogspot.co.uk has some great stuff if any1 is reading this looking for similar solutions give that page a look
msmithy12
Re: UART
Thu Dec 13, 2012 10:57 am
wiringPi has a serial out command that i have found, so if your reading this looking for some sample C code check out
https://projects.drogon.net/raspberry-p ... mment-1116
Gordon floats around the forum so he might pick up questions but his website/blog is so comprehensive I have learnt some great stuff C programming wise!
Joe Schmoe
Re: UART
Thu Dec 13, 2012 11:36 am
Sort of appropos of nothing, but...
Nobody has commented on this, so I'll pipe in. Note that:
sudo echo foo > /dev/ttyAMA0
won't do what you expect it to, because the shell redirection is performed by your local shell, not by the command run under sudo.
You can verify this by doing (assuming, of course, that plugh doesn't already exist):
sudo touch /tmp/plugh
sudo echo test > /tmp/plugh # Fails
sudo bash
echo test > /tmp/plugh # works
exit
thivtulz
Re: UART
Wed Mar 13, 2013 8:37 am
my objective is want to display the output in my laptop...
this is my coding..
import serial
ser = serial.Serial("/dev/ttyAMA0",9600)
ser.write("My String outputto serial port")
is there any mistake in my coding.Thanks .
thivtulz
Re: UART
Wed Mar 13, 2013 10:31 am
how to receive data from terminal to the raspberry pi through UART.?
techpaul
Re: UART
Wed Mar 13, 2013 1:17 pm
How have you connected the Pi to the PC/Laptop?
It needs an RS232 converter between GPIO UART and PC/Laptop?
Have you disabled the kernel from using the GPIO UART?
This is detailed in many places and posts in this thread.
Just another techie on the net - For GPIO boards see http:///www.facebook.com/pcservicesreading
or http://www.pcserviceselectronics.co.uk/pi/
Piciu
Re: UART
Sun Mar 24, 2013 1:34 pm
By the way, it's not
It's
echo - "sent from pi" > /dev/ttyAMA0
Difference is in the name of the port ( I guess it's a port) ;)
There is ttY, not ttV. Maybe someone will have this problem in future.
FTrevorGowen
Re: UART
Sun Mar 24, 2013 3:32 pm
thivtulz wrote: my objective is want to display the output in my laptop...
FWIW (and slightly off-topic) Whilst I havn't done anything much with the Pi's own UART (yet - I'm just starting to do "GPIO things" "at the mo.") I did test out a USB - RS232 cable a while ago and logged it as "working" in the wiki. Some pictures & screenshots etc. are at http://www.cpmspectrepi.webspace.virgin ... apter.html where I'm using a ancient serial printer/terminal to display the output etc. There's also some general "RS232" stuff elsewhere in my webpages that goes "way back".
Trev.
Still running Raspbian Jessie on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W) but Stretch on my 2xP3A+, P3B+, P3B, B+, A+ and a B2. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
vijay_nav
Re: UART
Wed Oct 23, 2013 5:57 am
please help me how to work with uart in raspberry pi....
please provide some projects or some links regarding uart in raspberry pi...........by using python scripting
DeeJay
Re: UART
Wed Oct 23, 2013 9:10 am
Try a Google search for "raspberry uart python"
These hits look useful -
https://sites.google.com/site/semillero ... rials/gpio
http://www.stuffaboutcode.com/2013/09/r ... ython.html
CopterRichie
Re: UART
Thu Jan 02, 2014 2:28 pm
Hello one and all, I have a question please. I would like to use the Raspberry Pi to program an Arduino chip directly using /dev/ttyAMA0 however, the Arduino requires the DTR to be toggled prior to uploading the code. So, which GPIO pin on the Raspberry Pi correspond to the DTR?
Thank you.
I will be using the Arduino IDE on the Raspberry PI for programming.
joan
Re: UART
Thu Jan 02, 2014 3:31 pm
CopterRichie wrote:Hello one and all, I have a question please. I would like to use the Raspberry Pi to program an Arduino chip directly using /dev/ttyAMA0 however, the Arduino requires the DTR to be toggled prior to uploading the code. So, which GPIO pin on the Raspberry Pi correspond to the DTR?
Thank you.
I'm not sure the Pi's UART supports DTR.
Regardless of that can you not choose any spare gpio and call that DTR, i.e. connect it to the Arduino and toggle the line in your code?
CopterRichie
Re: UART
Thu Jan 02, 2014 4:21 pm
joan wrote: I'm not sure the Pi's UART supports DTR.
I located the following but not sure how to implement it.
http://www.raspberrypi.org/phpBB3/viewt ... 241#p39241
joan
Re: UART
Thu Jan 02, 2014 4:33 pm
The solution in the other thread seems to require changing gpios 16/17 to an ALT mode (Alt 5, CTS/RTS) and using them as DSR/DTR.
I don't see the point. To my mind it's simpler to toggle a gpio.
Anyhow there are C libraries to allow you to set the ALT modes if that's what you want to do.
CopterRichie
Re: UART
Thu Jan 02, 2014 5:45 pm
I think but not sure, the Arduino IDE toggles both the DTR and the CTS lines. So I might be ok, will have to test to be sure.
Thank you for the assistance.
Richard-TX
Re: UART
Thu Jan 02, 2014 5:52 pm
I am going out on a limb anticipating the nest question.
To change the speed of the uart one has to open the device and then change the speed using an ioctl call or issue a stty command depending on the programming language. Closing the device and reopening it results in it reverting back to the default settings.
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
shyamgeek
Re: UART
Mon May 08, 2017 5:28 pm
For those wanting a python way to program Raspberry Pi for UART
http://radiostud.io/understanding-raspb ... unication/
Re: UART
Tue May 09, 2017 8:59 am
Some docs here, but this is a very old thread...
https://www.raspberrypi.org/documentati ... on/uart.md
