Madtom
Slow Raspi 3b+
Thu May 16, 2019 3:03 pm
Brought my pi a few months ago. Taken ages to set up but when I did it's very very slow!! Wifi doesn't work on it and everything takes about 5 minutes to open. I've got a 128gb sd card in there which I partitioned but still hasn't helped. Any advice would greatly appreciated!
B.Goode
Re: Slow Raspi 3b+
Thu May 16, 2019 5:36 pm
Welcome to the Raspberry Pi forums.
Perhaps begin by explaining which Operating System you have installed on your RPi?
Since appropriate partitions are normally configured by the NOOBS or PINN Installers, or by 'flashing' an Operating System image, what is your special requirement and how have you manually partitioned your microSD card?
The built-in WiFi network interface is supported under Raspbian and should work straightforwardly. What sort of 'everything' do you have in mind when you say "everything takes about 5 minutes to open".
LTolledo
Re: Slow Raspi 3b+
Fri May 17, 2019 10:53 am
To me.... it seems you're describing a boot up of an I5-8250U equipped Win10 pc, because that's the amount (or probably more) of time I have to wait in order to just open up a new excel file..... and type any info into it....
But I can immediately open a new LibreOffice Calc file in under 2 minutes after turning on the power switch of my RPi3B+ "multimedia" desktop .....
Some people be like:
Moonmarch
Re: Slow Raspi 3b+
Fri May 17, 2019 2:31 pm
On Raspbian OS, you can open "Task Manager" using the Ctrl+Alt+Del keyboard command, similar to what is available in Windows, to see which programs are using the most system resources, within "Task Manager," you can see how much RAM is available on the computer. You can run the "htop" utility to see CPU load per CPU, you can see which CPU is being utilized the most, you can install "htop" using the terminal with the command:
sudo apt-get install htop
sudo htop
Not every program is multi threaded, uses more than 1 CPU, for the RPI3, if CPU usage is at 25% all the time, that means only 1 CPU is being used. Using lighter weight programs can lower CPU usage, using a email client program on the RPI is faster than using the Outlook website within a web browser for emails.
Re: Slow Raspi 3b+
Fri May 17, 2019 2:36 pm
Is your SD Card genuine ??
adieu
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Buster.
Raspberry Pi Model 2B v1.1
