Daveolw1
tkinter Text Widget putting "{}" around text I insert
Thu May 16, 2019 10:40 am
Using Raspberry pi 3 Python and tkinter GUI and reading from file and inserting in Text Widget, but the text is wrapped by curly brackets and it also shows the text 4 times.
My code:-
from tkinter import *
root = Tk()
T = Text(root, height=40, width=100)
T.pack()
f = open('/home/pi/Documents/song1.txt', 'r')
f1 = f.readlines()
for x in f1:
    T.insert("1.0", f1)
mainloop()
Output:-
{ABIDE WITH ME, fast falls the eventide;
} {The darkness deepens, Lord, with me abide;
} {When other helpers fail and comforts flee,
} {Help of the helpless, O abide with me.}{ABIDE WITH ME, fast falls the eventide;
} {Help of the helpless, O abide with me.}[
The file song1.txt:-
Why is it putting "{}" around the lines, how do I remove them?
Why is it repeating the 4 lines 4 times?
Thanks for any help David.
Andyroo
Re: tkinter Text Widget putting "{}" around text I insert
Thu May 16, 2019 12:02 pm
My first thought is the braces are the cr/lf at the end of each line
If you use
f1 = f.readline()
You will read each line at a time. The you need to use the replace command to strip them out.
As for showing it four times thats due to the for loop and the insert of the wrong item.
You are looping with 'x' in f1 - f1 contains four line so the loop goes around four time BUT you add the full text in to the box by referencing f1 in the insert.
Try the following untested code (no GUI Pi handy as normal):
root = Tk()
T.pack()
# Note use of tilde to save typing :-)
with open("~/Documents/song1.txt") as f:
    f1 = f.read()
    f1 = f1.strip() # Take out CR / LF from the text read from file
    T.insert("1.0", f1)
# File is automatically closed after the read loop is complete
mainloop()
Just be careful with the case of variable - Python is case sensitive and the 'recommended format' is to use lowercase words separated with underlines
e.g.
ScreenDisplay would be screen_display
I now cannot get Eventide out of my mind - could be worse I suppose :D
edit: Corrected double dots and added comment to strip.
scotty101
Thu May 16, 2019 12:33 pm
Change
T.insert("1.0", f1)
to
T.insert("1.0", x)
You are inserting the whole song each time rather than each line.
Daveolw1
Thu May 16, 2019 8:10 pm
Thanks for the replies.
Andyroo, I copied your code but it brought up an error 2 file not found but replacing the "~" with /home/pi it worked fine.
scotty101 I put the "x" in place of "f1" and it worked but the lines were in reverse order, and 2 lines were in one line.
Thanks for your help I realise where I was going wrong, I did not need a loop.
David
Paeryn
Thu May 16, 2019 9:57 pm
You had the lines in reverse order because you had T.insert("1.0", x) which says "insert x at line 1, column 0", so the the first line was put in to the text widget then the second line was inserted before the first etc. To insert a line at the very end you use T.insert(Tk.END, x)
Daveolw1
Sat May 18, 2019 9:58 am
Can you explain how this works
    f1 = f.read()
    T.insert("1.0", f1)
If the CR/LF have been stripped out how does the insert know what is a line?
I assumed "f1" was a list off lines, but if I try "f1[2]" you only get the character at that position.
Paeryn
Sat May 18, 2019 1:03 pm
    f1 = f.read()
    T.insert("1.0", f1)
After f1 = f.read() f1 will be one string containing the entire contents of the file.
f1 = f1.strip() strips the leading and trailing whitespace from the string. So the first character will be the first non-whitespace character of the file and the last character will be the last non-whitespace character of the file, every character (both whitespace and non-whitespace) between those two will be kept as-is.
E.g. <LF> being the line feed character
<LF>Hello<LF>There<LF>
will end up as
Hello<LF>There
Return to “Python”
