revalo
Ultra high-speed imaging, capturing matrix style bullet time.
Mon May 13, 2019 11:46 pm
We used 16 Raspberry Pi camera modules and a 1/2,000,000th of a second strobe exposure to capture a bullet going through an apple at 16 different angles.
Check out our results and code here!
https://github.com/revalo/pishot
HermannSW
Re: Ultra high-speed imaging, capturing matrix style bullet time.
Thu May 23, 2019 2:09 pm
Nice work!
What kind of strobe do you use to achieve 0.5µs strobe pulse length?
Is it a high voltage one shot strobe?
How fast can you generate a 2nd strobe flash after the first?
I ask because I use a 5000lm led with reflector to get very bright single digit µs strobe pulse lengths:
Today I did my first v1 camera (clone) video, before I did use Arducam ov5647 camera:
viewtopic.php?t=235523
One feature of my flash I wanted to use later for taking multiple exposure frames is that I trigger my strobe from GPIO13 through a Mosfet,
viewtopic.php?f=33&t=241151&p=1471498#p1471369
and that allows very fast tuning on/off the strobe, and most importantly, repeatedly.
Just a few minutes ago I took my first global shutter video with v1 camera (of a mini drone propeller rotating at 20000rpm, which is 35.6m/s(!) at blade tips). And the propeller has two blades. Something went wrong with the timing, and I got multiple exposure accidentially ;-)
This is 2MP frame from video capture with double exposure (4 blades instead of 2):
When I have more I will start a new thread on global shutter video capturing with v1 camera.
P.S:
Made little progress today, captured first triple (11µs) exposure frame:
viewtopic.php?f=33&t=241151&p=1472384#p1472384
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://gitlab.freedesktop.org/HermannSW/gst-template
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
HermannSW
Sat May 25, 2019 9:59 pm
I have it under control, the new thread will be started soon, just for today:
viewtopic.php?f=33&t=241151&p=1472646#p1472646
"2MP frame generated by five 9µs duration strobe flashes, 241µs apart":
TomLer
Sat Jun 15, 2019 10:27 pm
This is really amazing, thank you so much for sharing.
I'm curious if you have more information on how the physical wiring between the devices was done?
HermannSW
Sun Jun 16, 2019 10:45 pm
I am not sure whether revalo still monitors this forum, you can find the wiring description in his github repo:
https://github.com/revalo/pishot#gpio-based
Yes, the work of revalo's team is amazing, capturing a single point in time with many Raspberry v1 cameras.
You can do amazing stuff with a single camera as well, just today I captured a roughly 100m/s flying pointed airgun pellet with 9kHz PWM frequency and 8.33µs strobe pulse length in this 9000eps frame (exposures per second) from 90fps v1 camera video ten times:
Return to “Camera board”
