ScriptBasic
Re: A Final Fibonacci Challenge
Fri Jun 14, 2019 9:37 pm
Everything is negative and the wrong result.
Old Schoolboy at least could could come up with a correct answer even if it was heavy lifting.
ejolson
Fri Jun 14, 2019 10:04 pm
Try changing
if n <= 2 THEN
to
if n < 2 THEN
and see if that fixes it.
ScriptBasic
Fri Jun 14, 2019 10:06 pm
Nope.
function hfibo(n)
  if n <= 2 THEN
    r = 1
  else
    k = n \ 2
    fk = hfibo(k)
    fk1 = hfibo(k + 1)
    if n % 2 = 0 then
      a = fk1 + fk1
      b = a - fk
      r = fk * b
    else
      a = fk * fk
      b = fk1 * fk1
      r = a + b
    end if
  end if
  hfibo = r
end function
SPLIT "0,0,0,0,0,0" BY "," TO k, a, b, r, fk, fk1
PRINT FORMAT("%.f",hfibo(10)),"\n"
DECLARE SUB fibo ALIAS "fibo" LIB "gmp"
PRINT fibo(10),"\n"
Output
[email protected]:~/sb/GMP$ scriba nfibo.sb
-15
[email protected]:~/sb/GMP$ scriba ../examples/test/fibo.sb
55
ScriptBasic
Fri Jun 14, 2019 10:16 pm
function hfibo(n)
  if n < 2 THEN
    r = 1
  else
    k = n \ 2
    fk = hfibo(k)
    fk1 = hfibo(k + 1)
    if n % 2 = 0 then
      a = fk1 + fk1
      b = a - fk
      r = fk * b
    else
      a = fk * fk
      b = fk1 * fk1
      r = a + b
    end if
  end if
  hfibo = r
end function
Segmentation fault (core dumped)
That's rare! (possible recursion overflow?)
ejolson
Fri Jun 14, 2019 10:24 pm
function hfibo(n)
  if n < 2 THEN
    r = 1
  else
    k = n \ 2
    fk = hfibo(k)
    fk1 = hfibo(k + 1)
    if n % 2 = 0 then
      a = fk1 + fk1
      b = a - fk
      r = fk * b
    else
      a = fk * fk
      b = fk1 * fk1
      r = a + b
    end if
  end if
  hfibo = r
end function
I guess not that then.
The base case for the recursion (first branch in the conditional) should agree with
F(0) = 0
F(1) = 1
F(2) = 1
F(3) = 2
I'm not sure what the original code did. Currently I'm away from my computer, so I can't help much more. I'm certain it will eventually work.
ScriptBasic
Fri Jun 14, 2019 10:27 pm
You have ScriptBasic running on your box. Can you give the script a try when you get home?
ScriptBasic
Fri Jun 14, 2019 10:41 pm
Does anyone have a fibo routine beyond schoolboy that I can try?
ScriptBasic
Fri Jun 14, 2019 11:41 pm
It looks like SchoolBoy takes home the prize. All the recursive attempts were way too slow. What might be happening is ScriptBasic is not doing compares as we assume when one is a number and the other a string.
a = 1
b = "5"
IF b > a THEN
  PRINT "It Works!\n"
ELSE
  PRINT "Nope.\n"
END IF
[email protected]:~/sb/GMP$ scriba comptest.sb
It Works!
DECLARE SUB BI_ADD    ALIAS  "bi_add"  LIB "gmp"
FUNCTION sfibo (n)
  IF n < 2 THEN
    sfibo = 1
  ELSE
    m = 0
    p = 1
    q = 0
    FOR i = 2 TO n
      m = BI_ADD(p, q)
      q = p
      p = m
    NEXT i
    sfibo = m
  END IF
END FUNCTION
PRINT sfibo(7500),"\n"
Output
[email protected]:~/sb/GMP$ time scriba sbfibo
11423965231520587047220488928656904198487186633317560797959030595738263643588305263964321080516991429937628886229555340146644442744473185460778302934743807002248109695741208782411159189994651520930091202035101269350523609417276542209682261168150544790025062794209091503702088574338650460569295592498666443239807989522593072562158640947468656887645879356201301594841872491497556389555817277508349058330498007583814270123329724353233156029127910968370052734811192660492733375394472692191584489489590970254440914222778382439339334175624660291588778456250479185237898309112318829984358216337347549014336517486496643224502773380042071174360597192343056318489287038447004730922073980870072990706067508624038407888471294048912294153491398930715643640170172837379127969101176561450586945715460276780809807889664272818316865711724985646554559305334340318994612185260719042008960311269000122672589731283419608098303367260382379660402261886574952211783683104453334281684425994447306306414660032519055079504313562694958935754118796157632978970220780288168992181699708922971417067735144929461193639081445200786881549331150381216073705417531166786634690469206418611524663013854198045284806720735273715046888704916821855277543026346215355286395854263168251068150374988851620501196943905031285049077628443804052134507022504682483293396215268186620124762379744668092166035314553541731537245946256422861852573006230492322259630342294350827184840607509969289328320360093204783447860955806396350723341261564285649453007949089154165288839814442677339344794691881510389855765582716774490000
real	0m0.695s
user	0m0.253s
sys	0m0.024s
SchoolBoy at 78000 which is 1000 times greater than I can do without GMP support.
[email protected]:~/sb/GMP$ time scriba sbfibo > sbfibo.out
real	0m41.990s
user	0m41.086s
sys	0m0.868s
At this point ScriptBasic has already achieved its goal of adding BIGINT support seamlessly. Anything beyond this is icing for me.
ScriptBasic
Sat Jun 15, 2019 12:49 am
Fibonacci 500
FUNCTION sfibo (n)
  IF n < 2 THEN
    sfibo = 1
    PRINT "[1] - 1\n"
  ELSE
    m = 0
    p = 1
    q = 0
    FOR i = 2 TO n
      m = BI_ADD(p, q)
      q = p
      p = m
      PRINT "[",i,"] - ", m, "\n"
    NEXT i
  END IF
END FUNCTION
sfibo(500)
Output
[email protected]:~/sb/GMP$ time scriba fibo500.sb
[2] - 1
[3] - 2
[4] - 3
[5] - 5
[6] - 8
[7] - 13
[8] - 21
[9] - 34
[10] - 55
[11] - 89
[12] - 144
[13] - 233
[14] - 377
[15] - 610
[16] - 987
[17] - 1597
[18] - 2584
[19] - 4181
[20] - 6765
[21] - 10946
[22] - 17711
[23] - 28657
[24] - 46368
[25] - 75025
[26] - 121393
[27] - 196418
[28] - 317811
[29] - 514229
[30] - 832040
[31] - 1346269
[32] - 2178309
[33] - 3524578
[34] - 5702887
[35] - 9227465
[36] - 14930352
[37] - 24157817
[38] - 39088169
[39] - 63245986
[40] - 102334155
[41] - 165580141
[42] - 267914296
[43] - 433494437
[44] - 701408733
[45] - 1134903170
[46] - 1836311903
[47] - 2971215073
[48] - 4807526976
[49] - 7778742049
[50] - 12586269025
[51] - 20365011074
[52] - 32951280099
[53] - 53316291173
[54] - 86267571272
[55] - 139583862445
[56] - 225851433717
[57] - 365435296162
[58] - 591286729879
[59] - 956722026041
[60] - 1548008755920
[61] - 2504730781961
[62] - 4052739537881
[63] - 6557470319842
[64] - 10610209857723
[65] - 17167680177565
[66] - 27777890035288
[67] - 44945570212853
[68] - 72723460248141
[69] - 117669030460994
[70] - 190392490709135
[71] - 308061521170129
[72] - 498454011879264
[73] - 806515533049393
[74] - 1304969544928657
[75] - 2111485077978050
[76] - 3416454622906707
[77] - 5527939700884757
[78] - 8944394323791464
[79] - 14472334024676221
[80] - 23416728348467685
[81] - 37889062373143906
[82] - 61305790721611591
[83] - 99194853094755497
[84] - 160500643816367088
[85] - 259695496911122585
[86] - 420196140727489673
[87] - 679891637638612258
[88] - 1100087778366101931
[89] - 1779979416004714189
[90] - 2880067194370816120
[91] - 4660046610375530309
[92] - 7540113804746346429
[93] - 12200160415121876738
[94] - 19740274219868223167
[95] - 31940434634990099905
[96] - 51680708854858323072
[97] - 83621143489848422977
[98] - 135301852344706746049
[99] - 218922995834555169026
[100] - 354224848179261915075
[101] - 573147844013817084101
[102] - 927372692193078999176
[103] - 1500520536206896083277
[104] - 2427893228399975082453
[105] - 3928413764606871165730
[106] - 6356306993006846248183
[107] - 10284720757613717413913
[108] - 16641027750620563662096
[109] - 26925748508234281076009
[110] - 43566776258854844738105
[111] - 70492524767089125814114
[112] - 114059301025943970552219
[113] - 184551825793033096366333
[114] - 298611126818977066918552
[115] - 483162952612010163284885
[116] - 781774079430987230203437
[117] - 1264937032042997393488322
[118] - 2046711111473984623691759
[119] - 3311648143516982017180081
[120] - 5358359254990966640871840
[121] - 8670007398507948658051921
[122] - 14028366653498915298923761
[123] - 22698374052006863956975682
[124] - 36726740705505779255899443
[125] - 59425114757512643212875125
[126] - 96151855463018422468774568
[127] - 155576970220531065681649693
[128] - 251728825683549488150424261
[129] - 407305795904080553832073954
[130] - 659034621587630041982498215
[131] - 1066340417491710595814572169
[132] - 1725375039079340637797070384
[133] - 2791715456571051233611642553
[134] - 4517090495650391871408712937
[135] - 7308805952221443105020355490
[136] - 11825896447871834976429068427
[137] - 19134702400093278081449423917
[138] - 30960598847965113057878492344
[139] - 50095301248058391139327916261
[140] - 81055900096023504197206408605
[141] - 131151201344081895336534324866
[142] - 212207101440105399533740733471
[143] - 343358302784187294870275058337
[144] - 555565404224292694404015791808
[145] - 898923707008479989274290850145
[146] - 1454489111232772683678306641953
[147] - 2353412818241252672952597492098
[148] - 3807901929474025356630904134051
[149] - 6161314747715278029583501626149
[150] - 9969216677189303386214405760200
[151] - 16130531424904581415797907386349
[152] - 26099748102093884802012313146549
[153] - 42230279526998466217810220532898
[154] - 68330027629092351019822533679447
[155] - 110560307156090817237632754212345
[156] - 178890334785183168257455287891792
[157] - 289450641941273985495088042104137
[158] - 468340976726457153752543329995929
[159] - 757791618667731139247631372100066
[160] - 1226132595394188293000174702095995
[161] - 1983924214061919432247806074196061
[162] - 3210056809456107725247980776292056
[163] - 5193981023518027157495786850488117
[164] - 8404037832974134882743767626780173
[165] - 13598018856492162040239554477268290
[166] - 22002056689466296922983322104048463
[167] - 35600075545958458963222876581316753
[168] - 57602132235424755886206198685365216
[169] - 93202207781383214849429075266681969
[170] - 150804340016807970735635273952047185
[171] - 244006547798191185585064349218729154
[172] - 394810887814999156320699623170776339
[173] - 638817435613190341905763972389505493
[174] - 1033628323428189498226463595560281832
[175] - 1672445759041379840132227567949787325
[176] - 2706074082469569338358691163510069157
[177] - 4378519841510949178490918731459856482
[178] - 7084593923980518516849609894969925639
[179] - 11463113765491467695340528626429782121
[180] - 18547707689471986212190138521399707760
[181] - 30010821454963453907530667147829489881
[182] - 48558529144435440119720805669229197641
[183] - 78569350599398894027251472817058687522
[184] - 127127879743834334146972278486287885163
[185] - 205697230343233228174223751303346572685
[186] - 332825110087067562321196029789634457848
[187] - 538522340430300790495419781092981030533
[188] - 871347450517368352816615810882615488381
[189] - 1409869790947669143312035591975596518914
[190] - 2281217241465037496128651402858212007295
[191] - 3691087032412706639440686994833808526209
[192] - 5972304273877744135569338397692020533504
[193] - 9663391306290450775010025392525829059713
[194] - 15635695580168194910579363790217849593217
[195] - 25299086886458645685589389182743678652930
[196] - 40934782466626840596168752972961528246147
[197] - 66233869353085486281758142155705206899077
[198] - 107168651819712326877926895128666735145224
[199] - 173402521172797813159685037284371942044301
[200] - 280571172992510140037611932413038677189525
[201] - 453973694165307953197296969697410619233826
[202] - 734544867157818093234908902110449296423351
[203] - 1188518561323126046432205871807859915657177
[204] - 1923063428480944139667114773918309212080528
[205] - 3111581989804070186099320645726169127737705
[206] - 5034645418285014325766435419644478339818233
[207] - 8146227408089084511865756065370647467555938
[208] - 13180872826374098837632191485015125807374171
[209] - 21327100234463183349497947550385773274930109
[210] - 34507973060837282187130139035400899082304280
[211] - 55835073295300465536628086585786672357234389
[212] - 90343046356137747723758225621187571439538669
[213] - 146178119651438213260386312206974243796773058
[214] - 236521166007575960984144537828161815236311727
[215] - 382699285659014174244530850035136059033084785
[216] - 619220451666590135228675387863297874269396512
[217] - 1001919737325604309473206237898433933302481297
[218] - 1621140188992194444701881625761731807571877809
[219] - 2623059926317798754175087863660165740874359106
[220] - 4244200115309993198876969489421897548446236915
[221] - 6867260041627791953052057353082063289320596021
[222] - 11111460156937785151929026842503960837766832936
[223] - 17978720198565577104981084195586024127087428957
[224] - 29090180355503362256910111038089984964854261893
[225] - 47068900554068939361891195233676009091941690850
[226] - 76159080909572301618801306271765994056795952743
[227] - 123227981463641240980692501505442003148737643593
[228] - 199387062373213542599493807777207997205533596336
[229] - 322615043836854783580186309282650000354271239929
[230] - 522002106210068326179680117059857997559804836265
[231] - 844617150046923109759866426342507997914076076194
[232] - 1366619256256991435939546543402365995473880912459
[233] - 2211236406303914545699412969744873993387956988653
[234] - 3577855662560905981638959513147239988861837901112
[235] - 5789092068864820527338372482892113982249794889765
[236] - 9366947731425726508977331996039353971111632790877
[237] - 15156039800290547036315704478931467953361427680642
[238] - 24522987531716273545293036474970821924473060471519
[239] - 39679027332006820581608740953902289877834488152161
[240] - 64202014863723094126901777428873111802307548623680
[241] - 103881042195729914708510518382775401680142036775841
[242] - 168083057059453008835412295811648513482449585399521
[243] - 271964099255182923543922814194423915162591622175362
[244] - 440047156314635932379335110006072428645041207574883
[245] - 712011255569818855923257924200496343807632829750245
[246] - 1152058411884454788302593034206568772452674037325128
[247] - 1864069667454273644225850958407065116260306867075373
[248] - 3016128079338728432528443992613633888712980904400501
[249] - 4880197746793002076754294951020699004973287771475874
[250] - 7896325826131730509282738943634332893686268675876375
[251] - 12776523572924732586037033894655031898659556447352249
[252] - 20672849399056463095319772838289364792345825123228624
[253] - 33449372971981195681356806732944396691005381570580873
[254] - 54122222371037658776676579571233761483351206693809497
[255] - 87571595343018854458033386304178158174356588264390370
[256] - 141693817714056513234709965875411919657707794958199867
[257] - 229265413057075367692743352179590077832064383222590237
[258] - 370959230771131880927453318055001997489772178180790104
[259] - 600224643828207248620196670234592075321836561403380341
[260] - 971183874599339129547649988289594072811608739584170445
[261] - 1571408518427546378167846658524186148133445300987550786
[262] - 2542592393026885507715496646813780220945054040571721231
[263] - 4114000911454431885883343305337966369078499341559272017
[264] - 6656593304481317393598839952151746590023553382130993248
[265] - 10770594215935749279482183257489712959102052723690265265
[266] - 17427187520417066673081023209641459549125606105821258513
[267] - 28197781736352815952563206467131172508227658829511523778
[268] - 45624969256769882625644229676772632057353264935332782291
[269] - 73822750993122698578207436143903804565580923764844306069
[270] - 119447720249892581203851665820676436622934188700177088360
[271] - 193270471243015279782059101964580241188515112465021394429
[272] - 312718191492907860985910767785256677811449301165198482789
[273] - 505988662735923140767969869749836918999964413630219877218
[274] - 818706854228831001753880637535093596811413714795418360007
[275] - 1324695516964754142521850507284930515811378128425638237225
[276] - 2143402371193585144275731144820024112622791843221056597232
[277] - 3468097888158339286797581652104954628434169971646694834457
[278] - 5611500259351924431073312796924978741056961814867751431689
[279] - 9079598147510263717870894449029933369491131786514446266146
[280] - 14691098406862188148944207245954912110548093601382197697835
[281] - 23770696554372451866815101694984845480039225387896643963981
[282] - 38461794961234640015759308940939757590587318989278841661816
[283] - 62232491515607091882574410635924603070626544377175485625797
[284] - 100694286476841731898333719576864360661213863366454327287613
[285] - 162926777992448823780908130212788963731840407743629812913410
[286] - 263621064469290555679241849789653324393054271110084140201023
[287] - 426547842461739379460149980002442288124894678853713953114433
[288] - 690168906931029935139391829792095612517948949963798093315456
[289] - 1116716749392769314599541809794537900642843628817512046429889
[290] - 1806885656323799249738933639586633513160792578781310139745345
[291] - 2923602405716568564338475449381171413803636207598822186175234
[292] - 4730488062040367814077409088967804926964428786380132325920579
[293] - 7654090467756936378415884538348976340768064993978954512095813
[294] - 12384578529797304192493293627316781267732493780359086838016392
[295] - 20038668997554240570909178165665757608500558774338041350112205
[296] - 32423247527351544763402471792982538876233052554697128188128597
[297] - 52461916524905785334311649958648296484733611329035169538240802
[298] - 84885164052257330097714121751630835360966663883732297726369399
[299] - 137347080577163115432025771710279131845700275212767467264610201
[300] - 222232244629420445529739893461909967206666939096499764990979600
[301] - 359579325206583560961765665172189099052367214309267232255589801
[302] - 581811569836004006491505558634099066259034153405766997246569401
[303] - 941390895042587567453271223806288165311401367715034229502159202
[304] - 1523202464878591573944776782440387231570435521120801226748728603
[305] - 2464593359921179141398048006246675396881836888835835456250887805
[306] - 3987795824799770715342824788687062628452272409956636682999616408
[307] - 6452389184720949856740872794933738025334109298792472139250504213
[308] - 10440185009520720572083697583620800653786381708749108822250120621
[309] - 16892574194241670428824570378554538679120491007541580961500624834
[310] - 27332759203762391000908267962175339332906872716290689783750745455
[311] - 44225333398004061429732838340729878012027363723832270745251370289
[312] - 71558092601766452430641106302905217344934236440122960529002115744
[313] - 115783425999770513860373944643635095356961600163955231274253486033
[314] - 187341518601536966291015050946540312701895836604078191803255601777
[315] - 303124944601307480151388995590175408058857436768033423077509087810
[316] - 490466463202844446442404046536715720760753273372111614880764689587
[317] - 793591407804151926593793042126891128819610710140145037958273777397
[318] - 1284057871006996373036197088663606849580363983512256652839038466984
[319] - 2077649278811148299629990130790497978399974693652401690797312244381
[320] - 3361707149818144672666187219454104827980338677164658343636350711365
[321] - 5439356428629292972296177350244602806380313370817060034433662955746
[322] - 8801063578447437644962364569698707634360652047981718378070013667111
[323] - 14240420007076730617258541919943310440740965418798778412503676622857
[324] - 23041483585524168262220906489642018075101617466780496790573690289968
[325] - 37281903592600898879479448409585328515842582885579275203077366912825
[326] - 60323387178125067141700354899227346590944200352359771993651057202793
[327] - 97605290770725966021179803308812675106786783237939047196728424115618
[328] - 157928677948851033162880158208040021697730983590298819190379481318411
[329] - 255533968719576999184059961516852696804517766828237866387107905434029
[330] - 413462646668428032346940119724892718502248750418536685577487386752440
[331] - 668996615388005031531000081241745415306766517246774551964595292186469
[332] - 1082459262056433063877940200966638133809015267665311237542082678938909
[333] - 1751455877444438095408940282208383549115781784912085789506677971125378
[334] - 2833915139500871159286880483175021682924797052577397027048760650064287
[335] - 4585371016945309254695820765383405232040578837489482816555438621189665
[336] - 7419286156446180413982701248558426914965375890066879843604199271253952
[337] - 12004657173391489668678522013941832147005954727556362660159637892443617
[338] - 19423943329837670082661223262500259061971330617623242503763837163697569
[339] - 31428600503229159751339745276442091208977285345179605163923475056141186
[340] - 50852543833066829834000968538942350270948615962802847667687312219838755
[341] - 82281144336295989585340713815384441479925901307982452831610787275979941
[342] - 133133688169362819419341682354326791750874517270785300499298099495818696
[343] - 215414832505658809004682396169711233230800418578767753330908886771798637
[344] - 348548520675021628424024078524038024981674935849553053830206986267617333
[345] - 563963353180680437428706474693749258212475354428320807161115873039415970
[346] - 912511873855702065852730553217787283194150290277873860991322859307033303
[347] - 1476475227036382503281437027911536541406625644706194668152438732346449273
[348] - 2388987100892084569134167581129323824600775934984068529143761591653482576
[349] - 3865462327928467072415604609040860366007401579690263197296200323999931849
[350] - 6254449428820551641549772190170184190608177514674331726439961915653414425
[351] - 10119911756749018713965376799211044556615579094364594923736162239653346274
[352] - 16374361185569570355515148989381228747223756609038926650176124155306760699
[353] - 26494272942318589069480525788592273303839335703403521573912286394960106973
[354] - 42868634127888159424995674777973502051063092312442448224088410550266867672
[355] - 69362907070206748494476200566565775354902428015845969798000696945226974645
[356] - 112231541198094907919471875344539277405965520328288418022089107495493842317
[357] - 181594448268301656413948075911105052760867948344134387820089804440720816962
[358] - 293825989466396564333419951255644330166833468672422805842178911936214659279
[359] - 475420437734698220747368027166749382927701417016557193662268716376935476241
[360] - 769246427201094785080787978422393713094534885688979999504447628313150135520
[361] - 1244666864935793005828156005589143096022236302705537193166716344690085611761
[362] - 2013913292136887790908943984011536809116771188394517192671163973003235747281
[363] - 3258580157072680796737099989600679905139007491100054385837880317693321359042
[364] - 5272493449209568587646043973612216714255778679494571578509044290696557106323
[365] - 8531073606282249384383143963212896619394786170594625964346924608389878465365
[366] - 13803567055491817972029187936825113333650564850089197542855968899086435571688
[367] - 22334640661774067356412331900038009953045351020683823507202893507476314037053
[368] - 36138207717265885328441519836863123286695915870773021050058862406562749608741
[369] - 58472848379039952684853851736901133239741266891456844557261755914039063645794
[370] - 94611056096305838013295371573764256526437182762229865607320618320601813254535
[371] - 153083904475345790698149223310665389766178449653686710164582374234640876900329
[372] - 247694960571651628711444594884429646292615632415916575771902992555242690154864
[373] - 400778865046997419409593818195095036058794082069603285936485366789883567055193
[374] - 648473825618649048121038413079524682351409714485519861708388359345126257210057
[375] - 1049252690665646467530632231274619718410203796555123147644873726135009824265250
[376] - 1697726516284295515651670644354144400761613511040643009353262085480136081475307
[377] - 2746979206949941983182302875628764119171817307595766156998135811615145905740557
[378] - 4444705723234237498833973519982908519933430818636409166351397897095281987215864
[379] - 7191684930184179482016276395611672639105248126232175323349533708710427892956421
[380] - 11636390653418416980850249915594581159038678944868584489700931605805709880172285
[381] - 18828075583602596462866526311206253798143927071100759813050465314516137773128706
[382] - 30464466237021013443716776226800834957182606015969344302751396920321847653300991
[383] - 49292541820623609906583302538007088755326533087070104115801862234837985426429697
[384] - 79757008057644623350300078764807923712509139103039448418553259155159833079730688
[385] - 129049549878268233256883381302815012467835672190109552534355121389997818506160385
[386] - 208806557935912856607183460067622936180344811293149000952908380545157651585891073
[387] - 337856107814181089864066841370437948648180483483258553487263501935155470092051458
[388] - 546662665750093946471250301438060884828525294776407554440171882480313121677942531
[389] - 884518773564275036335317142808498833476705778259666107927435384415468591769993989
[390] - 1431181439314368982806567444246559718305231073036073662367607266895781713447936520
[391] - 2315700212878644019141884587055058551781936851295739770295042651311250305217930509
[392] - 3746881652193013001948452031301618270087167924331813432662649918207032018665867029
[393] - 6062581865071657021090336618356676821869104775627553202957692569518282323883797538
[394] - 9809463517264670023038788649658295091956272699959366635620342487725314342549664567
[395] - 15872045382336327044129125268014971913825377475586919838578035057243596666433462105
[396] - 25681508899600997067167913917673267005781650175546286474198377544968911008983126672
[397] - 41553554281937324111297039185688238919607027651133206312776412602212507675416588777
[398] - 67235063181538321178464953103361505925388677826679492786974790147181418684399715449
[399] - 108788617463475645289761992289049744844995705477812699099751202749393926359816304226
[400] - 176023680645013966468226945392411250770384383304492191886725992896575345044216019675
[401] - 284812298108489611757988937681460995615380088782304890986477195645969271404032323901
[402] - 460835978753503578226215883073872246385764472086797082873203188542544616448248343576
[403] - 745648276861993189984204820755333242001144560869101973859680384188513887852280667477
[404] - 1206484255615496768210420703829205488386909032955899056732883572731058504300529011053
[405] - 1952132532477489958194625524584538730388053593825001030592563956919572392152809678530
[406] - 3158616788092986726405046228413744218774962626780900087325447529650630896453338689583
[407] - 5110749320570476684599671752998282949163016220605901117918011486570203288606148368113
[408] - 8269366108663463411004717981412027167937978847386801205243459016220834185059487057696
[409] - 13380115429233940095604389734410310117100995067992702323161470502791037473665635425809
[410] - 21649481537897403506609107715822337285038973915379503528404929519011871658725122483505
[411] - 35029596967131343602213497450232647402139968983372205851566400021802909132390757909314
[412] - 56679078505028747108822605166054984687178942898751709379971329540814780791115880392819
[413] - 91708675472160090711036102616287632089318911882123915231537729562617689923506638302133
[414] - 148387753977188837819858707782342616776497854780875624611509059103432470714622518694952
[415] - 240096429449348928530894810398630248865816766662999539843046788666050160638129156997085
[416] - 388484183426537766350753518180972865642314621443875164454555847769482631352751675692037
[417] - 628580612875886694881648328579603114508131388106874704297602636435532791990880832689122
[418] - 1017064796302424461232401846760575980150446009550749868752158484205015423343632508381159
[419] - 1645645409178311156114050175340179094658577397657624573049761120640548215334513341070281
[420] - 2662710205480735617346452022100755074809023407208374441801919604845563638678145849451440
[421] - 4308355614659046773460502197440934169467600804865999014851680725486111854012659190521721
[422] - 6971065820139782390806954219541689244276624212074373456653600330331675492690805039973161
[423] - 11279421434798829164267456416982623413744225016940372471505281055817787346703464230494882
[424] - 18250487254938611555074410636524312658020849229014745928158881386149462839394269270468043
[425] - 29529908689737440719341867053506936071765074245955118399664162441967250186097733500962925
[426] - 47780395944676052274416277690031248729785923474969864327823043828116713025492002771430968
[427] - 77310304634413492993758144743538184801550997720924982727487206270083963211589736272393893
[428] - 125090700579089545268174422433569433531336921195894847055310250098200676237081739043824861
[429] - 202401005213503038261932567177107618332887918916819829782797456368284639448671475316218754
[430] - 327491705792592583530106989610677051864224840112714676838107706466485315685753214360043615
[431] - 529892711006095621792039556787784670197112759029534506620905162834769955134424689676262369
[432] - 857384416798688205322146546398461722061337599142249183459012869301255270820177904036305984
[433] - 1387277127804783827114186103186246392258450358171783690079918032136025225954602593712568353
[434] - 2244661544603472032436332649584708114319787957314032873538930901437280496774780497748874337
[435] - 3631938672408255859550518752770954506578238315485816563618848933573305722729383091461442690
[436] - 5876600217011727891986851402355662620898026272799849437157779835010586219504163589210317027
[437] - 9508538889419983751537370155126617127476264588285666000776628768583891942233546680671759717
[438] - 15385139106431711643524221557482279748374290861085515437934408603594478161737710269882076744
[439] - 24893677995851695395061591712608896875850555449371181438711037372178370103971256950553836461
[440] - 40278817102283407038585813270091176624224846310456696876645445975772848265708967220435913205
[441] - 65172495098135102433647404982700073500075401759827878315356483347951218369680224170989749666
[442] - 105451312200418509472233218252791250124300248070284575192001929323724066635389191391425662871
[443] - 170623807298553611905880623235491323624375649830112453507358412671675285005069415562415412537
[444] - 276075119498972121378113841488282573748675897900397028699360341995399351640458606953841075408
[445] - 446698926797525733283994464723773897373051547730509482206718754667074636645528022516256487945
[446] - 722774046296497854662108306212056471121727445630906510906079096662473988285986629470097563353
[447] - 1169472973094023587946102770935830368494778993361415993112797851329548624931514651986354051298
[448] - 1892247019390521442608211077147886839616506438992322504018876947992022613217501281456451614651
[449] - 3061719992484545030554313848083717208111285432353738497131674799321571238149015933442805665949
[450] - 4953967011875066473162524925231604047727791871346061001150551747313593851366517214899257280600
[451] - 8015687004359611503716838773315321255839077303699799498282226546635165089515533148342062946549
[452] - 12969654016234677976879363698546925303566869175045860499432778293948758940882050363241320227149
[453] - 20985341020594289480596202471862246559405946478745659997715004840583924030397583511583383173698
[454] - 33954995036828967457475566170409171862972815653791520497147783134532682971279633874824703400847
[455] - 54940336057423256938071768642271418422378762132537180494862787975116607001677217386408086574545
[456] - 88895331094252224395547334812680590285351577786328700992010571109649289972956851261232789975392
[457] - 143835667151675481333619103454952008707730339918865881486873359084765896974634068647640876549937
[458] - 232730998245927705729166438267632598993081917705194582478883930194415186947590919908873666525329
[459] - 376566665397603187062785541722584607700812257624060463965757289279181083922224988556514543075266
[460] - 609297663643530892791951979990217206693894175329255046444641219473596270869815908465388209600595
[461] - 985864329041134079854737521712801814394706432953315510410398508752777354792040897021902752675861
[462] - 1595161992684664972646689501703019021088600608282570556855039728226373625661856805487290962276456
[463] - 2581026321725799052501427023415820835483307041235886067265438236979150980453897702509193714952317
[464] - 4176188314410464025148116525118839856571907649518456624120477965205524606115754507996484677228773
[465] - 6757214636136263077649543548534660692055214690754342691385916202184675586569652210505678392181090
[466] - 10933402950546727102797660073653500548627122340272799315506394167390200192685406718502163069409863
[467] - 17690617586682990180447203622188161240682337031027142006892310369574875779255058929007841461590953
[468] - 28624020537229717283244863695841661789309459371299941322398704536965075971940465647510004531000816
[469] - 46314638123912707463692067318029823029991796402327083329291014906539951751195524576517845992591769
[470] - 74938658661142424746936931013871484819301255773627024651689719443505027723135990224027850523592585
[471] - 121253296785055132210628998331901307849293052175954107980980734350044979474331514800545696516184354
[472] - 196191955446197556957565929345772792668594307949581132632670453793550007197467505024573547039776939
[473] - 317445252231252689168194927677674100517887360125535240613651188143594986671799019825119243555961293
[474] - 513637207677450246125760857023446893186481668075116373246321641937144993869266524849692790595738232
[475] - 831082459908702935293955784701120993704369028200651613859972830080739980541065544674812034151699525
[476] - 1344719667586153181419716641724567886890850696275767987106294472017884974410332069524504824747437757
[477] - 2175802127494856116713672426425688880595219724476419600966267302098624954951397614199316858899137282
[478] - 3520521795081009298133389068150256767486070420752187588072561774116509929361729683723821683646575039
[479] - 5696323922575865414847061494575945648081290145228607189038829076215134884313127297923138542545712321
[480] - 9216845717656874712980450562726202415567360565980794777111390850331644813674856981646960226192287360
[481] - 14913169640232740127827512057302148063648650711209401966150219926546779697987984279570098768737999681
[482] - 24130015357889614840807962620028350479216011277190196743261610776878424511662841261217058994930287041
[483] - 39043184998122354968635474677330498542864661988399598709411830703425204209650825540787157763668286722
[484] - 63173200356011969809443437297358849022080673265589795452673441480303628721313666802004216758598573763
[485] - 102216385354134324778078911974689347564945335253989394162085272183728832930964492342791374522266860485
[486] - 165389585710146294587522349272048196587026008519579189614758713664032461652278159144795591280865434248
[487] - 267605971064280619365601261246737544151971343773568583776843985847761294583242651487586965803132294733
[488] - 432995556774426913953123610518785740738997352293147773391602699511793756235520810632382557083997728981
[489] - 700601527838707533318724871765523284890968696066716357168446685359555050818763462119969522887130023714
[490] - 1133597084613134447271848482284309025629966048359864130560049384871348807054284272752352079971127752695
[491] - 1834198612451841980590573354049832310520934744426580487728496070230903857873047734872321602858257776409
[492] - 2967795697064976427862421836334141336150900792786444618288545455102252664927332007624673682829385529104
[493] - 4801994309516818408452995190383973646671835537213025106017041525333156522800379742496995285687643305513
[494] - 7769790006581794836315417026718114982822736329999469724305586980435409187727711750121668968517028834617
[495] - 12571784316098613244768412217102088629494571867212494830322628505768565710528091492618664254204672140130
[496] - 20341574322680408081083829243820203612317308197211964554628215486203974898255803242740333222721700974747
[497] - 32913358638779021325852241460922292241811880064424459384950843991972540608783894735358997476926373114877
[498] - 53254932961459429406936070704742495854129188261636423939579059478176515507039697978099330699648074089624
[499] - 86168291600238450732788312165664788095941068326060883324529903470149056115823592713458328176574447204501
[500] - 139423224561697880139724382870407283950070256587697307264108962948325571622863290691557658876222521294125
real	0m0.017s
user	0m0.008s
sys	0m0.009s
ejolson
Sat Jun 15, 2019 2:10 am
Nope.
function hfibo(n)
  if n <= 2 THEN
    r = 1
  else
    k = n \ 2
    fk = hfibo(k)
    fk1 = hfibo(k + 1)
    if n % 2 = 0 then
      a = fk1 + fk1
      b = a - fk
      r = fk * b
    else
      a = fk * fk
      b = fk1 * fk1
      r = a + b
    end if
  end if
  hfibo = r
end function
PRINT fibo(10),"\n"
Output
-15
55
Further investigation seems to indicate the reason for the wrong answer is that the variables a, b, fk, fk1 and r appearing in the hfibo function have global scope in Script Basic. Adding a print statement to your code obtains
$ scriba double.bas
hfibo(2)=1
hfibo(1)=1
hfibo(2)=1
hfibo(3)=2
hfibo(1)=5
hfibo(2)=1
hfibo(10)=-15
-15
$ cat double.bas
function hfibo(n)
  if n <= 2 THEN
    r = 1
  else
    k = n \ 2
    fk = hfibo(k)
    fk1 = hfibo(k + 1)
    if n % 2 = 0 then
      a = fk1 + fk1
      b = a - fk
      r = fk * b
    else
      a = fk * fk
      b = fk1 * fk1
      r = a + b
    end if
  end if
  print "hfibo(",n,")=",r,"\n"
  hfibo = r
end function
which nearly matches the output of the following C code:
$ gcc global.c
$ ./a.out
hfibo(2)=1
hfibo(1)=1
hfibo(2)=1
hfibo(3)=2
hfibo(5)=5
hfibo(2)=1
hfibo(10)=-15
-15
$ cat global.c
#include <stdio.h>
long a,b,fk,fk1,k,r;
long hfibo(long n){
    if(n <= 2){
        r = 1;
    } else {
        k = n / 2;
        fk = hfibo(k);
        fk1 = hfibo(k+1);
        if(n%2 == 0){
            a = fk1 + fk1;
            b = a - fk;
            r = fk * b;
        } else {
            a = fk * fk;
            b = fk1 * fk1;
            r = a + b;
    printf("hfibo(%ld)=%ld\n",n,r);
    return r;
int main(){
    printf("%ld\n",hfibo(10));
    return 0;
Note that the C code works fine if the variables are declared local as seen by
$ gcc local.c
$ ./a.out
hfibo(2)=1
hfibo(1)=1
hfibo(2)=1
hfibo(3)=2
hfibo(5)=5
hfibo(1)=1
hfibo(2)=1
hfibo(3)=2
hfibo(2)=1
hfibo(1)=1
hfibo(2)=1
hfibo(3)=2
hfibo(4)=3
hfibo(6)=8
hfibo(10)=55
55
$ cat local.c
#include <stdio.h>
long hfibo(long n){
    if(n <= 2){
        r = 1;
    } else {
        k = n / 2;
        fk = hfibo(k);
        fk1 = hfibo(k+1);
        if(n%2 == 0){
            a = fk1 + fk1;
            b = a - fk;
            r = fk * b;
        } else {
            a = fk * fk;
            b = fk1 * fk1;
            r = a + b;
    return r;
int main(){
    return 0;
Is there anyway to declare the variables a, b, fk, fk1, k and r to be local to the function hfibo in Script Basic?
ScriptBasic
Sat Jun 15, 2019 2:21 am
Yes.
FUNCTION ejolson
LOCAL a, b, fk, fk1, k
END FUNCTION
There is also an option you can enable that makes all variables In functions / subs LOCAL by default.
Good catch!
I'm still getting a segment fault not using GMP and a fibo(10). :(
function hfibo(n)
local a, b, fk, fk1, k, r
  split "0,0,0,0,0,0" by "," to k, a, b, r, fk, fk1
  if n < 2 then
    hfibo = 1
  else
    k = n \ 2
    fk = hfibo(k)
    fk1 = hfibo(k + 1)
    if n % 2 = 0 then
      a = fk1 + fk1
      b = a - fk
      r = fk * b
    else
      a = fk * fk
      b = fk1 * fk1
      r = a + b
    end if
  end if
  hfibo = r
end function
print format("%.f",hfibo(10)),"\n"
ejolson
Sat Jun 15, 2019 3:16 am
Yes.
FUNCTION ejolson
END FUNCTION
Good catch!
function hfibo(n)
  if n < 2 then
    hfibo = 1
  else
    k = n \ 2
    fk = hfibo(k)
    fk1 = hfibo(k + 1)
    if n % 2 = 0 then
      a = fk1 + fk1
      b = a - fk
      r = fk * b
    else
      a = fk * fk
      b = fk1 * fk1
      r = a + b
    end if
  end if
  hfibo = r
end function
Please set the if statement back to n<=2. Also, do you need to make n local as well?
ScriptBasic
Sat Jun 15, 2019 3:19 am
Making that change just returns zero. Good news the seg fault went away.
All arguments are LOCAL by default.
There is also a ByVal option so if you change a global variable in a function if has no effect on the caller.
Sat Jun 15, 2019 3:32 am
I think I owe an apology.
I screwed up that fiboNoMemo() I posted and ended up testing the wrong version of fibo so it looked like it worked here. Shame on me.
I have now rewritten it in the style of the last ScriptBasic version I have seen here so it should be easy to convert to ScriptBasic. And tested it properly!
$ cat hfibo.js
function hfibo (n) {
    let result
    if (n <= 2 ) {
        result = BigInt((n & 3) != 0)
    } else {
        let k = (n / 2) | 0
        let fk = hfibo(k);
        let fk1 = hfibo(k + 1);
        if ((n & 1) == 0) {
            let a = fk1 + fk1
            let b = a - fk
            result = fk * b
        } else {
            let a = fk * fk
            let b = fk1 * fk1
            result = a + b
    return result
console.log(hfibo(0))
console.log(hfibo(1))
console.log(hfibo(2))
console.log(hfibo(12))
console.log(hfibo(20000))
console.log(hfibo(4784969))
That first part for the base cases looks a bit odd now, it just has to return 0, 1, or 1 as big integers for n = 0, 1, 2 respectively.
Results:
$ node  hfibo.js
0n
1n
1n
144n
253116232373236124224015500...
683971213093125n
107273956418004772293648135...
539211500699706378405156269n
Takes about a minute for hfibo(4784969)
ScriptBasic
Sat Jun 15, 2019 3:42 am
This still returns zero for me.
function hfibo(n)
  if n <= 2 then
    hfibo = 1
  else
    k = n \ 2 or 0
    fk = hfibo(k)
    fk1 = hfibo(k + 1)
    if n and 1 = 0 then
      a = fk1 + fk1
      b = a - fk
      r = fk * b
    else
      a = fk * fk
      b = fk1 * fk1
      r = a + b
    end if
  end if
  hfibo = r
end function
ScriptBasic
Sat Jun 15, 2019 3:57 am
Heater,
How does this routine work for the Fibonacci 500 challenge?
In Python and JavaScript would be great.
Sat Jun 15, 2019 3:59 am
What does it return for:
hfibo(0)
hfibo(1)
hfibo(2)
hfibo(3)
You don't need the "or 0" in "k = n \ 2 or 0". That is just a Javascript thing to ensure the expression returns a 32 bit integer.
It should not make any difference but you have not fixed up the base case properly. fibo(0) will be wrong.
ScriptBasic
Sat Jun 15, 2019 4:07 am
function hfibo(n)
  if n <= 2 then
    hfibo = 1
  else
    k = n \ 2 or 0
    fk = hfibo(k)
    fk1 = hfibo(k + 1)
    if n and 1 = 0 then
      a = fk1 + fk1
      b = a - fk
      r = fk * b
    else
      a = fk * fk
      b = fk1 * fk1
      r = a + b
    end if
  end if
  hfibo = r
end function
for x = 0 to 3
  print hfibo(x),"\n"
next
0
0
0
0
Sat Jun 15, 2019 4:15 am
What fibo(500) challenge?
Anyway, very well:
hfibo.js
$ cat hfibo.js
    let result
    if (n <= 2 ) {
    } else {
        let k = (n / 2) | 0
        let fk = hfibo(k);
        if ((n & 1) == 0) {
            let a = fk1 + fk1
            let b = a - fk
            result = fk * b
        } else {
            let a = fk * fk
            let b = fk1 * fk1
            result = a + b
    return result
//console.log(hfibo(4784969))
console.log(hfibo(500))
$ time node hfibo.js
139423224561697880139724382870407283950070256587697307264108962948325571622863290691557658876222521294125n
real    0m0.092s
user    0m0.047s
sys     0m0.016s
hfibo.py
$ cat hfibo.py
def hfibo(n):
    if n == 0:
        return 0
    if n < 2:
        return 1
    k = (n + 1) // 2
    fk = hfibo(k)
    fk1 = hfibo(k - 1)
    if n & 1:
        return fk ** 2 + fk1 ** 2
    return (2 * fk1 + fk) * fk
print(hfibo(500))
$ time python3 hfibo.py
real    0m0.053s
user    0m0.031s
sys     0m0.000s
Sat Jun 15, 2019 4:20 am
ScriptBasic,
Well that's nuts then isn't it.
Your code says, first thing:
 if n <= 2 then
    hfibo = 1
  else
So when n is 0, 1 or 2 it has to return 1.
If it is returning 0 when n = 0, 1, 2 then you have something very broken in ScriptBasic!
ScriptBasic
Sat Jun 15, 2019 4:24 am
N is passed as 10 so that is dead code.
(Schoolboy rolling on the floor laughing)
Sat Jun 15, 2019 4:31 am
What do you mean "n is passed as 10"?
The code you posted says:
for x = 0 to 3
  print hfibo(x),"\n"
next
So that does not look like dead code to me.
Conversely if you are passing 10 why post the results as if they are for n = 0, 1, 2, 3 and confuse everybody ?
What is schoolboy got to laugh about? He is so slow he's never going to make it out of first grade.
ScriptBasic
Sat Jun 15, 2019 4:46 am
The Fibonacci 500 challenge is printing the first 500 fibo's. Did you not read my post?
FYI: @scruss's 'schoolboy' fibo returns the fastest time not using BIGINT libraries.(fibo 78 max) I did a 1000 times that using the same routine by using the GMP add routine in16 seconds on my PoS laptop.
Recursion is a code saver but you pay the price with performance. Like creating a mini namespace.
ejolson
Sat Jun 15, 2019 5:03 am
ScriptBasic,
 if n <= 2 then
    hfibo = 1
  else
Rather than
hfibo = 1
it should be
r = 1
as was pointed out about ten posts ago. Due to the impending digital apocalypse, the correction was reverted and the hfibo function is again returning 0 for everything. The old version does, of course, have the advantage of not overflowing the native integer arithmetic on the CPU.
Sat Jun 15, 2019 5:11 am
I just found your fibo 500 post.
That's great, your big integers work! All we need to do now is get the fibo(4784969) working.
That is not true.
Karatsuba multiplication is much faster than schoolboy multiplication for big numbers. It is recursive.
The fibo algorithms we use are much faster than schoolboy fibo for big numbers. It is recursive.
Quick sort is the fastest sorting algorithm. It is recursive.
I once wrote a recursive Fast Fourier Transform that surprised me by being faster for large data sets than the traditional iterative version I had written.
Searching a binary tree is much quicker than a iterating over a linked list. It is recursive.
Many loops can be expressed recursively, with a proper language that supports tail call optimization there is no performance penalty.
The common theme in all of these examples is the "divide and conquer" approach which enables optimization.
Currently ScriptBasic can't get to fibo(4784969) it will require recursion to do so. Unless you like to wait a long time.
