bedtime
An incomplete mini notification system in C
Mon May 06, 2019 8:20 pm
I've been making a lightweight notification system on my Pi3b+. It is designed to be extremely efficient and lightweight. Currently, it can (for the most part):
- display a notification using Xlib and one other library (I make a lot of my own string functions)
- display using justification
- print any number of lines or paragraphs
- add any sized padding to text
- use any size font and have the window perfectly adjust to it
- line wrapping (pain in the butt to implement but works nicely :) )
- timed auto close
As usual, it's free for anyone to use and modify (but try to let me know if you make any changes; I'd like to see them!)
The one thing it lacks is the ability to manage more than one notification at a time. I've been looking into ways to do this. One option is named pipes. If anyone has any ideas, please let me know.
note.c:
      gcc -Wall -O2 note.c -o note -lX11
#include<X11/Xlib.h>
#include<stdio.h>     // needed only for puts()
__inline int fast_memcmp(char *s, const char *s2)
    for(; *s2; )
        if(*s != *s2)
            return 1;
        ++s;
        ++s2;
    return 0;
void fast_strcpy(char *s, const char *s2)
    // Skip past spaces
    for(; (*s2 == ' '); )
        ++s2;
    for(; *s2; )
        *s = *s2;
        ++s;
        ++s2;
    *s = '\0';
__inline size_t fast_strlen(const char *s)
    const char *p = s;
    while(*s) ++s;
    return s - p;
/* The window which contains the text. */
struct {
    int width;
    int height;
    int y;
    int x;
    int padding;
    int maxW;
    char * txt[128];
    int txt_len[128];
    char txtAlt[128][128];
    int txtAlt_len[128];
    int doNotWrap;
    int isParagraph[128];
    int useHints;
    int border;
    int fontSize;
    int charFontSize;
    int autowidth;
    int timer;
    char justify[16];
    int lines;
    int altLines;
    /* X Windows related variables. */
    Display * display;
    int screen;
    Window root;
    Window window;
    GC gc;
    unsigned long black_pixel;
    XFontStruct * font;
} box;
/* Connect to the display, set up the basic variables. */
static void x_connect ()
    box.display = XOpenDisplay (NULL);
    box.screen = DefaultScreen (box.display);
    box.root = RootWindow (box.display, box.screen);
__inline void fast_strcat(char *s, const char *s1)
    while (*s) ++s;
    do{
        *s = *s1;
        ++s;
    }while (*s1++); // Concatenate & check for end of s
unsigned int fast_strtoul(const char *c)
    int x = 0;
    for(; (*c < 48 || *c > 57); )
        c++;
    for(; *c > 47 && *c < 58;)
        x = (x << 1) + (x << 3) + *c - 48;
        c++;
    return x;
void fast_memcpyS(char *str, const char *str2, int start, int length)
    --length;
    // Skip past spaces
    while(str2[start] == ' ' && --length)
        ++start;
    // Remove spaces at end of text
    while(str2[start + length ] == ' ' && --length);
/*    for(; length > -1; )
        str[length] = str2[start + length ];
        --length;
    int i = 0;
    for(; i < length + 1;)
        str[i] = str2[start + i];
        ++i;
    str[i] = '\0';
    //str[i - 1] = '-';
    printf("string: \'%s\'\n", str);
void fast_tostring(unsigned int num, char *str)
    int i, rem, len = 0, n = num;
    while (n != 0)
        ++len;
        n /= 10;
    for (i = 0; i < len; ++i)
        rem = num % 10;
        num = num / 10;
        str[len - (i + 1)] = rem + '0';
    str[len] = '\0';
/* Create the window. */
static void create_window ()
    char font[64], strSize[12];
    font[0] = '\0';
    fast_strcat(font, "-*-terminus-medium-r-*-*-");
    fast_tostring(box.fontSize, strSize);
    fast_strcat(font, strSize);
    fast_strcat(font, "-*-*-*-*-*-*-*");
    int direction, ascent = 0, descent = 0, extraLine = 0,
         numChars, textW = 0, longestString = 0, altTxtTotalLen = 0, altTxtLen;
    XCharStruct overall;
    box.font = XLoadQueryFont (box.display, font);
    box.charFontSize = XTextWidth(box.font, box.txt[0],
                         box.txt_len[0]) / box.txt_len[0];
    box.padding = (box.charFontSize * box.padding) / 100;
    box.height = box.padding;
    box.altLines = 0;
    box.border = 2;
    for(int i = 0; i < box.lines; )
        XTextExtents (box.font, box.txt[i], box.txt_len[i],
         &direction, &ascent, &descent, &overall);
        for(numChars = box.txt_len[i]; numChars; )
            textW = XTextWidth(box.font, box.txt[i], numChars);
            if(textW < (box.maxW - (box.padding * 2)) || box.autowidth )
                extraLine = 0;
                for( ; (numChars * extraLine) < box.txt_len[i] || box.doNotWrap;)
                    if(box.doNotWrap)
                        fast_memcpyS(box.txtAlt[box.altLines], box.txt[i], 0, numChars);
                    else
                        fast_memcpyS(box.txtAlt[box.altLines], box.txt[i], numChars * extraLine, numChars);
                    altTxtLen = fast_strlen(box.txtAlt[box.altLines]);
                    box.txtAlt_len[box.altLines] = altTxtLen;
printf("txtlen: %i\n", altTxtLen);
                    if(longestString < XTextWidth(box.font, box.txtAlt[box.altLines], box.txtAlt_len[box.altLines]))
                        longestString = XTextWidth(box.font, box.txtAlt[box.altLines], box.txtAlt_len[box.altLines]);
                    if(!extraLine && box.altLines)
                        box.isParagraph[box.altLines] = 1;
                        box.height += (ascent * .75);
                    }else
                        box.isParagraph[box.altLines] = 0;
                    if(box.txtAlt_len[box.altLines])
                        altTxtTotalLen += altTxtLen;
                        box.altLines += 1;
                        box.height += (ascent * 1.5);
                    ++extraLine;
                    if(box.doNotWrap)
                        for(int k = 0; XTextWidth(box.font, box.txtAlt[box.altLines] - 1, box.txtAlt_len[box.altLines - 1]) - k && k < 3; k++)
                            box.txtAlt[box.altLines - 1][altTxtTotalLen - k - 1] = '.';
                            //box.txtAlt[box.altLines - 1][numChars - k - 1] = '.';
                        break;
                break;
           --numChars;
        ++i;
    box.height += box.padding - descent;
    if(box.useHints)
        box.width = longestString + (box.padding * 2);
    else
        box.width = box.maxW;
   if(!fast_memcmp(box.justify, "c") || !fast_memcmp(box.justify, "center"))
                  box.x = 400 - (box.width / 2);
                  box.y = 220 - (box.height / 2);
   }else if(!fast_memcmp(box.justify, "r") || !fast_memcmp(box.justify, "right"))
                  box.x -= box.width + (box.border * 2);
    box.window =
        XCreateSimpleWindow (box.display,
                             box.root,
                             box.x,
                             box.y,
                             box.width,
                             box.height,
                             0,
                             BlackPixel(box.display, 0),
    XSelectInput (box.display, box.window, ExposureMask|KeyPressMask|ButtonPressMask);
    XMapWindow (box.display, box.window);
/* Set up the GC (Graphics Context). */
static void set_up_gc ()
    XColor color;
    Colormap colormap = DefaultColormap(box.display, 0);
    XParseColor(box.display, colormap, "#00FFFF", &color);
    XAllocColor(box.display, colormap, &color);
    box.gc = XCreateGC (box.display, box.window, 0, 0);
    XSetBackground (box.display, box.gc, box.black_pixel);
    XSetForeground (box.display, box.gc, color.pixel);
    XSetFont (box.display, box.gc, box.font->fid);
/* Draw the window. */
static void draw_screen ()
    int x, y, direction, ascent, descent;
    XTextExtents (box.font, box.txtAlt[0],
     box.txtAlt_len[0], &direction, &ascent, &descent, &overall);
    XClearWindow (box.display, box.window);
    x = box.padding;
    y = box.padding + ascent;
    for(int i = 0; i < box.altLines; )
        if(box.isParagraph[i])
           y += (ascent * .75);
        XDrawString (box.display, box.window, box.gc,
                 x, y, box.txtAlt[i], box.txtAlt_len[i]);
        y += (ascent * 1.5);
        ++i;
/* Loop over events. */
static void event_loop ()
    struct timeval tv;
    XEvent e;
    Atom wmDelete=XInternAtom(box.display, "WM_DELETE_WINDOW", True);
    //XSelectInput (box.display, box.window, ExposureMask|KeyPressMask|ButtonPressMask);
    XSelectInput (box.display, box.window, ExposureMask|ButtonPressMask);
    int running = 1, num_ready_fds, x11_fd = ConnectionNumber(box.display);
    fd_set in_fds;
    // Main loop
    while(running)
        // Create a File Description Set containing x11_fd
        FD_ZERO(&in_fds);
        FD_SET(x11_fd, &in_fds);
        tv.tv_usec = 0;
        if(box.timer)
            tv.tv_sec = box.timer;
        else
            tv.tv_sec = 1;
        while(XPending(box.display))
            XNextEvent (box.display, &e);
            switch(e.type)
                case (KeyPress):
                case (ButtonPress):
                //case (ClientMessage):
                          XSetWMProtocols(box.display, 0, &wmDelete, 1);
                          running = 0;
                          break;
                case (Expose):
                          draw_screen ();
                          break;
        // Wait for X Event or a Timer
        num_ready_fds = select(x11_fd + 2, &in_fds, NULL, NULL, &tv);
        if (!num_ready_fds && box.timer)
                running = 0;      // Exit gracefully
void printArgs()
            puts("note v.1 (alpha 1)- released 2019-04-25");
            puts("Usage: [options] [text]");
            puts("\nOptions:");
            puts("\n\t-x\t\t\tx cooridinate");
            puts("\n\t-y\t\t\ty cooridinate");
            puts("\n\t-fs, --fontsize \tFont size");
            puts("\n\t-w,  --maxwidth\t\tMaximum width of text");
            puts("\n\t-nh, --nohints \t\tDisable hinting. Forces fixed window\n\t\t\t\tsize (retains size of --maxwidth).");
            puts("\n\t-t,  --time\t\tDuration notification is displayed\n\t\t\t\t(in seconds). Arg '0' is indefinite.");
            puts("\n\t-j,  --justify\t\tText justification. Takes args:\n\t\t\t\t[-l|--left|-c|--center|-r|--right]");
            puts("\n\t-nw, --nowrap\t\tDisable text wrapping.");
            puts("\n\t-p,  --padding\t\tPadding (% of char size).\n\t\t\t\tE.g., for 150% padding, use: -p 150");
            puts("\n\t-a,  --autowidth\tWidth adjusts to text size.");
int main (int argc, char ** argv)
    // Set defaults for text to be display in top right corner
    box.useHints  = 1;
    box.doNotWrap = 0;
    fast_strcpy(box.justify, "right");
    box.fontSize  = 18;
    box.timer     = 3;
    box.x         = 780;
    box.y         = 25;
    box.maxW      = 300;
    box.autowidth = 0;
    box.padding   = 100;
    box.lines     = 0;
    int i = 1;
    for (; i < argc ; )
        if(!fast_memcmp(argv[i], "-nh") ||
           !fast_memcmp(argv[i], "--nohints"))
            box.useHints  = 0;
        } else if(!fast_memcmp(argv[i], "-nw") ||
                  !fast_memcmp(argv[i], "--nowrap"))
            box.doNotWrap = 1;
        } else if(!fast_memcmp(argv[i], "-j") ||
                  !fast_memcmp(argv[i], "--justify"))
            fast_strcpy(box.justify, argv[++i]);
        } else if(!fast_memcmp(argv[i], "-fs") ||
                  !fast_memcmp(argv[i], "--fontsize"))
            box.fontSize = fast_strtoul(argv[++i]);
        } else if(!fast_memcmp(argv[i], "-w") ||
                  !fast_memcmp(argv[i], "--maxwidth"))
            box.maxW = fast_strtoul(argv[++i]);
        } else if(!fast_memcmp(argv[i], "-t") ||
                  !fast_memcmp(argv[i], "--time"))
            box.timer = fast_strtoul(argv[++i]);
      } else if(!fast_memcmp(argv[i], "-a") ||
                  !fast_memcmp(argv[i], "--autowidth"))
            box.autowidth = 1;
        } else if(!fast_memcmp(argv[i], "-x"))
            box.x = fast_strtoul(argv[++i]);
        } else if(!fast_memcmp(argv[i], "-p" ) ||
                  !fast_memcmp(argv[i], "--padding"))
            box.padding = fast_strtoul(argv[++i]);
        } else if(!fast_memcmp(argv[i], "-y"))
            box.y = fast_strtoul(argv[++i]);
        } else if(!fast_memcmp(argv[i], "-h") ||
                  !fast_memcmp(argv[i], "--help"))
            printArgs();
            return 0;
        } else
           break;
        ++i;
    for(; box.lines + i < argc; )
       box.txt_len[box.lines] = fast_strlen(argv[box.lines + i]);
       box.txt[box.lines]     = argv[box.lines + i];
       ++box.lines;
    // No text was given, so just print the filename arg as text
    if (!box.lines)
       ++box.lines;
       box.txt[0] = argv[0];
       box.txt_len[0] = fast_strlen(box.txt[0]);
    x_connect ();
    create_window ();
    set_up_gc ();
    event_loop ();
    return 0;
View github for updated versions: https://github.com/bathtime/all/blob/master/note.c#L2
Also, looking for suggestions and any input-big or small! :)
PeterO
Re: An incomplete mini notification system in C
Mon May 06, 2019 9:19 pm
How do you use this because
./note "hello world"
Segmentation fault (core dumped)
PeterO
bedtime
Mon May 06, 2019 10:45 pm
PeterO
i'm very sorry about this.
You see, I'm in Canada, and the weather has been most beautiful, so there is a slight chance that I may have partaken in some ungava (43.1% alc.), Premium Canadian Gin, and thus I may have overlooked that I had entered 'terminus' as the font on line 170.
Could you please try changing that line to:
fast_strcat(font, "-*-*-medium-r-*-*-");
... and recompiling?
What happens?
You can type './note -h' for a rude explanation of the parameters.
Again, I'm sorry about this. The app really wasn't designed for the public, and I just wanted to share.
Please let me know.
Thanks. :)
jahboater
Mon May 06, 2019 10:56 pm
Here are couple of small things.
All the cases of "for(; *s2; )" could be replaced with "while( *s2 )", its just a little easier to read.
You have produced many "fast" replacements for the standard library functions. The compiler knows all about these functions (they are part of the C standard) and will replace them with inline code itself - if it helps performance.
Make use of things like "*s2++" on the Pi which has auto increment addressing (though the compiler will likely do it for you).
For example, you could replace:-
    for(; *s2; )
        *s = *s2;
        ++s;
        ++s2;
with
while( *s2 )
   *s++ = *s2++;
PeterO
Tue May 07, 2019 6:08 am
Yes font selection was the problem.
Your interest in "old school" code is admirable, but I have to say, that an equivalent solution produced with modern tools is much easier.
PeterO
bedtime
Tue May 07, 2019 4:59 pm
PeterO wrote: Yes font selection was the problem.
PeterO
Though, in the world of computers, you often end up paying for that convenience. Most of my programs have a near-instant startup, and I'd like to keep it that way.
Agreed and done.
I took them out. Thanks.
    for(; *s2; )
        *s = *s2;
        ++s;
        ++s2;
with
while( *s2 )
   *s++ = *s2++;
I agree with replacing the 'for' with 'while', but I just did a benchmark on the very functions below and found my code to be significantly faster:
#1.
    while(*s2)
        if(*s != *s2)
            return 1;
        ++s;
        ++s2;
    return 0;
#2.
int fast_memcmp2(char *s, const char *s2)
    while(*s2)
        if(*s++ != *s2++)
            return 1;
    return 0;
Results when ran 10000000x:
1. 0m05.35s real 0m05.35s user 0m00.00s system
2. 0m05.43s real 0m05.41s user 0m00.00s system
These results were consistent and varied by only +.01s. That's over 1% performance difference; I'll take it.
Return to “C/C++”
