mattg31
Imports causing python script to hang at startup
Sun May 05, 2019 11:10 am
I have a python script running on a raspberry pi that I want to run automatically at startup. I had this working until I added a temperature sensor, and now the program wont run automatically at startup, but will run fine with no errors if I run it manually.
Is there something I don't know about certain imports at startup?
What works:
I modify `rc.local` by adding `python /home/pi/myscript.py &` near the end of the file.
where myscript.py =
    #!/usr/bin/python3
    import RPi.GPIO as GPIO #for GPIO naming convention
    import os #for power circuit
    import serial #for reading serial port on USB
    import time
    import threading
    def power_button():
	    GPIO.setmode(GPIO.BCM)#set to GPIO Values
	    GPIO.setwarnings(False)
	    GPIO.setup(4,GPIO.OUT)#relay coil
	    GPIO.setup(22,GPIO.OUT)#power LED
	    GPIO.setup(27,GPIO.IN)#power button sense
	    GPIO.output(4,GPIO.HIGH)#turn on coil
	    GPIO.output(22,GPIO.HIGH)#turn on power LED
	    powerButton = GPIO.input(27)
	    while powerButton ==1: #check for change, then shutdown
	    #change occured, as program left the while loop, proceed below
	    GPIO.output(22,GPIO.LOW)#turn off power LED
	    os.system('sudo shutdown -h now')
    #power button thread
    thread1 = threading.Thread(target=power_button)
    thread1.start()
Like mentioned above, this code works and runs properly at startup automatically.
What doesn't work:
When I add my temperature sensor imports, it will no longer start automatically, but will run fine if I run manually after the pi boots up.
myscripy.py with more imports added:
    #!/usr/bin/python3
    import time
    import threading
    import adafruit_sht31d #sht temphumid sensor
    import board #sht temphumid sensor
    import busio #sht temphumid sensor
    import requests #for posting
    # Create library object using our Bus I2C port for SHT31 temp humid sensor
    i2c = busio.I2C(board.SCL, board.SDA)
    sensor = adafruit_sht31d.SHT31D(i2c)
    def power_button():
    thread1.start()
Any ideas?
bensimmo
Re: Imports causing python script to hang at startup
Sun May 05, 2019 1:09 pm
You probably need to log the errors how are you starting it?
It could just be a permissions problem (e.g. needs to be run as pi user)
Or it may need a delay so everything is up and ready.
(As a note, it looks like you are importing the same thing twice, sht31t ?)
bensimmo
Sun May 05, 2019 1:11 pm
I must read better
Try changing to python3
It's often better to do (I've found anyway)
cd /home/pi
su pi -c "python3 my script.py > thelogfile.log 2>&1"
That way you can see what is going on (any print statements and any error or crashes in the order they appear, normally)
scruss
Sun May 05, 2019 1:16 pm
One of the libraries you're importing is expecting a network connection? The network might not be up by the time rc.local is run.
Pronouns: he/him
mattg31
Mon May 06, 2019 9:57 am
Thanks for the feedback guys. I tried quite a few things to make this work, ultimately it was making it executable, then running it as pi user from rc.local (/bin/su -c "/home/pi/myscript.py" - pi &), then finally adding in a 10 second delay to the beginning of the program to let everything startup before all the imports occur.
Thanks again!
Return to “Python”
