Hi mates, I?m using RB3 only for Node Red and Teamviewer (no USB attached, 5,15 volt power), usually the load is very low, maybe 2 to 5%, I've tried to open some holes in the cover so I lower from 59° to 52° now. Is it to consider safe temperature to a long life?
I don't want to add a fan cause in the long run it just make the things worst because of the dust, so I searched for some passive coolers and it seems there are available only small ones, are them worth? maybe some degrees less with such low cpu usage, what is your experience about it? Do you have some other suggestions? Thanks
