wolf123
Issue with bluetooth adapter
Fri May 03, 2019 5:17 pm
Hi there!
I'm trying to set up a bluetooth adapter on my raspberry pi (model 1 B+). The adapter comes from Farnell and it is supposed to be compatible with Raspian.
The adapter seems to be recognized, since:
$ lsusb
Bus 001 Device 005: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 001 Device 004: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp. SMC9512/9514 USB Hub
But, when I fire up blueman-manager, I get prompted a warning window: "Bluetooth turned off - Bluetooth needs to be turned on for the device manager to function". I click on "Enable bluetooth" and the manger starts with the "Adapter" button grayed out.
I checked the troubleshooting section of the blueman project, and it suggests that my adapter might be at fault.
Running
$ bluetoothctl
[bluetooth]# list
doesn't get me any results.
The documentations suggests that the culprit might be a killswitch of some sort, but bluetooth seems enable on rfkill:
$ rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
I am running the latest Raspian image (tried both lite and 'regular' favors).
Any ideas, anyone?
Thank you very much.
Douglas6
Re: Issue with bluetooth adapter
Fri May 03, 2019 9:41 pm
What do you get from
hciconfig - a
If it indicates the adapter is "DOWN" (I suspect it will), try
sudo hciconfig hci0 up
If that fails, report the results.
