jstacy00
Extended Tweets in Twython
Mon Apr 29, 2019 6:09 pm
I am kind of new to Python and the Twython module. The tweets that my program is reading/printing out, are still limited to 140 characters rather than the newer 280 standard. I've read that you could possibly use tweet_mode=extended, however, I'm not sure where to apply this in my code, below:
import cups
from twython import TwythonStreamer
#set up the printer
conn = cups.Connection()
printers = conn.getPrinters()
prin = conn.getDefault()
from auth import (
    consumer_key,
    consumer_secret,
    access_token,
    access_token_secret
class MyStreamer(TwythonStreamer):
    def on_success(self, data):
        if 'text' in data:
            username = data['user']['screen_name']
            tweet = data['text']
            #Creates a text file and writes the tweet to that file
            fout = open ("twitter.txt","w")
            fout.write("@{}:\n".format(username))
            fout.write("{}".format(tweet))
            fout.close()
            #Prints the text file
            conn.printFile(prin, "/home/pi/twitter.txt"," ", {})
stream = MyStreamer(
    consumer_key,
    consumer_secret,
    access_token,
    access_token_secret
stream.statuses.filter(track='#overheard')
Could I get a little help with this. Thanks!
Re: Extended Tweets in Twython
Mon Apr 29, 2019 6:24 pm
jstacy00
Mon Apr 29, 2019 7:12 pm
Thanks! I went ahead and added it to the last line. However I'm still only getting 140 characters. Did I put it in the wrong place?
stream.statuses.filter(track='#overheard', tweet_mode='extended')
thanks again.
Mon Apr 29, 2019 9:01 pm
I don't know. Post a new issue on GitHub and the code author(s) can help.
jstacy00
Tue Apr 30, 2019 1:07 pm
will do. Thanks!
Return to “Python”
